Coulomb gauge implies instantaneous radial electric field?
  • Context: Undergrad
  • Thread starter Thread starter Bob44
    Electromagetism
The discussion centers on the implications of the Coulomb gauge in electromagnetism, particularly regarding the instantaneous radial electric field generated by a time-dependent point charge. The scalar potential ##\phi## is governed by Poisson's equation, while the vector potential ##\mathbf{A}## is decomposed into transverse and longitudinal components. The radial electric field ##\mathbf{E}_\parallel## is derived from these potentials, leading to the conclusion that any instantaneous contributions from the longitudinal field are canceled by the transverse field, thus preserving causality in observable electric fields. References to Jackson's 2002 paper provide further insights into gauge transformations and their implications for causality.
  • Understanding of electromagnetic theory, specifically Maxwell's equations.
  • Familiarity with scalar and vector potentials in the context of electromagnetism.
  • Knowledge of the Coulomb gauge and its mathematical implications.
  • Basic grasp of Poisson's equation and its applications in electrostatics.
  • Study Jackson's 2002 paper "From Lorenz to Coulomb and other explicit gauge transformations" for advanced insights into gauge transformations.
  • Explore the derivation and implications of the retarded and advanced potentials in electromagnetism.
  • Investigate the mathematical treatment of instantaneous fields versus retarded fields in electromagnetic theory.
  • Examine the role of charge conservation in maintaining causality within electromagnetic fields.
Physicists, electrical engineers, and students of electromagnetism seeking a deeper understanding of gauge theories, causality in electric fields, and the mathematical framework underpinning electromagnetic potentials.
Bob44
Scalar and vector potentials in Coulomb gauge
Assume Coulomb gauge so that
$$\nabla \cdot \mathbf{A}=0.\tag{1}$$
The scalar potential ##\phi## is described by Poisson's equation
$$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$
which has the instantaneous general solution given by
$$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$
In Coulomb gauge the vector potential ##\mathbf{A}## is given by
$$\nabla^2\mathbf{A}-\frac{1}{c^2}\frac{\partial^2\mathbf{A}}{\partial t^2}=-\mu_0\mathbf{J}+\frac{1}{c^2}\nabla\frac{\partial\phi}{\partial t}.\tag{4}$$
We decompose the vector potential ##\mathbf{A}## into its transverse and longitudinal components
$$\mathbf{A}=\mathbf{A}_\perp+\mathbf{A}_\parallel.\tag{5}$$
We define the transverse current density ##\mathbf{J}_\perp## by subtracting off the longitudinal component ##\nabla \partial \phi/\partial t## from the total current density ##\mathbf{J}## to obtain
$$\mathbf{J}_\perp=\mathbf{J}-\varepsilon_0 \nabla \frac{\partial \phi}{\partial t}.\tag{6}$$
Therefore the transverse component of the vector potential ##\mathbf{A}_\perp## obeys the wave equation
$$\nabla^2\mathbf{A}_\perp-\frac{1}{c^2}\frac{\partial^2\mathbf{A}_\perp}{\partial t^2}=-\mu_0\mathbf{J}_\perp\tag{7}$$
which has the retarded general solution
$$\mathbf{A}_\perp=\frac{\mu_0}{4\pi}\int \frac{\mathbf{J}_\perp(\mathbf{r}',t_r)}{|\mathbf{r}-\mathbf{r}'|}d^3r'\tag{8}$$
where
$$t_r=t-\frac{\mathbf{r}-\mathbf{r}'}{c}.\tag{9}$$
The longitudinal component of the vector potential ##\mathbf{A}_\parallel## obeys the Poisson equation
$$\nabla^2 \mathbf{A}_\parallel=-\frac{1}{c^2} \nabla \frac{\partial \phi}{\partial t}\tag{10}$$
$$\mathbf{A}_\parallel=\frac{1}{4\pi c^2}\int \frac{\nabla'(\partial\phi/\partial t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{11}$$
Point charge at the origin connected to a wire
Let us consider a time-dependent point charge ##q(t)## located at the origin, which is connected to a wire that carries current to or from the charge.
