Screen not illuminating
  • Thread starter Thread starter Martyn Arthur
The user is experiencing an issue with a 16x2 Serial LCD display not illuminating despite previously functioning correctly. They confirmed the wiring connections, including a resistor and power supply, but the screen remains unresponsive. Questions were raised about potential physical damage or incorrect connections that may have led to the malfunction. After some troubleshooting, the user realized they had misconfigured the wiring, leading to the issue. The discussion highlights the importance of double-checking connections in troubleshooting electronic components.
Martyn Arthur
TL;DR
problem checking bacground on this;Compatible with HD44780 1602 16x2 Serial LCD White Character Blue Backlight Display Board 3.3V 5V Compatible with Arduino
Hellol I have pins for this; apologies for subseqquent bold; bold option is not responsive.
Compatible with HD44780 1602 16x2 Serial LCD White Character Blue Backlight Display Board 3.3V 5V , Using Arduino Uno.
15 and 16 connected; 16 to gnd via a 220ohm resistor and 16 to 5v. Mtest meter reads 5v but the screen is not illuminating.
It had previously been functional. Is any other test possible or is i that the module has become faulty?
Thanks
Martyn
PS: mentor adjusted to remove bold text.
It wasn’t bold tagged it was bracketed by [ head ] tags and that’s why it didn't unbold.
Computer science news on Phys.org
Can you link to the display's datasheet?
Did anything happen as part of it starting to not work? Did it get dropped or plugged in wrong or anything else like that? Is it only the backlight that is not working (can you see dim characters without the backlight?)?
i don't know of anything untoward. Originally just the screen functioned with no characters then it just gave up. Am I correct in believing that the wiring previously described is such that the screen should illuminate?
Thanks
Martyn
Ah got the wiring messed up, ok now; apologies for having wasted your time; thanks for your patience!
Martyn
Likes berkeman and Baluncore
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
