Fusion research idea involving more pressure
  • Thread starter Thread starter Xebiqe
The discussion centers on the idea that increasing pressure in fusion reactors, alongside heat, could enhance fusion reactions. The original poster is uncertain about the feasibility of this approach and suggests using inert gas to achieve higher pressure. Responses clarify that the concept likely pertains to Magnetic Confinement Fusion (MCF) reactors, where contact with reactor walls or pressurized gases can cool the plasma, hindering fusion. Participants recommend further reading on fusion reactor mechanics and plasma physics to better understand the challenges involved. Overall, the conversation emphasizes the complexity of achieving the necessary conditions for fusion.
Xebiqe
TL;DR
Could it be that fusion reactors require more pressure?
Greetings!
I have been thinking about fusion reactors and got an idea; what if fusion reactors just require more pressure along with the heat? I'm not active herel so I'm not sure if that is already underway, just thinking about the stars.
- Xebiqe
Welcome to PF.
What type of fusion reactor are you asking about? How do you propose to exert more pressure on the plasma in that configuration?
Thank you.
I mean all types of fusion reactors. I am not sure whether this would work, but I hope that pumping—and pressurize with it—inert gas to the reactor can achieve enough pressure. I hope that this gives you more ideas.
Presumably you mean Magnetic Confinement reactors (Tokamaks and similar), and not Inertial Confinement Fusion (ICF) reactors. Magnetic confinement is used because any contact with the reactor walls (or a pressurized inert gas) cools the plasma, which is counterproductive to achieving the combination of high pressure and high temperature that is required to encourage fusion reactions to occur in the plasma.
It will help you a lot to do some reading about how fusion reactors work, and read at least about the basic plasma physics involved. I'll try to add some links here for further reading for you. I don't know your background in physics (and specifically plasma physics), so I'll try to keep the links to more basic reading. I can recommend more advanced references if you like.
https://en.wikipedia.org/wiki/Nuclear_fusion
https://en.wikipedia.org/wiki/Plasma_(physics)#Plasma_science_and_technology
Likes DEvens and Alex A
Hello, I am designing an X-ray irradiator with MCNP simulation. But I am still in confusion, whether my X-ray housing will be a box or a cylinder. If the box (macrobody identifier of MCNP) is required, I am trying to match the dimension as that of the cylinder, i,e, the height will be that of the cylinder height, and the other two dimensions will be that of the radius of the cylinder (surface 52 and 53). Can anybody please help me define the surfaces? Below is my attached text file. Forgot...
  • · Replies 19 ·
  • · Replies 40 ·
  • · Replies 36 ·
  • Poll Poll
