Graduate Strong Progenitor Age Bias in Supernova Cosmology
  • Thread starter Thread starter PeterDonis
The recent paper highlights a significant correlation between the luminosity of Type Ia supernovae and the age of their progenitor galaxies, suggesting a systematic bias in supernova cosmology that has been largely uncorrected by existing methods. This bias affects the interpretation of supernova data, leading to discrepancies with cosmic microwave background (CMB) measurements. After adjusting for progenitor age, the supernova data aligns more closely with the cold dark matter model proposed by the Dark Energy Spectroscopic Instrument (DESI). The findings imply a decelerating universe rather than an accelerating one, challenging previous conclusions about dark energy. Overall, this research calls into question the standardization of Type Ia supernovae as reliable distance indicators in cosmology.
TL;DR
A new analysis of Type 1a supernovae to correct for the effects of the age of the progenitor stars suggests that the universe's expansion might not be accelerating
The thread title is the first part of the title of a paper published just today [1]. Here is the abstract:
Supernova (SN) cosmology is based on the key assumption that the luminosity standardization process of Type Ia SNe remains invariant with progenitor age. However, direct and extensive age measurements of SN host galaxies reveal a significant (##5.5 \sigma##⁠⁠) correlation between standardized SN magnitude and progenitor age, which is expected to introduce a serious systematic bias with redshift in SN cosmology. This systematic bias is largely uncorrected by the commonly used mass-step correction, as progenitor age and host galaxy mass evolve very differently with redshift. After correcting for this age bias as a function of redshift, the SN data set aligns more closely with the ##w_0 w_acommonly used mass-step correction, as progenitor age and host galaxy mass evolve very differently with redshift. After correcting for this age bias as a function of redshift, the SN data set aligns more closely with the## cold dark matter (CDM) model recently suggested by the Dark Energy Spectroscopic Instrument (DESI) baryon acoustic oscillations (BAO) project from a combined analysis using only BAO and cosmic microwave background (CMB) data. This result is further supported by an evolution-free test that uses only SNe from young, coeval host galaxies across the full redshift range. When the three cosmological probes (SNe, BAO, and CMB) are combined, we find a significantly stronger (⁠⁠## > 9 \sigma##) tension with the CDM model than that reported in the DESI papers, suggesting a time-varying dark energy equation of state in a currently non-accelerating universe.
[1] https://academic.oup.com/mnras/article/544/1/975/8281988?login=false
  • Wow
Likes Astronuc, hutchphd, Greg Bernhardt and 8 others
Space news on Phys.org
Hello Peter
I'm interested in the issue of the universe's apparent accelerated expansion and would like to learn more.
Could you please bring the abstract down a level or two so that I can understand what it says more readily.
Thank you,
Cerenkov.
Cerenkov said:
Hello Peter
Thank you,
Cerenkov.
They measured supernovas took into account the star system/galaxy (edit) that produced the supernovas, then cross checked with other data from CMBR and BAO. conclusion is it is slowing down not speeding up.
I only know all this because I have reading about it for the last two days and was going to post a thread on it!
Perlmutter won the Nobel for coming to a different conclusion with a lot of the same data from what I have read. He did not standardize the SN the same way Lee did, "standardized SN magnitude and progenitor age."
Disclosure - I used copilot to compare the papers as a lot of the technical stuff is is too difficult.
The refs it gave were. Oxford Academic - Lees paper above
https://arxiv.org/abs/astro-ph/9812473
https://iopscience.iop.org/article/10.1086/306106/fulltext/37558.text.html
https://www.stsci.edu/~ariess/documents/1998.pdf
I hope this acceptable.
We use Type 1a supernovae to estimate distances because how bright they are is well correlated with various other characteristics like their colour. That makes them excellent standard candles for measuring cosmological distances, and hence for estimating the history of expansion.
However, the expansion history implied by these supernovae is different from that derived from CMB measures. This paper suggests that this is because the model of SN 1a brightness is wrong. They say it actually also depends on galaxy age. I haven't quite got to the bottom of why - they have observational evidence, and I think the theoretical reason is that they think the characteristics of the population of white dwarfs (that generate SN 1a explosions) change with galaxy age.
