Correct statement about a reservoir with an outlet pipe
  • Thread starter Thread starter songoku
The discussion centers on the accuracy of statements regarding water flow from a reservoir with an outlet pipe. Statements (ii) and (iv) are deemed correct, while statement (i) is false because the speed of water exiting the tap is greater than that at the surface. There is confusion about statement (iii), which some believe is correct, as it suggests that increasing gravitational potential energy reduces kinetic energy, impacting water flow. The conversation highlights the importance of atmospheric pressure and the role of height differences in determining water flow, emphasizing that water will stop flowing when pressure balances are reached. Overall, the analysis relies on Bernoulli's equation to clarify these dynamics.
songoku
A reservoir has a constant water level as shown in picture below. For each statement, check whether it is true or false
(i) Velocity of the surface water going down is equal to the velocity of the water flowing through the outlet pipe
(ii) If the reservoir is sealed and the water will still be flowing but eventually it will stop.
(iii) If the outlet pipe moving to higher position, the velocity of the water will decrease
(iv) In the picture, pressure at the surface of the water in reservoir is equal to the pressure at the tap
Bernoulli Equation
Continuity Equation
The answer to this question is statements (ii) and (iv) are correct.
(i) This is FALSE because the speed of water in the tap is greater than speed at the water surface
(ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not?
(iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the pipe will reduce its kinetic energy so the speed of water is slower. Why is this statement not correct?
(iv) This is correct because both pressures are atmospheric pressure.
What is the logic to analyze statements (ii) and (iii)?
Thanks
In (ii) I think "sealed" means that the container has a top cover and is no longer open to atmospheric pressure.
Why do you think (iii) is not correct? If the outlet pipe is moved all the way to the top, there will be no water flow. The water below the outlet does not count. The speed at the outlet depends on the height difference from the outlet to the surface.
But what this information has to do with "the water will still be flowing but eventually it will stop."? I mean even though the container is not sealed, the water will still flow out the tap when it is opened and will stop when the water runs out.
I say statement (iii) is correct but the answer key says it is wrong.
Thanks
When the top is sealed, the air above the surface is initially at atmospheric pressure. Will it remain at atmospheric pressure as the level of the water drops? Why do people punch two holes to pour liquid out of a can? (See picture on the right.)
Does the answer key provide a reasoning for the answer? Who do you think is right, you or the answer key?
songoku said:
Homework Statement: A reservoir has a constant water level as shown in picture below.
If the water level is constant then the surface water is motionless. If it is supposed to be raining, then one needs to say so.
The people making up these questions need to invest in some proof readers.
I interpreted that to mean "The velocity speed at which the surface drops is the same as the velocity speed of the water exiting at the bottom."
Which would mean that no water is exiting at the bottom.
Yes, I chose to disregard the word "constant" in the statement of the problem for it to make sense.
As the volume of the liquid contained inside the tank decreases, the air pressure above its surfaces also decreases.
"The water will still flow out the tap when it is opened and will stop when the water runs out" only in the case that the tank is not deep enough, and the surface never reaches a critical height that equals the value of the external pressure.
If the tank is deep enough for the surface to reach a certain critical height at which the remaining pressure above the surface + [critical height x liquid density x gravity acceleration], which equals the value of the external pressure, a balance of forces is reached, and the flow stops.
The second one is the case represented by the OP diagram (height differential of 12 meters), because the pressure of one natural atmosphere is more or less equivalent to the pressure exerted by a column of 10 meters of water.
Assuming ideal gas and constant temperature, then as the water level drops, the volume increases so the pressure decreases.
kuruman said:
View attachment 366410 Why do people punch two holes to pour liquid out of a can? (See picture on the right.)
Not sure why. I just know they did
No reasoning. I think I am correct.
You mean it is possible for the water to stop flowing when the remaining height of water in the tank is 10 m?
Thanks
Bernoulli's equation P+ρgh+(1/2)ρv2=const is the logic for analyzing statements (ii) i (iii).
The statement (ii):
P1+ρgh1+(1/2)ρv12=P2+ρgh2+(1/2)ρv22
Is it possible to have the next situation P2-P1=ρgh1-ρgh2=ρgh?
The statement (iii):
P1=P2⇒gh1-gh2=(1/2)v22-(1/2)v12
(1/2)v22>>(1/2)ρv12⇒gh1-gh2≈(1/2)v22
The statement (ii):
I would say it is possible. So if this situation happens, then the water won't flow even though the tap is open?
Thanks
Not what I wrote. :smile:
When the level reaches 10 meters, some pressure value may still exist on top of the water, which should be considered.
Besides the weight of the 10-meter column, the tap will be "feeling" that pressure (which is transferred through the incompressible liquid).
Try applying Bernoulli to each side of the tap, please.
Water will stop flowing through that tap when the potential and pressure energies on the left side of the open tap equal the pressure energy on the right side.
What is the expression ##\rho g h## used for?
True.
P2-P1=ρgh holds when v1=v2, and as you said in the original post, v1 can not be equal to v2, except in the case when v1=0 and v2=0.
Likes Herman Trivilino
Because one hole will not allow the free flow of water. You need on hole for water to come out and another hole for the air to go in.
Here is a simple experiment to do at home, if you haven't seen it already.
Stick a straw in a glass of water.
Seal the top end with your thumb.
Lift the straw out of the water straight up.
Why doesn't the water flow out the open bottom?
Remove your thumb from the top end.
Why does the water flow out the bottom now?
I am not sure what you mean by "each side of the tap" but I will take position 1 to be at the 12 m above the tap and position 2 to be at the tap.
Set: ##v_1=0## and ##h_2=0##
$$P_1 + \frac{1}{2} \rho v_{1}^{2}+\rho g h_1=P_2 + \frac{1}{2} \rho v_{2}^{2}+\rho g h_2$$
$$P_1+\rho g h_1=P_{atm}+\frac{1}{2} \rho v_{2}^{2}$$
If ##P_1+\rho g h_1=P_{atm}## then ##v_2## will be zero so the water won't flow eventhough the tap is open.
To consider the pressure that is related to gravitational potential energy
Wow I did this a lot but never thought of the physics behind it. Let me try
When the top end is sealed, the gas pressure at the top is lower than atmospheric pressure because less air molecules giving pressure. The gas pressure at the bottom part is still atmospheric pressure so the total air pressure at the top + the hydrostatic pressure of the water is equal to atmospheric pressure at the bottom end of the straw. This will keep the water to be in equilibrium (not flowing)
When the seal is removed, the gas pressure at top end is back to atmospheric pressure so now there will be pressure difference between the top end and bottom end of the straw. The pressure difference is ##\rho gh## and this net pressure will push the water down.
Is this correct?
Thanks
Not quite that simple. When you put your finger on the top the air pressure is still atmospheric: same number of molecules at the same temperature in the same volume.
But what happens as you lift the straw?
No, the pressure at the surface of the surrounding water is still atmospheric. The pressure at the bottom of the straw will be higher.
It's used to describe the increase in pressure with depth.
When te straw is lifted, water level inside the straw will decrease causing the volume occupied by the air increases ans reducing the gas pressure. Is that correct?
Thanks
Thanks
Yes.
Thank you very much for all the help and explanation kuruman, jbriggs444, Lnewqban, Herman Trivilino, Gavran, haruspex
Likes Herman Trivilino, Gavran and Lnewqban
  • · Replies 31 ·
