Inverse Function with Differentiation
The discussion focuses on finding the derivative of the inverse function of f(x) = x^3 + e^x at the point 2, specifically (f^-1)'(2). It is established that there is no need to explicitly find the inverse function to solve the problem. Instead, the chain rule is applied, leading to the formula g'(x) = 1 / (g^-1)'(g(x)), where g(x) is defined as f^-1(x).
  • Understanding of inverse functions and their properties
  • Proficiency in applying the chain rule in calculus
  • Familiarity with differentiation of composite functions
  • Knowledge of exponential and logarithmic functions
  • Study the application of the chain rule in differentiation
  • Learn about the properties of inverse functions in calculus
  • Explore examples of differentiating inverse functions
  • Investigate the behavior of the function f(x) = x^3 + e^x and its derivatives
Students and professionals in mathematics, particularly those studying calculus and differential equations, as well as educators teaching inverse functions and differentiation techniques.
Soaring Crane
Let f(x) = x^3 + e^x.
Find (f^-1)'(2).
I know how to do everything else except the first step. How do you find the inverse of f(x)? I know the inverse of an exponential function is a logarthmic function, but where do I proceed from here?
Thanks.
There's a theorem for that
Find (f^-1)'(2).
Thanks.
You don't need to find an inverse function to answer this question, you only need to determine the value of its derivative at 2. I am supposing that you know the chain rule:
Let [itex]y=g(x)[/itex] so that [itex]g^{-1}(y)=x[/itex]. Recall that y is a function of x, so in differentiating w.r.t. x we apply the chain rule to get [itex]\left( g^{-1} \right)^{\prime}(y)y^{\prime}=1[/itex] but [itex]y=g(x)[/itex]
so put [itex]y^{\prime}=g^{\prime}(x)[/itex] and the equation becomes [itex]\left( g^{-1} \right)^{\prime}\left( g(x)\right) g^{\prime}(x)=1[/itex] or [itex]g^{\prime}(x)=\frac{1}{\left( g^{-1} \right)^{\prime}\left( g(x)\right)}[/itex].
In your problem, let [itex]g(x)=f^{-1}(x)[/itex].
  • · Replies 31 ·
