Trivial fiber bundle vs product space
The discussion revolves around the relationship between trivial fiber bundles and product spaces in topology, exploring definitions, properties, and implications in mathematical and physical contexts. Participants analyze the distinctions and similarities between these concepts, particularly in terms of canonical projections and diffeomorphism.
  • Some participants propose that a trivial fiber bundle consists of distinct copies of the fiber space, while a product space involves a single copy of the fiber that is identified across the product.
  • Others question the definitions of trivial bundles, referencing external sources like Wikipedia and Penrose's work to clarify their understanding.
  • One participant distinguishes between a trivial bundle and a globally trivializable bundle, suggesting that the former is a product while the latter is homeomorphic to a product without a canonical homeomorphism.
  • Some argue that a product has a richer structure due to its canonical projections, while others contend that if a bundle is diffeomorphic to a product, it retains the same structure.
  • There is a discussion about the nature of canonical projections, with some asserting that a product has two natural projections, while others dispute the notion of what is considered canonical.
  • Participants express differing views on whether the choice of diffeomorphism affects the canonical nature of the projections in trivial bundles versus product spaces.
Participants do not reach a consensus on the definitions and implications of trivial fiber bundles versus product spaces. Multiple competing views remain regarding the nature of canonical projections and the significance of diffeomorphism.
Limitations in definitions and interpretations are evident, with participants referencing various sources and examples that may not align perfectly. The discussion highlights the complexity of the concepts involved and the nuances in terminology.
cianfa72
TL;DR
Is the trivial fiber bundle of topological spaces the same as the product space ?
I've a doubt about the following: take the trivial fiber bundle of the base space ##B## and the fiber ##F## vs the product ##B \times F## of topological spaces ##B## and ##F##.
Are they really the same ?
As far as I can tell, in the trivial fiber bundle each fiber in the bundle in a distinct/separated copy of the topological space called "the fiber space" ##F##, whereas in the product ##B \times F## it is the same copy of ##F## that, let me say, enters multiple times in the product (i.e. all the copies of ##F## are actually identified).
Then, it's true that they are canonically identified, but that's another story....
What is the definition of a trivial bundle that you have seen?
https://en.wikipedia.org/wiki/Fiber_bundle#Trivial_bundle
I'd add that my doubt comes from this picture of ##\mathbb E^1 \times \mathbb E^3## in Penrose book:
I believe I got the point. A trivial bundle is different from a global trivializable bundle. The former is a product while the latter is just homeomorphic to a product, however there isn't a canonical/natural homeomorphism.
So ##\mathcal A = \mathbb E^1 \times \mathbb E^3## is a product (i.e. a trivial fiber bundle). It has the two canonical projections on the factors.
Penrose then defines Galilean spacetime ##\mathcal G## as a (trivializable) affine fiber bundle over the base ##\mathbb E^1## and fibers modeled as ##\mathbb E^3##. Here there is only the projection on the base space defined by the structure. Since there isn't the other canonical projection of the product, there is no natural way to identify points on the fibers, i.e. absolute time but not absolute space.
See also Aristotelian-vs-galilean-relativity-in-terms-of-bundles
I don't think this has anything to do with mathematics. A tribual bundle is a trivial bundle whether it is given as a product or it is diffeomerphic to a product. A spesific realization as a product may be important to physics, but that is a different question.
martinbn said:
I don't think this has anything to do with mathematics. A trivial bundle is a trivial bundle whether it is given as a product or it is diffeomerphic to a product.
Ok so according to you, from a mathematical viewpoint, there is no difference between a trivial vs. (globally) trivializable fiber bundle.
I'd say a product has got a richer structure than a trivial bundle consisting of both canonical/natural projections (to the first and to the second factor). In some sense, once the trivial bundle is defined from the product, then one of the two canonical projections is essentially "forgotten".
I don't understand your point. If it is diffeomerphic to a product you can tranfer any property of the product to it. It has the exact same structure.
Yes however, even if diffeomorphic to a product, there is no canonical/natural diffeomorphism. That's the difference with a product that has canonical projections on the factors.
What is canonical about a product? A product ##A\times B## can be written as a product in many ways, say as ##A\times f(B)## for any diffeomorphism ##f## of ##B##. Just because you start with a chosen one it doesn't make it canonical.
Yes. Nevertheless do you agree that a product has got two canonical/natural projections ? A globally trivializable fiber bundle has only one "built in" projection (the projection on base space).
