Two-layer dielectric, four-capacitor model vs three-capacitor model
  • Thread starter Thread starter mmfiizik
The discussion revolves around a problem involving a square parallel-plate capacitor with two layers of dielectric materials. The original poster describes a scenario where one dielectric layer is moved, leading to a complex arrangement of dielectrics and air, and seeks clarification on how to calculate the capacitance of the system.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • The original poster attempts to analyze the capacitor by splitting the upper plate area into two regions, questioning the validity of treating the entire top slab as a single capacitor. They explore the implications of the dielectric arrangement on capacitance calculations.
  • Some participants question the assumption that the voltage at the bottom of the slab remains constant across its width, suggesting that the configuration should be treated as two series combinations in parallel.
  • Others raise concerns about the implications of charge distribution and electric field uniformity across the capacitor, leading to discussions about whether the dielectric interface can be considered an equipotential surface.
Participants are actively engaging with the problem, exploring different interpretations of the dielectric arrangement and its effects on capacitance. There is a recognition of the complexity involved in the charge distribution and electric fields, with some guidance offered regarding the treatment of the system as two series stacks in parallel.
There are ongoing discussions about the assumptions related to uniform charge density and the behavior of the electric field in the presence of different dielectric materials. The original poster and others are grappling with the implications of moving one of the dielectric layers and how that affects the overall capacitance calculation.
mmfiizik
The lower dielectric is moved out of the arrangement by x in the +ex direction, as shown in
the right-hand image. The value x changes in the value range 0 ≤ x ≤ a. Calculate the total capacitance of the arrangement as a function of x. The boundary effects should be neglected for the calculation. The
surrounding air is assumed to be er,L = 1.
Parallel plate capacitor
I am working on part (f) of a exercise. The setup is a square parallel-plate capacitor with plate side a and separation d. Initially the gap is filled by two layers on top of each other. The upper half has relative permittivity epsilon_{r1} and the lower half has epsilon_{r2}. Then the lower dielectric is moved in the +e_x direction by a distance x. As a result, on the left region of width x, epsilon_{r1} stack becomes over air, while on the right region of width a-x the stack remains epsilon_{r1} over epsilon_{r2}.
My interpretation was to split the upper plate area into two parallel stripes that share the same plate voltage. The left stripe has area A1=ax and is a series combination of epsilon_{r1} and of air (epsilon_{rL} = 1). The right stripe has area A2=a(a−x) and is a series combination of epsilon_{r1} and of epsilon_{r2}. And those two in series are then connected in parallel. However when I calculate capacitance this way, I get different answer.
The official solution instead appears to treat the entire top slab epsilon_{r1} as a single capacitor Cr1 placed in series with (Cr2∥CL), where CrL represents the air part. I struggle to see why the whole top slab can be replaced by one series element when its lower boundary sits partly over air and partly over epsilon_{r2}. In my view the left and right stripes are are regions in parallel (because of same voltage drop?). So I am confused in how should I calculate capacitance. Even if I am not restricted in splitting the material and I end up with configuration like this:
how do I know if it is (C1 || C2) + (C3 || C4) or (C1 + C3) || (C2 + C4) ? By "+" I mean series.
Thanks for any insight.
Solution:
I think you are right. The book solution implicitly assumes that the voltage at the bottom of slab 1 is constant across the width, which is not the case. You have to treat it as two series combinations in parallel.
But since the top slab doesn’t move, top plate's surface-charge density (or charge distribution) shouldn’t change. Then the normal displacement at the plate is the same everywhere (D=σ=const). Because the top layer is the same material ε_r1 across the whole width, the electric field there would also be the same, E1=D/(ε_0*ε_r1), so the drop across the top layer ΔV1=(d/2)E1 should be identical at every lateral position. Wouldn’t that make the dielectric interface with ε_r1, ε_r2 and ε_rL (air) an equipotential surface?
But I don't accept your premise. You assert that the top plate's charge distribution doesn't change, therefore the electric field doesn't change. Why? I say that the electric field changes, depending on what's between the plates, and therefore the charge density will change too. The key point is that to have the same charge density on the top and bottom plates (at corresponding x) the field must satisfy
epsilontEt= epsilonbEb (It's still not letting me insert symbols!)
as well as Etd/2 + Ebd/2 = deltaV
Therefore Et, and the potential at d/2, will vary depending on whether the bottom is filled with slab 2 or air at that point.
I don’t think that’s correct – there will be discontinuities in charge-densities and field-strengths as you move left to right. To add what @mjc123 said, I think the system should be visualised like this:
Thank you all for explanations. I tried to prove this to myself by contradiction, but it might be an oversimplification.
If we assume that there is uniform charge density on both plates, it would mean that at every point out of that plate displacement field ##\text{D}## would be the same. Then voltage drop across capacitor left part would be:
$$\Delta V=U_{0}=\frac{Dd}{2\varepsilon_{0}\varepsilon_{r,1}}+\frac{Dd}{2\varepsilon_{0}\varepsilon_{r,L}}$$
And for the right part:
$$\Delta V=U_{0}=\frac{Dd}{2\varepsilon_{0}\varepsilon_{r,1}}+\frac{Dd}{2\varepsilon_{0}\varepsilon_{r,2}}$$
But since ##U_{0}## is fixed by the voltage source, and ##\varepsilon_{r,L}\neq \varepsilon_{r,2}## (they were equal in the first part of the task), ##\text{D}## cannot be the same for right and left capacitor sides. Then charges on the metal plate have to redistribute so that ##D_{right}\neq D_{left}##. But then voltage drop in the top slab is not the same anymore:
$$\Delta {V_{1,right}}=\frac{D_{right}d}{2\varepsilon_{0}\varepsilon_{r,1}}$$
$$\Delta {V_{1,left}}=\frac{D_{left}d}{2\varepsilon_{0}\varepsilon_{r,1}}$$
Therefore the internal interface is not equipotential. So my premise was indeed incorrect and we have two series stacks in parallel.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 17 ·