Of course, there were more young galaxies in the early universe because they hadn't had time to become old galaxies. So changing to their model of SN 1a brightness fixes (so they say) a systematic bias in the estimated distance of supernovae. Then the supernova-based distance estimates align better with the CMB based estimates. Furthermore, that has a knock-on effect on the best fit model of the scale factor as a function of time, and hence our estimate of dark energy density as a function of time. That turns out to be a now-decelerating universe.
Likes difalcojr, Spinnor, berkeman and 2 others
Thanks very much for your help pinball1970 and Ibix.
So, let me see if I understand this.
Perlmutter et al worked on the premise that type 1a supernovae could be treated as 'standard candles' and on the back of this assumption, in 1998, they found that the expansion of the universe was speeding up. But if the results of the paper PeterDonis cited hold up, then the standardization of type 1a's is called into doubt.
Which means that certain other things are also called into doubt. Such as the presence of a small but positive cosmological constant and the need to invoke Dark Energy as the mechanism for this accelerated expansion.
Going further, Hawking and Penrose made two basic assumptions in this 1970 paper.
https://royalsocietypublishing.org/doi/10.1098/rspa.1970.0021
First, that the gravitational attraction of the mass of the universe would eventually overcome the expansion, reverse it and then lead to a collapse. Second, that the universe had a negative or null cosmological constant.
I was informed, here in this forum, that since their work on the initial cosmological singularity required a negative or null cosmological constant, the 1998 discovery of a positive value for it invalidated their theorem. They had made an assumption about the universe that was later found to be false. Which meant that the conclusion of their paper, that space-time emerged from an initial singularity, couldn't hold up.
But now, with the advent, of this new finding about type 1a supernovae, is it possible that the cosmological constant will be assigned a null or negative value?
Which would seem to put Hawking and Penrose's singularity theorem back into play. Or not?
Ok, these are very early days and I'm probably guilty of jumping the gun and making mistakes in my speculations. But if anyone who understands these things could please comment on and/or correct my thoughts I'd very much appreciate the help. I've been fascinated by the subject of dark energy, the cosmological constant and the accelerating expansion of the universe for many years now and I'm keen to know and understand more.
Thank you,
Cerenkov.
I marked this thread as "A" level for a reason. You've gotten some good general responses, but be aware that you might not be able to follow the details of what's in this paper if you don't have the background for an "A" level thread.
Where? Please give a link to the specific thread.
Not. Even if it turns out that there is no dark energy and the expansion of the universe is not accelerating, that doesn't mean the universe will recollapse.
You are leaving out one crucial premise of the Hawking-Penrose singularity theorems. In the context of whether the universe will recollapse or not, that premise works out to this: that the universe must be contracting. The theorem tells you that, if the universe is contracting at some instant of time, and the other premises are met (one of which is that there is a zero or negative cosmological constant), then there will be a "Big Crunch" singularity at some point in the universe's future.
But the universe is not contracting now; it's expanding. Even if the expansion is not accelerating, it's still expanding. And the Hawking-Penrose theorem tells you nothing at all about whether it will cease expanding at some point in the future and start contracting.
It seems that I didn't recall things correctly Peter. We did discuss the energy conditions of that paper by Hawking and Penrose. But the key point is found in the abstract.
The theorem applies if the following four physical assumptions are made: (i) Einstein’s equations hold (with zero or negative cosmological constant),
What seems to have happened is that on my own I've concluded that because the universe appears to have a small, but positive cosmological constant, Einstein's equations do not hold. Because this paper was based upon the assumption of a zero or negative cosmological constant it didn't agree with our observations of the universe. So, the paper and its proof were invalid.
I've probably drawn the wrong conclusion... and now await for you to tell if that's so. :nb)
Thank you,
Cerenkov.
Ok, thanks for clarifying and explaining Peter.
Now, just off the top of my head I seem to recall that there's a theorized scenario that's neither accelerated expansion or collapse. Where the universe expands at a slower and slower rate but never actually comes to a halt. Is that right?
If so, does this new finding line up with that scenario?
Thank you,
Cerenkov.
Of course that's wrong. The Einstein Field Equation works just fine with a positive, zero, or negative cosmological constant. All models of our universe in cosmology use the Einstein Field Equation.
