Is mathematics invented or discovered?
  • Thread starter Thread starter Meden Agan
The debate on whether mathematics is invented or discovered centers around two perspectives: the subjective construction of mathematical symbols and axioms versus the objective truths that emerge from established frameworks. Key distinctions are made between syntax, semantics, and application, highlighting that while foundational choices (like those in non-Euclidean geometry) represent invention, the truths derived from these frameworks (such as Pythagoras' theorem) are discoveries. The interplay between invention and discovery is further illustrated through examples like computability and the Peano axioms, emphasizing that mathematical creativity lies in the formulation of concepts while rigor is applied in proving them. Ultimately, the discussion suggests a nuanced view where mathematics may exist in a category of its own, potentially termed as "incovered" or "disvented."
  • Understanding of mathematical philosophy and its historical context
  • Familiarity with foundational concepts in geometry, such as Euclidean and non-Euclidean geometries
  • Knowledge of formal logic, particularly first-order logic and completeness theorems
  • Basic grasp of computability theory, including Turing machines and recursive functions
  • Explore the implications of the first-order completeness theorem in mathematical logic
  • Investigate the principles of non-Euclidean geometry and its applications
  • Study the foundations of computability theory and its various definitions
  • Examine the philosophical implications of mathematical Platonism and its critiques
Philosophers of mathematics, mathematicians, educators, and anyone interested in the foundational questions surrounding the nature of mathematical truth and creativity.
Meden Agan
The question ‘is mathematics invented or discovered?’ is a much-debated issue in the philosophy of mathematics. It is a classic. I would like to know what you think about it.
Below is my view.
IMO, the question ‘is mathematics invented or discovered?’ pits two equally plausible intuitions against each other. On the one hand, mathematicians choose symbols, definitions and axioms; on the other, once the rules are set, they encounter facts that cannot be changed at will. To bring some order to this, it is useful to distinguish between three levels: syntax (the signs and rules of deduction), semantics (the abstract structures to which those signs refer) and application (the relationship with the physical world). “Inventing” mainly concerns the first level; “discovering” concerns the second; effectiveness in science concerns the third.
On the discovery side, mathematics shows objectivity and necessity. Once Euclidean geometry has been established, Pythagoras' theorem does not depend on the taste of those who prove it. Fermat's Last Theorem didn't become true because Wiles proved it: the proof only revealed a truth already implied by the axioms of arithmetic and set theory used in the proof. The historical convergence of distant cultures on concepts such as natural numbers, divisibility, or symmetry suggests that there are robust structures that our cognitive activity encounters rather than creates.
On the invention side, however, foundations matter. Non-Euclidean geometry arises from modifying an axiom; topology arises from introducing a new notion of neighborhood; functional analysis invents spaces and norms; category theory reorganizes mathematical objects in terms of arrows and composition. These choices open up entire continents of otherwise inaccessible results. Furthermore, some statements are independent of the most commonly used axioms: the continuum hypothesis cannot be proven or disproven starting from Zermelo–Fraenkel–Choice (ZFC); the same is true for many statements about large cardinals. Here, the discipline shows pluralism: there are several coherent “mathematical worlds”, each with its own truths. This is strong evidence in favor of the constitutive role of invention in establishing the framework within which we then reason.
A rigorous way to bring the two approaches together can be as follows. Mathematics studies possible structures. We invent formal languages and choose axioms that isolate a class of structures; within that class, truths are no longer invented, they are discovered. Logic makes this transition precise: “provable” means obtainable syntactically from axioms and rules; “true in a model” means satisfied by a structure that interprets those symbols. The first-order completeness theorem guarantees that what is true in all models of an axiomatic system is also provable, and vice versa. At the same time, the incompleteness theorems say that, for sufficiently rich systems, there are arithmetic truths that cannot be proven within the system: a sign that discovery is not exhausted in a single formal framework and that sometimes axiomatic extensions guided by internal mathematical criteria (fertility, consistency, explanatory power) are needed.
Concrete examples clarify the intertwining. Non-Euclidean geometries are ‘invented’ by modifying the parallel postulate; but once the axioms are chosen, the theorems describing triangles on surfaces with positive or negative curvature are ‘discovered’ and do not depend on arbitrariness. The notion of computability has been introduced with different definitions (Turing machines, recursive functions, lambda calculus), but they all converge on the same class of computable functions: this convergence is an indication that the concept understood is not a pure artefact, but rather a stable aspect of the notion of effective computation. The arithmetic of natural numbers is often seen as particularly realistic: in second-order logic, Peano axioms characterize natural numbers “up to isomorphism”, i.e. they describe an essentially unique structure; in first-order logic, however, non-standard models appear, reminding us that the result also depends on the logical framework adopted.
The question remains as to why mathematics works so well in science. A non-mystical answer is that the physical world has relational structures that can be homomorphically represented by mathematical structures. We do not “discover” mathematics by looking at nature, nor do we “invent” it at random: we select, from among many possible theories, those that capture observable regularities with the maximum ratio of predictive power to simplicity. When the choice is successful, mathematics is applicable because there is a structural correspondence between the model and the phenomenon. Here, too, the invention lies in proposing the model; the discovery lies in drawing the necessary conclusions that are then empirically verified.
