Downloading videos from TP-Link NVR1108H-W Network Video Recorder
  • Thread starter Thread starter Wrichik Basu
The discussion revolves around setting up a CCTV recording system for a landlord who requires better functionality than the current setup, which only allows downloading of motion-detected footage. The tenant has already installed an indoor camera with recordings saved on a micro SD card, accessible via the TP-Link Tapo app. The landlord wants to install an outdoor camera to monitor a neighbor and needs a system that can store recordings for at least six months and allow for downloading entire footage segments.The proposed solution includes a hardware NVR, specifically the TP-Link NVR1108H-W, paired with a 4 TB HDD and a Wi-Fi camera like the Tapo C510W. The setup aims to enable external access to video downloads via port forwarding. Key concerns include whether this setup will allow downloading longer video segments, as the current system's limitations are inadequate for legal purposes. There are suggestions to check the app settings, as the current limitations may stem from the app's configuration rather than the hardware itself.
Wrichik Basu
Insights Author
Hello everyone! I'm back once again after a brief hiatus.
I am trying to set up a CCTV recording system for a person who is not much into technology and doesn't have much knowledge of things like these. Actually, I am a tenant in his paying guest facility. I have already installed one indoor camera for him (inside our PG), where the recordings are saved locally on a micro SD card. He and I can access those via the TP-Link Tapo app. But it allows us to download only portions where motion has been detected or someone has been identified. I cannot download the entire footage of a time span of my choice.
Now, the landlord wants to install another camera outside our door so that he can keep a look on the next door neighbour. He needs a better system, as he would like to keep recordings of at least six months, and wants to be able to download entire footage of specified time intervals if the need arises (as clipped footages are not accepted in any court) over Wi-Fi. Note that our facility has a different Wi-Fi; he lives in the same building, but upstairs, so he is on a different network. Our network's range doesn't go up to his apartment.
One option is to use a software NVR. But he does not have a PC. So buying a full CPU + HDD + monitor + NVR + camera will probably cross his budget.
I was thinking of the following setup:
  1. Hardware NVR that supports Wi-Fi, e.g. the NVR1108H-W 8 Wi-Fi Channel Network Video Recorder from TP-Link.
  2. A 4 TB HDD for the NVR.
  3. The above NVR has a WAN port, as visible in the images on Amazon and this video made by TP-Link Malaysia. So I can probably configure it to make it accessible from the internet via port forwarding in the router.
  4. A Wi-Fi camera, like the Tapo C510W. Have to change DNS settings to give it a fixed IP so that the NVR can connect to it.
My questions:
  1. Does this setup look good?
  2. I want to be able to download chunks of video from the NVR from external networks. The current CCTV that I have installed inside the PG, Tapo C210, only allows me to download those chunks where motion or faces are detected. But that won't work in my case. Will I be able to download longer videos from this NVR? Anyone has any experience with this NVR?
Computer science news on Phys.org
This sounds like a strange limitation. The name "TP-Link" implies to me a router of a kind. It's almost like the problem is in the setup of the control application for this device. The one you call "Tapo app". Why you'd be limited to only downloading only portions where motion was detected sounds like the camera was only activated during these conditions. When "someone has been identified" sounds weird to me. Is face recognition a part of the package? How does it know who's fit's the criteria for identification?
You should absolutely be able to download everything. I'd check this "Taco app"'s settings...
Just my 2 cents.
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
  • · Replies 16 ·
  • · Replies 116 ·
21K
10K
  • · Replies 22 ·