At the time it was written, this part did; everyone thought the cosmological constant was zero.
In the late 1990s, when the (apparent) discovery of accelerated expansion was made, then the assumption of a zero or negative cosmological constant was (believed to be) no longer in agreement with observation. However:
Wrong. The paper proves a mathematical theorem based on certain premises. That proof was, is, and remains valid. Mathematical theorems don't become invalid just because their premises don't necessarily hold in our actual universe.
Likes dextercioby
Yes, there are theoretical models that do that. If there is no dark energy (zero cosmological constant), then the only significant component of stress-energy in our universe now and in the future would be ordinary matter, and in any model which is dominated by ordinary matter and has a density less than or equal to the critical density, the expansion will decelerate forever but never quite come to a halt.
If this new finding turns out to be confirmed, yes, it would put scenarios like the ones I described above back into play.
So I've tripped up on my use of terms.
What I should have said was that the proof is mathematically valid, but, in accordance with what Hawking and Penrose wrote, it does not apply to OUR universe. Because the measured value of our universe's cosmological constant appear to be positive and the theorem only applies if it is measured to be negative or zero.
Is that more accurate?
It is, provided that our universe's cosmological constant actually is positive.
Which may not be the case if the new analysis of type 1a supernovae holds up?
Would you please explain what it mean if the Perlmutter's 1998 finding were overturned by this new finding?
What would the implications be for the cosmological constant?
Would it's value need to be revised?
Thank you,
Cerenkov.
Yes, one possible result if this new analysis holds up is that cosmologists would revise their estimate of the value of the cosmological constant--probably to zero (since a negative cosmological constant has even more theoretical issues than a positive one, and I don't think any of the evidence looked at by this analysis, if it holds up, points to a negative cosmological constant, just to it not being positive). That would mean revising our best current model of the universe and its expansion history.
https://science.nasa.gov/dark-energy/
If memory serves Peter, to account for the speeding up of cosmic expansion scientists invoked Dark Energy. But if it is found that Perlmutter et all made the wrong assumptions about the standard candles they were using and the universe isn't accelerating in it's expansion, what then? Is there any need to invoke the place holder of Dark Energy?
Or are there other lines of evidence for the existence of this mysterious stuff/energy/thingy/whatever?
Does this new finding change the Hubble Tension in any way?
Finally, what about the DESI results from earlier this year? As I understand it they seemed to indicate a slowing of cosmic expansion. How does this sit with these new findings about the type 1a's?
Thank you,
Cerenkov.
Basically, yes.
Not from cosmology, no.
If I understand the paper correctly, revising our model of the universe in the way the paper is saying would at the very least greatly reduce the Hubble Tension. Whether it would completely resolve it, I don't know.
I haven't looked into this so I can't say. Maybe another poster in this thread will have more information.
The paper cited in the OP makes heavy use of the DESI 2025 release. Statistical analysis is in section 4.
Rather than go through the thread and like all @Cerenkov ’s questions I’d just thank him/her for having the courage to ask all the questions I also had. You’re obviously way better informed on the subject than me so in addition to bringing the subject a little down from it’s A level I avoided making a fool of myself (which I normally excel at :smile: ).
Why thank you, sbothy. :smile:
But how can I be better informed than you if I've asked all the questions you had? We must be on a par to have thought of the same questions. :wink:
Cerenkov (who is a he, btw)
Yes, Cerenkov-radiation at its most beautiful and up close deadly. Let's not make this into a humbleness competition. Your questions was more informed than mine would have been. Learn to take a compliment! o0)
I humbly accept your compliment.
:wink:
I think the summary in Sabine Hossenfelder's new video is excellent. Many important points made, I have bolded two at the end that interest me the most:
"The Nobel Prize winning observation heavily relied on regularities of [Type 1a] supernovae. They assumed that these stellar explosions always happen in a very similar way no matter what galaxies the supernova's in. Astrophysicists like to refer to them as standard candles. The new paper which just appeared says that, well, that just isn't so.
They looked at the newest collections of data of supernovae from two different experiments. Together, these are more than 3,000. This is much more data than Perlmutter, Schmidt and Reese had in the 1990s when they did their analysis. Back then, they had fewer than 100.