This perspective also explains the authority of rigor without falling into metaphysical dogmatism. Rigor is the discipline of the second step: once the framework has been invented, it is proven. Mathematical creativity, on the other hand, lives in the first step: defining concepts, conjecturing axioms, changing points of view. The objectivity of the conclusions doesn't deny the historicity of the premises; the historicity of the premises doesn't diminish the necessity of the conclusions. In central and stable cases (elementary arithmetic, real analysis), the various approaches converge, and the sense of “discovery” is strong; at the exploratory margins (foundations, advanced set theory), the weight of inventive choices and pluralism grows.
Let me know.
I am, and many mathematicians are, too, a Platonist. It is discovered. I even go as far as thinking that great compositions or paintings are discovered, or better: uncovered. However, it is sometimes hard to maintain this point of view when I see which constructions mathematicians "find" to prove theorems.
My favorite example is a circle. There is no such thing as a circle in real life. Nevertheless, we all know what is meant and can well calculate with it. Mankind may have invented the wheel, but not the circle. In the end, this is a purely philosophical question.
Why do we assume that one of the concepts of invention and discovery must apply to mathematics? Perhaps it's neither. Perhaps mathematics has its own category: either incovered or disvented.
  • Haha
Math comes with rules that help it stay in a lane. I think it could be a useful tool to help, but it is mistreated by using it exclusively. Modern science does not even have the language to explain "why" nature does whatever it does.
I came away from physics with years of headaches, because a physics degree is 100% math. This is great for rote memory dependent thinkers that can't see a mechanism of causality and prefer the procedural memorized math approach that describes "what it does." I can prove that angular momentum is a convenient math analogy that describes a gyro, but the real cause of the effect is perpendicular accelerations that have NOTHING to do with spinning but the rate that it creates.
This has been my 25-year secret, because it proves math can lie to you and hide a real "cause" from you. My explanation is causal, and they just can't see it, because it's not a math "procedure" that comes with mnemonic devices, the right-hand rule and the conservation "law." A law is not an understanding.
"The wheels on the bus go round and round." This song describes everything you see a bus do EXACTLY like math does, but it's not an understanding. I think causality is too messy for the crowd, and that's the success of math. Rote memory thinkers can point their sticks at the shadows on the wall, and they all agree with each other, yet none of them know how to turn around and look at reality. Math does not dictate reality.
  • Skeptical
I disagree. You can do physics without mathematics, I don't mean University physics, research level but you can investigate it like Faraday did say.
You can split light using a prism, see a straight stick bend in water, draw the position of the stars, sun and moon, perhaps make a stone circle to map them? See what happens to a photographic plate when exposed to certain rocks. Some qualitative things.
Mathematics describes physics very well but I would not describe physics that way.
I am not a mathematician so I am curious as to what mathematics is and what people who study it think it is.
Fresh42 once said, "Mathematics is philosophy," that surprised me.
To say that now in the 2020s, surprised me.
But the rules aren't necessarily hard and fast. Back in the Middle Ages, the concept of negative numbers was not recognized. Once they were discovered or invented (your choice here), the rules changed. Many years later, the concept of the numbers beyond the reals arose, so the rules changed again to accommodate complex numbers. Even though complex numbers have an imaginary component, they are used in several fields, most notably in understanding how electrical circuits work.
Well, hardly. Certainly the language of much of physics is mathematics, but this language is used to explain physical concepts. There is a lot of mathematics that is completely unrelated to physics, and much of physics has little to do with mathematics. Perhaps your physics degree was "100% math," but I doubt that this is the case for physics degrees from other institutions than the one you attended.
Do you have any examples to back up your extraordinary claim here?
Your two examples here are pretty weak. For the first, he right-hand rule is merely an agreed-upon convention. It is hardly a law. For the second, there is no "conservation law." There are laws of conservation of momentum and of energy. These laws are valid because they are backed up by centuries of experiments.
Correct. "Why" questions are for philosophy. Science is silent on why things happen; it is about what and how.
Also correct!
We invented math to describe what we see.
I do have concrete proof that math can perfectly describe what you see AND totally hide the actual cause of the effect, but it will probably get deleted from this site, because this site is NOT for new things, so this discussion may be ruined by this. My youtube channel is jnhrtmn, and the latest video explains it. It even has math that describes the actual accelerations, and it does not need a right-hand rule before it works. There is an acceleration vector field shaped like a cylindrical hoof that you've never seen, because the "peers" were taught angular momentum first. I will be surprised if you can even see it. Most are silent and never speak to me again.
