Does QED Originate from Non-Relativistic Systems?
  • Context: Graduate
  • Thread starter Thread starter A. Neumaier
    Qed
The discussion revolves around the origins of Quantum Electrodynamics (QED) and its relationship with non-relativistic systems, particularly in the context of lattice QED and Poincare invariance. Participants explore theoretical implications, interpretations, and the validity of various models within quantum field theory.
  • Some participants propose that QED can be conceptually derived from non-relativistic quantum mechanical systems like lattice QED, while others argue that this view distorts the facts, emphasizing that lattice QCD is motivated by Poincare invariant QCD.
  • There is contention regarding the accuracy and relevance of lattice QED, with some asserting that it is not a good example for demonstrating Lorentz invariance arising from non-invariant theories.
  • Some participants assert that Poincare invariant QED is a low energy effective theory and question the existence of a true Poincare invariant version of QED at all energies due to the presence of a Landau pole.
  • Others counter that standard textbooks discuss Poincare invariant QED and that its renormalized results are indeed Poincare invariant, suggesting that unresolved issues do not negate its status as a valid theory.
  • There are claims that lattice QED has significant limitations, including dependence on lattice spacing and the need for fine-tuning to achieve results that align with QED predictions.
  • Some participants express skepticism about the notion that QED lacks validity as a quantum theory without a nonperturbative version, arguing that many textbooks recognize QED as an excellent quantum theory.
  • Disagreement exists over whether lattice QED and Poincare invariant QED yield the same low energy effective theories, with some asserting they do not and highlighting differences in predictions.
Participants generally disagree on the relationship between QED and non-relativistic systems, the validity of lattice QED, and the implications of Poincare invariance. Multiple competing views remain, and the discussion is unresolved.
Participants note that the existence of a Landau pole in QED raises questions about its validity at high energies, and there are unresolved mathematical aspects regarding the nonperturbative version of QED. The discussion also highlights the dependence of lattice QED on specific parameters and the need for fine-tuning.
  • #91
Demystifier said:
So from the fact that nobody did it so far, you conclude that it cannot be done?
I strongly doubt it too. I'm not aware of a single paper about lattice QED. Only lattice QCD is of course a standard method for several decades by now, and there are still serious problems to be solved (e.g., getting S-matrix elements, solving the finite-temperature case at finite baryo-chemical potential satisfactorily etc. etc., but indeed it's a very active field of research, while about lattice QED, I've not even seen a single paper).
  • #92
Demystifier said:
I'm not an expert in lattice QFT, so I cannot give a reference. I know that perturbative analytic calculations at lattice are more difficult than those in the continuum, but this in no way indicates that lattice perturbative results don't agree with observations.
Well, as long as there don't exist some lattice perturbative results, we can't check, right?
  • #93
atyy said:
Of course not - I agree with you that the construction problem is wide open - and that is the point! [...] Since the construction problem is open, the claim that Poincare invariant QED exists is not substantiated.
Only the construction problem for a QED satisfying the Wightman axioms or equivalents is wide open. The construction problem for a Poincare invariant QED at 1-loop that agrees with experiment was fully solved in 1948 and this solution was honored by a Nobel price for Feynman, Tomonaga and Schwinger. In fact, few physicists care about constructive QFT at all; it is a problem only for the small minority of mathematical physicists.
atyy said:
Only when the construction problem is solved can one claim that Poincare invariant QED exists.
This is the view of mathematical physicists. But for them, lattice QED is definitely not QED, and a mere effective theory is no theory at all. Thus to claim their view as the authoritative view completely defeats your goal to promote lattice QED.
atyy said:
Since the construction problem is wide open, we cannot at the moment use a truly Poincare invariant QED as a starting point for Wilsonian renormalization.
Wilsonian renormalization is virtually useless in QED. It is not responsible for any its successes. So not having this starting point is irrelevant in practice.
  • #94
Doubt what? It's technically more difficult, but I see no reason to expect that, if someone could solve the technical problems, one would not give results that agree with observations.
