Help with proving limits using Epsilon-Delta definition
  • Context: Undergrad
  • Thread starter Thread starter shirewolfe
    Definition Limits
The discussion revolves around proving limits of quadratic functions using the Epsilon-Delta definition, specifically focusing on the limit of the function f(x) = x^2 + 1 as x approaches 1. Participants explore the necessary steps and relationships to establish the limit rigorously.
  • One participant expresses difficulty in proving the limit and outlines their initial steps, questioning how to relate |x+1||x-1| to |x-1| to find delta in terms of epsilon.
  • Another participant suggests using the triangle inequality to bound |x + 1|, proposing that |x + 1| can be expressed in terms of |x - 1| and a constant.
  • A different participant challenges the initial claim of having found the limit, emphasizing that the value of 2 is merely a guess and not yet verified through the Epsilon-Delta definition.
  • This participant provides a structured approach to proving the limit, detailing assumptions and inequalities that must be satisfied to establish the limit rigorously.
  • A later reply acknowledges the correction regarding the nature of the limit, clarifying the intent behind the initial statement about finding the limit.
  • Another participant expresses a light-hearted acknowledgment of their tone in the discussion, indicating a collaborative atmosphere despite earlier disagreements.
Participants do not reach a consensus on the initial claim of having found the limit, with some asserting it is merely a guess and others providing methods to verify it. The discussion contains both supportive guidance and critical challenges, indicating a mix of agreement on the need for rigorous proof and disagreement on the initial assertions.
Some assumptions regarding the bounds of delta and epsilon are made, but these are not universally accepted or resolved within the discussion. The relationship between |x+1| and |x-1| is also not fully established, leaving some uncertainty in the approach.
shirewolfe
I am having trouble proving the limits of quadratic functions such as the following. (I used "E" to represent epsilon and "d" for delta)
lim [(x^2)+1]
x->1
I found the limit, L, to equal 2 and have proceeded through the following steps:
|f(x) - L| < E
| [(x^2)+1] - 1| < E
|[(x^2)-1]| < E
|x+1||x-1| < E
While I also know that 0 < |x-1| < d.
My question is how do you find the numerical relationship between |x+1||x-1| and |x-1| so that I may find d in terms of E?
(I was thinking of finding the bounded open interval in which |x+1||x-1| = |[(x^2)-1]| and substituting the greastest figure of the interval, which would be greater than |x+1|, in place of |x+1| so that I would have z|x-1|< E where z is an identified numerical value. However, in problems like the one above, |x+1||x-1| = |[(x^2)-1]| within a seemingly unbounded interval.)
please help. your time and assistance is very much appreciated.
Use the triangle inequality perhaps, |x + 1| = |x - 1 + 2| <= |x - 1| + 2 < d + 2.
lim [(x^2)+1]
x->1
First of all, you have NOT found the limit, and certainly not shown that it is 2!
What you have done, is to make a GUESS at the limit value!
(As it happens, you've made a correct guess, but that is irrelevant; it's still a guess).
What you are to do now, is:
1. Does my guess (2) satisfy the properties that a limit must have?
2. Let |x-1|&lt;\delta
3. Then, |x^{2}+1-2|=|x^{2}-1|=|x-1||x+1|
4. Now, by assumption, |x-1|&lt;\delta
Let us make a further assumption, that \delta&lt;1
Then, |x+1|&lt;2 (\delta&lt;1)
And:
|x^{2}+1-2|&lt;2\delta, (\delta&lt;1)
5. Let \epsilon&gt;0
If we are to have |x^{2}+1-2|&lt;\epsilon for all x satisfying |x-1|&lt;\delta it is sufficient if the following inequalities are simultaneously satisfied:
2\delta&lt;\epsilon
\delta&lt;1
Hence, setting \delta=min(\frac{\epsilon}{2},1) suffices.
That is, we were able to show that our guess (2) satisfy the properties a limit must have.
By 'finding' 2 through the substitution of 1 in f(x)=[(x^2)+1] I meant that it was a possible limit whose validity must be varified through the E-d definition. Thank you for correcting me however, to avoid my own future confusion.
Thanks for the helpful guidance and clarification.
I was perhaps a bit too snappish on that point, don't bite me back, though..:wink:
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 16 ·
