The discussion revolves around the concept of a photon traveling in a black hole, specifically examining the implications of length contraction and reference frames in the context of special relativity and general relativity. Participants explore the theoretical underpinnings of these concepts and their implications for understanding black holes and the nature of light.
- Exploratory
- Technical explanation
- Debate/contested
- Conceptual clarification
- Some participants propose that length contraction implies that a photon experiences the universe as having zero length in its direction of travel, potentially leading to the conclusion that a black hole forms around it.
- Others argue that the rest frame of a photon is not an inertial reference frame, and therefore, concepts like length contraction do not apply in the same way as they do for massive objects.
- A later reply questions the validity of applying inertial frame results to a photon, asserting that the reasoning based on length contraction is flawed and does not support the conclusion about black holes.
- Some participants highlight that the energy density and momentum density in the proposed frame would cancel each other out, preventing black hole formation.
- One participant emphasizes that photons do not have a point of view or frame of reference, which leads to contradictions when assuming otherwise.
- Another participant mentions that coordinate-free methods in physics can help avoid conceptual mistakes related to the discussion.
- Several participants reference a FAQ regarding the rest frame of a photon, indicating that this topic has been discussed previously in the community.
- One participant expresses a realization of the complexity of special relativity and suggests focusing on general relativity instead.
Participants generally disagree on the application of length contraction to photons and the implications for black hole formation. Multiple competing views remain, with no consensus reached on the validity of the initial claims regarding photons and black holes.
Participants note that the assumptions regarding reference frames and the application of relativistic effects are critical to the discussion. The limitations of applying concepts derived for massive objects to massless particles like photons are also highlighted.