No, I don't agree because there is nothing canonical about it. If ##X=A\times B## and ##X=A\times B'##, which one is the canonical?
So I believe what I call trivial fiber bundle is what for instance Lee - Introduction to smooth manifolds calls product fiber bundle ##A \times B##.
A trivial (or trivializable) fiber bundle ##(E, A,\pi, F)## is only diffeomorphic to ##A \times F## in such a way that ##\pi## agrees with the projection on the first factor.
Yes, but what is the difference? You say that one is canonical and the other not, but in what sense. If you have that ##A\times B## is diffeomorphic to ##A\times F##, which one is the canonical?
Maybe I can't explain my point. If I give you explicitly ##A \times B## this naturally includes the projections on the factors. It is true that ##A \times B## is diffeomerphic to ##A \times F## through the diffeomorphism ##\phi##, however one is making an arbitrary choice by picking ##\phi##.
Yes, but you giving me ##A \times B## involves a choice and is not canonical. It is the same if I gave you explicitely a vector space with a basis, or a manifold and some coordiantes.
Sorry, I can't understand. If I give you explicitly ##A \times B##, I'm giving you a product that can be treated as a (product) fiber bundle in which the bundle projection is the projection on the first factor.
What is the implied choice you are talking about giving you ##A \times B## ?
I also don't understand what you mean by "I give you a product" and how it is different from "I give you something that is diffeomeorphic to a product". Say you give me ##\mathbb R^1\times \mathbb R^1##, how is that different than giving me ##\mathbb R^2##.
By definition ##\mathbb R^2## as set is ##\mathbb R^1 \times \mathbb R^1##. Furthermore as topological space it carries the product topology from the standard topology of ##\mathbb R^1##. Therefore, to me, ##\mathbb R^2## is exactly ##\mathbb R^1 \times \mathbb R^1## with the relevant topology, i.e. it is not just homeomorphic/diffeomorphic to the latter.
When I say "I'm giving you something that is diffeomorphic to a product" I'm not assuming/giving you any specific diffeomorphism.
You see, here you don't see a difference. So what is the difference then? Let me give you another example. Take a torus say given explicitely by an equation or as ##S^1\times S^1##. When you give me a torus which one do you give me, and how are the two different?
Sorry, I'm not that skilled in this area. What I can say is to take a look at Lee - ISM chapter 10 Ex. 10.37.
As far as I can tell, in a) what he calls product fiber bundle is just an example/instance of trivial (or global trivializable) fiber bundle. In the latter any homeomorphism such that the bundle projection agrees with the projection on the first factor is valid/admissible.
lavinia said:
The definition of any fiber bundle includes a choice of a projection mapping. Trivial fiber bundles are not special.
Yes, but for the case of product bundle the projection mapping is canonically/naturally given by the structure of the product (it is one of the two projections on factors).
Note that, following JM. Lee - ISM, a product bundle is not the same as a trivial fiber bundle (a product bundle is a special case of trivial fiber bundle).
cianfa72 said:
TL;DR: Is the trivial fiber bundle of topological spaces the same as the product space ?
A choice of a product decomposition of a topological space that is homeomorphic to a Cartesian product AxF naturally supplies a projection mapping. This mapping together with the projection onto the first factor defines a trivial fiber bundle. The definition of a fiber bundle includes a choice of a projection mapping. A and AxF by themselves are technically not a fiber bundle.
You mean, take a topological space ##B## that is homeomorphic to the Cartesian product ##A \times F##. The choice of the homeomorphism ##\varphi## basically defines a product decomposition of ##B##. Now combining ##\varphi## with the projection on the first factor one defines a trivial fiber bundle.
##A \times F## is a product bundle according the definition given in JM. Lee - ISM book. Using the natural projection on the first factor one defines a trivial fiber bundle.
I essentially agree with you @cianfa72. i.e. technically a trivial bundle is a trivializable bundle plus a trivialization. the difference however does not matter for many purposes.
more generally, a complex line bundle is a locally trivializable C- bundle. most of the time the properties we are interested in are not dependent on the choice of local trivialization. however sometimes they are.
e.g. in the study of dynamical systems on Riemann surfaces, one can realize the surface as a quotient of a polygon by identifying opposite edges via translations. the simplest example is a torus realized by identifying opposite edges of a rectangle. this allows one to place a flat metric (with singularities in higher genus) on the surface. this amounts to choosing a specific not everywhere zero one form, hence a specific local trivialization of the cotangent bundle of the Riemann surface (away from the zeroes of the form). see this beautiful exposition by Curt McMullen:
https://people.math.harvard.edu/~ctm/papers/home/text/papers/tsurv/tsurv.pdf
Most of us are not experts in this specialized area of study and normally do not consider specific trivializations. I myself only became aware of the importance of this distinction by reading the McMullen paper, just tonight as it happens.
