Hubble Constant, Dark Energy and the Expanding Universe
The discussion revolves around the Hubble constant, its relationship with dark energy, and the implications for the expansion rate of the universe. Participants explore the apparent contradictions in the behavior of the Hubble constant, particularly in light of recent observations suggesting it may be increasing, while traditionally it was thought to be decreasing. The conversation includes theoretical considerations, observational evidence, and the definitions of key terms related to cosmology.
  • Some participants question why the Hubble constant was assumed to be decreasing while dark energy is thought to accelerate expansion, highlighting a perceived paradox.
  • One participant describes the Hubble parameter and its time dependence, noting that its behavior depends on the scale factor and its derivatives.
  • Another participant clarifies that an accelerating expansion (##\ddot a > 0##) does not necessarily imply an increasing Hubble parameter, which can remain constant or decrease in certain models.
  • Some participants discuss the implications of recent observations from NASA and the Dark Energy Spectroscopic Instrument (DESI), suggesting that the Hubble constant may not be constant over time, which challenges previous assumptions.
  • There is mention of the distinction between the Hubble parameter, the Hubble constant, the expansion rate, and the cosmological constant, with some participants expressing confusion over these terms.
  • One participant points out that the measured value of the Hubble constant in the later universe is consistently higher than its value at the time of the Cosmic Microwave Background, raising questions about the reasons for this discrepancy.
Participants express multiple competing views regarding the behavior of the Hubble constant and its implications for cosmology. There is no consensus on whether the Hubble constant is truly increasing or decreasing, and the discussion remains unresolved regarding the implications of recent observations.
Participants note that the definitions and relationships between the Hubble parameter, Hubble constant, expansion rate, and cosmological constant are critical to understanding the discussion, but these concepts are sometimes conflated, leading to confusion.
PhanthomJay
Homework Helper
Insights Author
TL;DR
Recent info from Hubble suggests an Increasing Hubble constant (Source: NASA) that was originally thought to be decreasing, especially since Dark Energy assists in decreasing the expansion due to its own accelerating expansion properties that are making the universe less dense. Please explain this paradox.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
Space news on Phys.org
I think about it as follows:
The Hubble parameter ##H=\frac {\dot a} a##, where ##a## is the scale factor. To see how it changes in time, I take ##\dot H=\frac {\ddot a a-\dot a \dot a}{a^2}##.
If the expansion is constant, ##\ddot a =0##, then ##\dot H \lt 0##, i.e., the Hubble parameter decreases.
If the expansion accelerates, ##\ddot a \gt 0##, then the Hubble constant increases if ##\ddot a a \gt {\dot a}^2## and decreases otherwise. So, the outcome depends on the values of ##a, \dot a,## and ##\ddot a## at the moment.
This is a common confusion. The bottom line is that when we say accelerating expansion we mean ##\ddot a > 0##, which means that ##\dot a## increases, whereas the Hubble parameter is ##\dot a/ a##. Even if ##\dot a## increases, ##H## might not as covered in the previous post. In fact, in a dark energy dominated universe, ##H## is constant.
As @Hill rightly points out, if the expansion accelerates, the Hubble parameter ##H## could theoretically increase, remain constant, or decrease. In the most plausible current model (a dark energy dominated universe), ##H## decreases. In the de Sitter universe, whose only component is the cosmological constant ##\Lambda##, ##H## is constant.
PhanthomJay said:
TL;DR Summary: Recent info from Hubble suggests an Increasing Hubble constant (Source: NASA) that was originally thought to be decreasing, especially since Dark Energy assists in decreasing the expansion due to its own accelerating expansion properties that are making the universe less dense. Please explain this paradox.
While not answering your technical question about the functional relationship of the different constants (others have already addressed that), the reason that this is coming up at all is because improved astronomy suggests that the Hubble constant may not be constant.
The possibility that Hubble's constant was changing over time was something that was hinted at by the Hubble Space Telescope, which further astronomy observations in the last five years or so have reinforced. (Another thread in the cosmology forum with 94 posts so far reviews how strong the evidence for that hypothesis is, which is a matter of ongoing debate among astrophysicists.)