At any point from the origin the radial electric field ##\mathbf{E}_\parallel## is given by
$$\mathbf{E}_\parallel=-\nabla \phi - \frac{\partial \mathbf{A}_\parallel}{\partial t}\tag{12}.$$
We have
\begin{eqnarray}
\phi(\mathbf{r},t)&=&\frac{1}{4\pi\varepsilon_0}\frac{q(t)}{r},\tag{13}\\
-\nabla \phi&=&\frac{1}{4\pi\varepsilon_0}\frac{q(t)}{r^2}\hat{\mathbf{r}},\tag{14}\\
\frac{\partial\phi}{\partial t}(\mathbf{r}',t)&=&\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{r'},\tag{15}\\
\nabla'\frac{\partial \phi}{\partial t}(\mathbf{r}',t)&=&-\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{r'^2}\hat{\mathbf{r}}'.\tag{16}
\end{eqnarray}
Substituting eqn.##(16)## into eqn.##(11)## and using the standard Poisson integral of a radial gradient we obtain
\begin{eqnarray}
\mathbf{A}_\parallel(\mathbf{r},t)&=&\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{c^2 r}\hat{\mathbf{r}},\tag{17}\\
-\frac{\partial \mathbf{A}_\parallel}{\partial t}&=&-\frac{1}{4\pi\varepsilon_0}\frac{\ddot{q}(t)}{c^2 r}\hat{\mathbf{r}}.\tag{18}
\end{eqnarray}
Therefore by substituting eqn.##(14)## and eqn.##(18)## into eqn.##(12)## we find that the radial electric field ##\mathbf{E}_\parallel## is given by
$$\mathbf{E}_\parallel=\frac{1}{4\pi\varepsilon_0}\left(\frac{q(t)}{r^2}-\frac{\ddot{q}(t)}{c^2r}\right)\hat{\mathbf{r}}.\tag{19}$$
Does eqn.##(19)## violate causality since it is an instantaneous expression?
Longitudinal electric field isn't an observable, E is. (Save some electrostatic near field stuff when E is approx ##E_{\parallel}## and complete far field where E is approx ##E_{\perp}##). The question seems a bit ill framed in it's foundations, can a math equation violate causality? Sure. Can physics? No, not when you account for Maxwell + charge conservation + retarded boundary conditions.
Here, when you look at the total field $$E = E_{\perp} + E_{\parallel}$$ any instantaneous bit from the longitudinal electric field is cancelled exactly by the transverse field, so there is nothing causality violating in the observable E.
Bob44 said:
Does eqn.(19) violate causality since it is an instantaneous expression?
As was pointed out by @QuarkyMeson, no, because it is only part of the field.
However, Maxwell’s equations admit causality-reversed solutions. So you can get non-physical solutions. These can be found using advanced potentials.
However, these solutions have a light-speed delay, just to the past instead of the future. So if you find an “instantaneous” transfer of information in the field then you made a mistake.
But how could the retarded transverse field cancel the instantaneous longitudinal field as it takes a finite time for the transverse field to get to the observation point whereas the longitudinal field is there already?
This is shown in Jackson's 2002 paper "From Lorenz to Coulomb and other explicit gauge transformations" (Am J Phys, 35:832-837). Basically, he shows that in the Coulomb gauge $$-\frac{\partial \mathbf A_C}{\partial t} = \frac{1}{4\pi\epsilon_0}\int d^3 x' \left( \frac{[\rho]}{R^2}\mathbf{\hat R} + \frac{[\partial \rho/\partial t']}{Rc}\mathbf{\hat R} - \frac{[\partial \mathbf J/\partial t']}{Rc^2} - \frac{\rho}{R^2} \mathbf{\hat R}\right)$$where the square brackets indicate retarded quantities. The final term is a non-retarded quantity that exactly cancels out the non-retarded quantity from ##-\nabla \Phi_c## leaving only retarded quantities in the total E field.
Of course, as I mentioned before, for every causal retarded solution there is a non-causal advanced solution. But either way there are no instantaneous terms in the fields, just in the potentials.
Thanks for the reference!
https://arxiv.org/abs/physics/0204034
  • · Replies 29 ·
  • · Replies 21 ·