  • #95
Well, I don't believe a calculation that doesn't exist. Why should I bother myself with a tedious calculation leading to results which I can get much easier with the well established calculational methods developed over the past 40 years to evaluate relativistic QFTs perturbatively right away in the continuum?
  • #96
Don't take me for granted, but I think there are 1-loop lattice results which, for low energy phenomena, agree with standard 1-loop results. In any case, the book by Montvay and Munster is a very good reference. If you take some time to read it, you will see that the difference between perturbative lattice QFT and ordinary perturbative QFT can, to a large extent, reduce to the difference between Fourier sum and Fourier integral.
  • #97
No, but for two other reasons:
1. There is the general feeling in the community that the continuum limit of lattice QED is likely to be trivial (I gave a reference for that), which would impose a rigid limit on the accuracy achievable).
2. What has been done anywhere in lattice QFT has always lead to very low accuracy (a few percent at best). Accuracy increases like ##N^{-1/2}## with the number of lattice points per dimension, and work increases like ##N^7##. Extrapolating to what is needed to get 10 significant did accuracy would require of the order of ##10^{20}## lattice points per dimension. Thus of the order of ##10^{80}## lattice points and of the order of ##10^{140}## floating point operations would be needed. This doesn't prove that it cannot be done. But surely it cannot be done during the time any of those participating in this discussion will live.
  • #98
When I see a big picture that this calculation entails, I do.
  • #99
There is a little trickle of them. Nothing at all in their results is inviting to work on the topic.
Of the 442 pages of main text excluding references, only 12 pages are on lattice QED (Section 4.5), and much of it summarizes results from continuum QED (e.g., Pauli-Villars regularization on p.227). The last 2 1/2 pages (pp.228-230) contain information on nonperturbative studies of lattice QED in very simplified scenarios (e.g., the quenched approximation). They conclude by stating that
Montvay and Munster said:
the fermion always decouples in the continuum limit, leading to a trivial bosonic theory. These non-perturbative studies of renormalization suggest that the continuum limit of lattice QED is trivial.
This conclusion by experts on the subject is diametrically opposite to atyy's claims that lattice QED is a good approximation of QED, or a good starting point for low energy QED.
  • #100
Please share your thinking in enough detail that others can check its cogency.
  • #101
A. Neumaier said:
This has nowhere be done; it is wishful thinking.
It is no more wishful that asserting that Poincare invariant QED exists - no one has shown that it exists at all energies, and if it does not exist at all energies, then it cannot be Poincare invariant.
  • #102
vanhees71 said:
As I said, I consider it also not very advantageous to use the lattice regularization to define QFT. There are better ways to regularize perturbative QFT like Pauli Villars or dim. reg. or a stupid old cutoff (in Euclidean QFT maybe the most simple idea). Conceptually regularization is even a bit unintuitive for my taste, and my great "aha feeling" came when I learned the BPHZ formalism, which uses always physical masses, couplings and fields order by order in PT (either loop-wise, i.e., in powers of ##\hbar## or in some coupling constant(s) or any other counting scheme appropriate to the definite model under investigation) and the counter-term approach. Then you simply subtract the divergences, introducing the renormalization scale etc. Then you get the RG equation from the independence of S-matrix elements on the choice of the renormalization scale (and even the renormalization scheme). This more conventional approaches are all well defined ways to work in renormalized perturbation theory with only finite quantities at any step of the calculation. For me it's way more intuitive than an artificial space-time lattice with quite nasty properties (fermion doublers and other kinds of artifacts, the lost Poincare, Lorentz, rotation invariance etc. ect.) and very delicate convergence issues if you want to get to the continuum limit. I'm also not familiar with the calculational techniques to evaluate even a simple one-loop diagram as vacuum polarization and electron self-energy on the lattice. With the other techniques it's not such a big deal. For a nice introduction also to calculational techniques see P. Ramon, QFT - A Modern Primer.