The authors of the new paper took the data apart into groups by two different criteria. The first is how far the light traveled from the galaxy to us. This is the same as the Nobel Prize winners did. The further the supernova, the dimmer it appears. And since the universe expands, the wavelength of the light gets stretched as it travels. This is called the red shift. It's the relation between the dimming and the red shift that tells us how the universe expands.
The new thing is that they also look at how old the galaxy was when the supernova happened. This is a different type of information. Basically, the overall light emission from the entire galaxy has a different spectral shape depending on how old the galaxy is. The kicker is that they find these different properties are correlated. The younger the galaxy, the dimmer the supernovae, independent of the red shift. The problem is now that naturally the further back in time you look, the younger the average galaxy. But since the age is correlated with the supernova properties, this looks exactly like the key evidence for the accelerated expansion of the universe.
Basically, they say that it's wrong to conclude that the expansion of the universe is accelerating. It's just that younger galaxies have on average dimmer supernovae. They don't say why this might be the case. They simply say this is what the data really say. And this isn't one of those maybe results with low statistical significance. This is a whopping 5.5 sigma correlation which they call a serious systematic bias.
They also redo the calculation for the expansion of the universe and find that it currently isn't accelerating. It's actually slightly decelerating though it seems to have accelerated in the past. If it goes on to decelerate then this might mean the universe will actually recolapse. And yes, this finding is neatly compatible with other recent results from DESI and the dark energy survey. They also found that it looks like this somewhat alleviates the Hubble tension, though it doesn't make it go away.
The paper has been peer-reviewed and it's published in a decent journal, but this correlation in the red shift data isn't entirely new and its relevance has been debated among astrophysicists for a couple of years now. Most believe that the effect is there but much smaller than what this group says."
Likes eloheim, pinball1970, javisot and 3 others
Very interesting! How would this conclusion fit to the (almost) flatness of the universe?
And another point, wouldn't this result change the expansion history significantly? The temperature of the plasma at recombination is estimated around 3000 K, which we measure 2.7 K today, which if I see it correctly corresponds to an expansion factor of around 1100 since then. Does this still make sense in case there is no accelerated expansion?
Likes pinball1970
Yes. Figure 9 in the paper in the OP shows the acceleration parameter, ##-\ddot{a}a/\dot{a}^2##, as a function of time under several models.
Yes. The redshift is just the ratio of ##a## now to when the light was emitted, independent of the evolution of ##a##. So no changes of this type can affect that 1100 figure. This would change our estimate of the time since recombination, but I'm not sure how much.
Likes timmdeeg and pinball1970
That "Evolution of the deceleration parameter" figure really caught my eye. The new calculation suggests a universe with accelerating expansion between 2 and 7 bya. Anyone know if this can this be the product of a very weak (constant) cosmological constant that was only able to overwhelm gravitation during that period? Or would it require some type of dynamic dark energy or new physics? (If so it kind of reminds me of the situation with MOND theories being able to explain a lot of galaxy dynamics but still needing a "little bit" of dark matter to be fully consistent with observation.)
That shouldn't be possible with a cosmological constant, because the energy density of matter and radiation can only decrease with expansion, so once the universe has expanded to the point where the cosmological constant dominates, it should keep dominating (i.e., expansion should keep accelerating) forever after that.
I think so, yes. See above.
Note, though, that even something like "dynamic dark energy" wouldn't be expected to act the way it would have to for the accelerated expansion to stop 2 billion years ago; the energy density of the "dynamic dark energy" would have to suddenly decrease sharply, so that it would be much smaller than the matter energy density (radiation energy density is negligible by that time). But first, it's hard to imagine why such a thing would happen, and second, the energy density can't just disappear, it would have to go somewhere, into either matter or radiation, so that there would be an event something like the "reheating" at the end of inflation, though on a smaller scale, and there ought to be obvious observational evidence of that--which there isn't.
In other words, IMO that pattern of accelerated expansion starting 7 bya and then stopping 2 bya is a reason to doubt that the findings of this paper are actually valid.
Likes eloheim and timmdeeg
  • · Replies 16 ·
  • · Replies 34 ·
