PeterDonis
Mentor
- 49,627
- 25,744
Not just not very clear, but apparently confused about what you are trying to talk about. See below.cianfa72 said:maybe I wasn't very clear in post #22.
Yes. Which means that the key point you gave in post #22, about the solution being a first-order differential equation and therefore unique, does not apply to the general case. It only applies to the particular case of parallel transport along a geodesic.cianfa72 said:In the general case (not geodesic curve) for both parallel and FW transport we need to know the curve and the vectors involved in the transport only at the point P from which the transport is carried out.
So why did you even bother mentioning the first-order differential equation solution property, if you were interested in the general case? That property doesn't even hold for parallel transport in the general case, let alone FW transport.
In other words, based on what you're saying now, your post #22, and the entire subthread based on it, was wasting both your and my time.