In my opinion, the best way to understand the quite involved ideas behind renormalized perturbation theory is to sit down and do calculations like the one-loop structure of QED to the end. For a beginner, I'd recommend to use the modern approach, using dim. reg. as regulator and then discussing various renormalization schemes like minimal subtraction and/or modified minimal subtraction, the usual on-shell scheme.
There is not much difference between a stupid old cutoff and lattice QED - both mean explicitly that the theory does not exist at all energies. If QED does not exists at all energies, then it cannot be Poincare invariant.
  • #103
Nobody claims that QED is valid at all energy scales (nor any other QFT for that matter). It is very likely, although not strictly proven, that QED has a Landau pole, where it breaks down, but it's at very high energies irrelevant for all practical purposes. Whether there exists some more comprehensive theory than relativistic QFT that is valid at all energy scales, is unknown today.
For the so modified interpretation of QFTs as low-energy effective theories, it is totally irrelevant which regularization you use. The regularized theory is just a step in the calculation for the S-matrix elements in terms of well-defined finite renormalized quantities.
It's not even necessary to use regularization at all. You can as well directly renormalize using the BPHZ formalism, it's only technical sometimes a bit less convenient than modern regularization techniques like dim reg or the heat-kernel methods or even Pauli-Villars (in some cases where dim. reg is not easily applicable). Finally, all that counts and all that's comparable to experiment are the results of renormalized perturbative QED.
  • #104
If we don't know whether QED exists at all energies, then doesn't it mean we don't know whether it is truly Poincare invariant (since an energy cutoff spoils Poincare invariance)?
  • #105
Again, the claim is that it is a good approximation at large distances. As I already said, I don't give a damn what any theory without quantum gravity say in the continuum limit.
  • #106
Why bother? Even if I find the reference (which would take some time because I'm not an expert), this will not change your general opinion.
  • #107
True, but there is also a general feeling in the community that this does not affect predictions for long distance phenomena. The point of effective theories (lattice QFT, continuum Standard Model without quantum gravity, ...) is to study long distance phenomena. Those who worry much about the continuum limit are missing the point.
You are talking about Monte-Carlo simulations (of lattice QFT) at a computer, but it should be distinguished from lattice QFT as such.
  • #108
All formulas of the renormalized, textbook QED, existing since 1948 as witnessed by a Nobel prize given for its discovery, are fully Poincare invariant at every loop order, and make excellent predictions. Thus your assertion is a purist's claim (who apparently thinks that only satisfaction of the Wightman axioms may define what existence means) , irrelevant to the success of QFT since 1948.
But unlike the first feeling, which is corroborated by quite a number of studies of QED and related theories whose lattice version has a Landau pole (and I pointed to one), you cannot point to a single paper where the second feeling is corroborated by making highly accurate predictions form lattice QED.
You should bother for the sake of the readers of this thread, who are surely interested whether your claims are substantiated or just irrelevant private thoughts. I write for the readers, not for the participants in the discussion - the latter rarely change their point of view due to the arguments.
The whole point of a physical theory is to make good and testable predictions. A theory that makes predictions the content of which one can never find out is untestable and not worth its salt. Lattice QFT was created to contribute constructively to QCD through lattice computations, not to make empty statements (where those who make it don not even bother to justify them by references) about the power of a lattice QED with which nobody will ever be able to make competitive predictions! The paucity of papers on lattice QED is ample evidence of this fact.
  • #109
Let them speak for themselves!
  • #110
A. Neumaier said:
We mainly discuss textbook QED, which is a Poincare invariant theory at few loops,[...] and rigorous QED, of which it is unknown whether it exists.
Sure, and you keep mixing these two, while not clarifying atyy's query about what you mean by Poincare invariant in this context. The Poincare invariance you are talking about seems to refer to the global(spacetime) symmetry in the rigorous QED that is unknown whether it exists but it is confusely mixed with the local(at every loop order, at each energy) Poincare invariance that make to 10 or more decimal precision predictions that you mention here:
Instead of using a patronizing tone towards everyone you could address this.
  • #111
He didn't query about this meaning.