No. All of physics is 100% math, regardless of where you learn it. I want a mechanism of cause, and they call it, "the intuitive explanation," but that comes after the math, so that explanation may have no reality at all. The variables in gravity math likely have nothing to do with what causes gravity. In college I asked, "How is light speed constant to the observer and there is still redshift?" He wrote the Lorenz transform on the board thinking that he answered my question. I wanted a mechanism of cause, and he gave me a number between 0 and 1. That transform CHANGES numbers that you actually measured to adjust length, mass, and time. This creates a new reality ON YOUR PAPER where you begin to think time is relative from what's on the paper. None of this is actually seen, and the NON-transformed reality does NOT just disappear. It's still there, and there is no alternative effort to 100% math on your paper.
I could go on, but they may delete this anyway.
  • Skeptical
Your accusation that we only do physics and maths by rote memorisation doesn't hold up against those of us who can figure stuff out for ourselves.
Perhaps you struggle with mathematics and the only way you can learn it is through rote memorisation. That doesn't apply to everyone. Some of us are cleverer than that!
  • Love
BS.
How about this? The wavelength increases, thereby shifting the color toward the red end of the visible spectrum, while the speed of light remains unchanged. No Lorentz (note spelling) transformation needed, as far as I can see.
Right, and it's there in the rules for this site -- https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/ -- the rules that you agreed to when you signed up.
From the rules...
We wish to discuss mainstream science. That means only topics that can be found in textbooks or that have been published in reputable journals.
I don't think I necessarily disagree, but with that it is a bit strange that when something in the natural world is combined in a new interesting way we call it invention implying it has arise from human inspiration, but when human inspiration define some new mathematical object (i.e. a set of consistent rules) that doesn't really can be found in nature, then it is discovered.
Everyone know how extremely powerful math is for modelling the natural world, so if we go with math being uncovered then it must imply that math already exists as a part of the natural world, hence when a new mathematical structure is uncovered it seems it will be a new interesting combination of something already existing in the natural world, hence it is also an invention. Or what?
I'd say that math is formal description of relationships. The natural world is full of relationships. So it's not surprising that math is useful in describing the natural world.
As they should, there's enough nonsense everywhere around us, we don't need another one here.
Tell me you've never learnt physics without telling me so. What you say is nonsense even at the high-school level. You can't do physics that way (i.e. by memorizing things that "peer" say) on the very basic level! Everyone who know physics knows that, including all of my high-school students. Heck, even elementary school students that tried to achieve something in physics olympiad know that! That's why I love physics! It requires thinking, not memorising! You're here to troll us.
To give an analogy: @jnhrtmn imagine you're sitting with someone and having the time of your life. And then someone calls you and tries to convince you that the person you're with is not alive, or even didn't exist in the first place. You'd get mad. This is the kind of 'mad' I get when I read things like what you said in your posts. It's not only false, reality is the exact opposite of what you say! My 13 year old students know that!
What was the context? I would say that mathematics is definitely not philosophy (in fact I may go far enough to say that it is the oposite of it).
Sorry I cant remember that. It could have been a similar "what is mathematics?" type thread but it may have been edging towards philosophy which is not allowed. If Fresh was a mentor then he may have closed it.
Guessing he was referring to the logic, analysis side? A lot of those prominent philosophers overlapped with Mathematics.
Guessing though.
What mankind invented was the axle.
As fresh points out, there are plenty of circles in the natural world - and even things that roll. But nature never invented the wheel because it is predicated on the axle. Nature can't have two independent parts rotating in relation to one another in that sense because it never found a way to pass nutrients between them*.
* except one tiny case, which is left up to the reader to divine
Whether mathematics was invented or discovered is itself a philosophical question.
My latest contribution to the homework forum is the idea of using a simple recurrence relation to calculate a probability, instead of summing an infinite geometric series. The sense in which that idea was invented or discovered can be argued ad infinitum.
And most discussions about it happen because people use "invented" and "discovered" with slightly different meanings.
The magic of math is that we can use it to make predictions in many fields.
When you say math hides what's going on in physics, it's true, but not for the reason you think.
Math is used to model what we see, what we measure. There is nothing that says math describes the physical process. This is the reason we test everything. Whenever we find something that the math predicts wrong, we reevaluate our test hardware, our measurements, and finally our theory.
NOVA had an episode The Great Math Mystery that can explain it better:
https://www.pbs.org/wgbh/nova/video/the-great-math-mystery/
It's also available on YouTube.
  • Agree
My example to the "is mathematics invented or discovered?" question is the monster group. This is the largest simple group, with 8x10^53 elements. So if you think mathematics is invented, you would have to agree that when Galois first wrote down the definition of a group, that at that instant the monster group sprang into existence from nothing. To me this is obvious nonsense, and I think it must be that the structure of the monster group existed before there were mathematicians, and we discovered it by studying mathematics.
  • Skeptical
I thought you were going to say that the monster group shows that mathematics is invented!
You could say the same about the wheel. The concept of the wheel "must" have existed before any human thought of it. In fact, the concept of the world of ideals is central to Aristotle's philosophy.
  • · Replies 72 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 66 ·
25K
  • Poll Poll
  • · Replies 137 ·
28K
  • · Replies 54 ·