The measured value of Hubble's constant in the later universe is consistently higher than its measured value at the time of that the Cosmic Microwave Background was formed, and we're not sure why this is the case.
The indications that it has changed over time were heightened by recent observations that are more fine grained over multiple time periods in the history of the universe from the Dark Energy Spectroscopic Instrument (DESI) observatory, in Arizona. These observations prefer a non-constant Hubble constant and as a consequence, non-constant (a.k.a. dynamic) dark energy.
ohwilleke said:
... improved astronomy suggests that the Hubble constant may not be constant.
I think four concepts are being mixed up here that, although related, are very different: the Hubble parameter, the Hubble constant, the expansion rate, and the cosmological constant.
The Hubble parameter tells us the speed of galaxies' recession as a function of their distance. This parameter is constant in space, but varies over time. In the most widely accepted cosmological model, this parameter is constantly decreasing.
The Hubble constant is the current Hubble parameter.
The expansion rate refers to the rate of increase (or decrease) of the scale factor.
The cosmological constant is the factor that explains the acceleration of the expansion, that is, the acceleration of the growth of the scale factor.
1. this is an old thread - I'm not sure it's worth trying to engage with posts from close to two years back. Shame on Jamie for resurrecting the thread for no good reason.
2. I'm surprised that you'd misinterpret this so, given the general quality of your posting history, or the earlier posts in this thread providing clarification. Maybe it's me who's misreading your intent.
After all, the H0 doesn't change by definition, while that the Hubble parameter has to be changing must have been obvious ever since Hubble's observations were married to the framework of the FLRW metric. It decreasing with time is a necessary feature of any universe that's not fully dominated by dark energy. This is what the 'technical' posts you referred to explained.
Non-constant H hardly implies dynamic dark energy - although increasing, or not sufficiently decreasing, H could.
Furthermore, this is rather tangential to the Hubble tension issue, which btw doesn't measure a higher value of H at the present time than at recombination - the value at recombination was way, way higher. It's the present-time value extrapolated from the conditions in the past that doesn't quite measure up to the value for the same cosmic time, only measured more directly. Even assuming that this is a physics issue and not a measurement one, it isn't showing increasing H0. At best, it'd be showing an H that is not decreasing sufficiently fast, which could be due to growing dark energy density. Perhaps that's what you wanted to say.
I appreciated his clarification and, in particular, the clear list of the different terms in one short post. So after all, it added value to the thread, even if old.
  • Agree
The reason I decided to revive this thread is because I noticed that the final conclusion ("in a dark energy dominated universe, ##H## is constant") seemed incorrect to me, and I considered (perhaps mistakenly) that it's not the spirit of this forum to leave threads with erroneous conclusions.
But, well, this isn't the first time (and I suspect it won't be the last) that I've been severely criticized for something that seems perfectly normal to me.
I'm sorry, but I can't see exactly what I misinterpreted.
Other than mentioning you in passing, I addressed the person I quoted.
There's no need to get all up in arms over my remark. Your clarifications are all kosher. I'm merely bemused by the why of anyone wanting to respond to people who have long left the building.
As an aside, a 'X' dominated universe, afaik, may refer to a universe with that X being merely larger than any other density, by also a universe where any density other than the X is negligible. In the latter case, a dark energy dominated universe would be equivalent to (or asymptotically approaching) a de Sitter one.
Sorry, but in your post #7, it's not at all clear that in point 1 you're referring to one person and in point 2 to another.
In post #4 (which revives the thread), I'm responding to @Orodruin, who, as far as I know, hasn't left "the building".
I disagree. The current standard cosmological model is considered a dark energy dominated universe, and its dark matter content is far from negligible.
He wasn't. All of his response (except for mentioning you in passing, as he said) was to what he quoted from another user, not you.
Jaime Rudas said:
I disagree.