The meaning of Poincare invariance is everywhere the same, with a choice of 4 different Poincare groups which have the same Lie algebra. In case of QED, the biggest (the universal cover) applies, as anyone can check who understands 1-loop QED. Nothing in my or atyy's arguments depends on whether one has a more restricted notion of Poincare group, considering only the connected component of unity. Thus is is pointless to dwell on these details.
  • #112
He actually assumes the same meaning for Poincare invariance and yet he asks:
The meaning you refer to below is only compatible with the existence of the rigorous QED(i.e. at all energies).
Perhaps is not so pointless because the local Poincare(algebra) invariance guaranteed loop by loop (therefore already at one loop) doesn't inmediately generalize to the full group global invariance, you need to assume the rigorous asymptotically valid QED at all energies that you admit might not exist. If it doesn't exist the exponential map from the algebra to the group is not guaranteed to be injective.
  • #113
This debate might look interesting, but is in fact pointless. QED as a quantum field theory in 4D Minkowski spacetime has as input parameters the Lagrangian action of the coupled Dirac field (psi, psi-bar) and the electromagnetic field (A). This is obviously Poincare invariant. As in any other Quantum Theory, the question poses as: the input of this theory is the Lagrangian action, but what are the states and observables of this theory (output) ? Are they truly Poincare invariant ?
  • #114
1-loop QED exists rigorously at all energies. It is invariant under exactly the same Poincare group as the full theory. Only the accuracy is not the same at high energies as that of fully nonperturbative QED, whose existence is in doubt. But it is already much better than anything what lattice QED has to offer.
  • #115
You mean that it is compatible with approximations at other energies, 1-loop is a low energy approximation, but what I'm saying is that the fact of obtaining finite accurate predictions at different orders doesn't imply Poincare group invariance at all orders, because that precisely what you need a rigorous QED for. The Landau pole is just a possible obstruction to that, there are others.
No, only under the local identity component algebra, unless you assume a Minkowski spacetime from the beginning, but then why would you say the existence of a rigorous QED is in doubt. Only if there was a rigorous QED in the first place we could assume the full symmetry of Minkowski spacetime as the exact one for the physical theory and also derive it from the algebra using the exponential map.
Of course, I'm not discussing this.
  • #116
Well, that's close to the question I've been trying to pose. Admitting the possibility that if the input is not rigorously proved, we must admit the possibility that the output is not globally Poincare invariant and belongs to a different input.
  • #117
Rocky, the input is clear, we're speaking about a specially-relativistic field theory (hence it admits a Lagrangian density in flat Minkowski spacetime) with known assumptions: locality (the no. of space-time derivatives is finite), global Poincare invariance (the action in terms of integrated fields and their derivatives stays the same under a global Poincare transformation of the fields up to a hypersurface term). These two assumptions uniquely define the (gauge-fixed) Lagrangian density. Now what do we do with it? Define the quantum observables: energy spectra of bound states could be an example. Can this be calculated exactly (within formal mathematics) ? If so, it must be Poincare invariant.
  • #118
RockyMarciano said:
I've got the feeling that you have run out of good arguments
All of my arguments in this thread are good and don't need to be repeated.
  • #119
Well, all I am saying (and I think also Arnold is saying) is that lattice QED is not the right formulation of the low-energy (long-distance) effective theory described by QED, leading to results that agree to experiment at 12 significant digits, but that's good old perturbative renormalized QED, formulated around 1948 and finally proven to exist at all orders as a Dyson renormalizable relativistic QFT in the mid 1960ies, when the problem of overlapping divergences was finally solved by the work of BPHZ.
  • #120
And I am saying that these 12 significant digits scan also be obtained by perturbative renormalied QED at the lattice. Nobody did it explicitly, but since Feynman rules for lattice QED are essentially the same (except that we have sum over momenta instead integral over momenta in loop diagrams), nobody expects significant deviations for g-2.
  • · Replies 376 ·
26K
  • · Replies 37 ·
10K
  • · Replies 37 ·
  • · Replies 87 ·
9K
  • · Replies 62 ·
13K
  • · Replies 23 ·
19K