As far as I can understand, your point is that a trivial bundle includes two pieces of information: a trivializable bundle plus a specific trivialization of it. On the other hand, a trivializable bundle has some (hence infinite) trivialization of it, however no specific trivialization is picked/included.
A product bundle ##A \times F## naturally carries with it two canonical trivializations, namely the projections on the factors.
well yes. I had assumed you meant this to be an F-bundle over A, in which case those two projections give, in my opinion, one trivialization of it as such. but yes, they also allow it to be considered as a trivial A- bundle over F, which can be thought of as a second trivialization. You just have to give a definition of trivialization to decide.
I believe you understand this concept and are ready to move on to more substantive aspects of it, such as the case I mentioned where the choice of trivialization does give an interesting extra bit of structure. In the case of the torus, S^1 x S^1, for example, the two trivializations you mention give two different families of closed geodesics, the usual two foliations of this trivial torus. Its seems there are also other trivializations corresponding to other such families, consisting of translates of other pairs of generators of the first homology group.
What I am used to and maybe this is wrong, a trivial bundle is one for which there exists a global trivialization. But there is no need for a specific trivializaton to say that the bundle is trivial.
In the case of connected compact smooth manifolds trivializations of the tangent bundle are often defined through a set of non-zero vector fields that span the tangent spaces at each point. This displays the tangent bundle as a linear sum of trivial line bundles, the line bundles whose basis vector in each tangent space is the vector field itself. This linear sum is called a Whitney sum. Different sets of non-zero vector fields define different trivializations and can reveal interesting strucure of the manifold. For instance on a torus of revolution the trvialization determined by left and right handed Villarceau circles reveals two coverings of the torus by pairwise linked circles.
More generally, there are other descriptions of trivial bundles as Whitney sums where not all of the factors are trivial and may not all be line bundles. For instance, given any closed surface in R^3 other than a torus, its tangent bundle is not trivial but its Whitney sum with its normal bundle, the bundle of vectors whose fibers are perpendicular to the surface, is trivial. But no trivialization of the Whitney sum is usually given and in fact, the splitting of the bundle into the tangent bundle and the normal bundle leads to much if not all of classical differential geometry of surfaces.
So to riff on what @mathwonk emphasized, different splittings of a trivial vector bundle into Whitney sums of sub vector bundles can reveal profound structure. And in fact splittings of any vector bundle ,trivial or not, into sums of sub vector bundles, can reveal profound structure.
In these cases, there needs to exist a vector bundle isomorphism from the total space E of the vector bundle to a sum A_1⊕A_2⊕... of vector bundles that commutes with the bundle projection map.
It seems indeed this is the usual meaning of trivial, i.e. equivalent to a product, but without a choice of trivialization. I was assuming otherwise, but it was just what seemed plausible to me, not citing any source. I should have remembered my own frequent advice not to disagree about the meaning of words, nor to assume they have a universal meaning, but rather just to ask what definition someone is using. I.e. to me there is no harm in different sources using various definitions for the same word, as long as one says which one is being used at the time. Indeed this is inevitable.
E.g. Spanier, p.92, uses the word trivial for a bundle that is only equivalent to a product. Spivak, on the other hand, uses the word trivial in both senses! I.e. on page 3-12, he calls the product bundle the trivial bundle (more precisely the trivial n- plane bundle over X), and then on page 3-13, he calls any bundle equivalent to the product bundle also trivial.
There seems to one near general agreement, in these sources and also in the even more classical source Steenrod, that the term product bundle does refer to a bundle with a given trivialization. Even in that case, Spanier and Spivak use "product" only for the actual product XxF, and Steenrod uses "product" for a bundle plus an isomorphism with XxF.
I hope these remarks do not remind too much of Humpty Dumpty:"When I use a word,...".
I am also aware now that my favorite math joke, the question: "what do you get when you cross an elephant with a chicken?" has (at least) two answers!
Not following all the arguments that closely but I think I agree with Martin. Once you learn some category theory, products are defined as something satisfying a specific universal property and are unique up to isomorphism. It's fairly easy to construct "different" products that satisfy the dame universal property.
  • · Replies 43 ·
  • · Replies 29 ·