I don't think you do. I think you are just saying that our best current model of our actual universe is dark energy dominated in the first of the two senses that @Bandersnatch described. Since he did not claim that our actual universe was dark energy dominated in the second sense, nothing he said is inconsistent with what you said.
This is not an appropriate comment. If you think an old thread should not have been restarted, please use the Report button to bring it to the attention of the moderators instead of making this kind of comment in the thread. (What's more, it's not very consistent for you to first say the thread shouldn't have been restarted, and then continue the restarted discussion.)
Having looked at the recent posts, I don't see any issue with this thread having been restarted. So it's fine to continue participating.
Yes, you're right.
This is a matter of nomenclature. When you refer to our universe as dark energy dominated, the meaning is exactly that dark energy is just the largest component. However, in general usage, it is typically also used to refer to a situation where other components are negligible. This is the kind of situation I was referring to in my post so I don’t really see that anything was added on top of that apart from perhaps clarification of meaning the latter case
I always consider the Richard Nixonesque silent majority of readers to be my true audience.
PhanthomJay said:
TL;DR: Recent info from Hubble suggests an Increasing Hubble constant (Source: NASA) that was originally thought to be decreasing, especially since Dark Energy assists in decreasing the expansion due to its own accelerating expansion properties that are making the universe less dense. Please explain this paradox.
i am glad to read and applaud you for promoting the elimination for the need of dark energy. i discovered this 10 years ago or more by noticing that all the calculations for the expansion from Hubble onward used time with a positive value. looking back in time which Hubble did, sees time in the negative. Susskind has pointed this out in several lectures. i am surprised that no one has followed with recalculation of the expansion occurrence in the universe. first, one can not look deep into space and know or even speculate what the universe is doing today. my understanding is the Hubble noticed a greater red shift in quasar spectra the farther away the origin was from earth. the closer to earth observations reported less red shift in the spectra. the smaller red shift meant is closer to current time frame and smaller expansion rate in the universe; keep in mind that it is closer to current time. this observation and calculation change alone eliminates the need to introduce the concept of "dark energy".
Reference: https://www.physicsforums.com/threads/models-without-dark-energy.1067912/
Simply changing the "zero" of time changes nothing about physics.
You can, however, do mathematical modelling, which I would describe as a prediction rather than a speculation.
The quasar bit is wrong - quasars weren't discovered for about thirty years after Hubble's work. The rest is correct (although there is a lot of random velocity on top of the pattern in galaxies as close as the ones Hubble studied).
No it doesn't. Dark energy comes from the fact that the observed expansion history cannot be accounted for in an FLRW universe containing only matter, dark matter, and radiation. Dark energy is what you have to add to the model to make the predictions match measurement.
It may turn out to have a mundane explanation (e.g. it's an artefact of a measurement problem) or a truly exotic one (e.g. completely new physics required) or something in between. But you can't make it go away by changing the time you call ##t=0##. Otherwise I could rewrite all of physics by resetting my watch.
sorry for the miss attribution of quasar measurement to Hubble. time is not set to "0". Leonard Susskind
said time is not positive but negative when looking out in space. α dot / α should be negative. having a negative sign in front makes acceleration slowing. do your mathematical modelling correctly and then predict. hence there is no sustained accelerated expansion history observed in the far reaches of the universe.
there is no speculation when looking at history.
stephen h said:
Leonard Susskind
You are misunderstanding something Susskind said, then. Since ##a## is necessarily positive, negative ##\dot{a}/a## would imply negative ##\dot{a}##, which would imply a decreasing scale factor - i.e. a contracting universe which would have cosmological blue shifts, not red shifts. Such universes are possible to describe, but it's nothing like what our universe is doing at this time or any time in the past.
Can you link to whatever you read by Susskind?
I have looked for the Susskind quote again, but have not viewed all of his videos yet. i know that is important.
i am reading more on the presence of galactic clusters and will complete the statement when i get more internet time.
After moderator review, the thread will remain closed. Thanks to all who participated.
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 20 ·
