What should sit beside a physics equation?
samuel_a
Hi all,
I’m working on a physics equation reference and I’m trying to make the sourcing and explanations as reliable as possible.
When you look up a physics equation, what do you most want alongside it: assumptions, units, variable definitions, derivation, worked example, limits of use, or something else?
I’d really value input from people who study, teach, or use this material regularly.
Wildly guessing, thematize the equations according to textbook sections of a target book from which to be used for studying. One may state what each variable represents or the variables could be understood according to what is being studied. Would a published reference handbook do what you want?
Thanks, that makes sense. It is already organised quite heavily by topic, so that is useful confirmation for me. I think the next thing I am still trying to work out is what is most worth showing directly beside each equation rather than just in the wider topic structure.
It sometimes depends on what the equation is. There is at least one equation very often used in chemistry (so not physics, but I am sure physicists will have similar examples) that is nothing else but a rearranged basic equation describing acid dissociation - it is just that the rearranged version is much more convenient to use is practice (Henderson-Hasselbalch equation vs acid dissociation constant definition in case anyone wonders). There, the derivation (or some explanation of what is going on) is a must.
Other example I can think of is a Michaelis–Menten equation - which is basically a trivial modification of a basic kinetics equation. It seemed so obvious to me as an extension of a basic theory I was actually surprised to learn it is treated as a specific case worth of being named. Here, again, it is derivation that matters.
But in both cases basic equations - one for dissociation equilibrium and one for reaction kinetics - were discovered and used without any derivation (many, many years after discovery it was shown they can be derived either from thermodynamics or using statistical mechanics), so I wouldn't think of showing their derivations as something basic (worth of mentioning, definitely).
samuel_a said:
assumptions (yes),
samuel_a said:
units (yes),
samuel_a said:
variable definitions (yes),
samuel_a said:
derivation (no, the reason you have a reference is so you don't have to derive it),
samuel_a said:
worked example (good for a study guide, but not for a reference because it makes the reference too long),
samuel_a said:
limits of use (yes),
samuel_a said:
or something else (alternative names for the equation if there is more than one common name, a citation to a source for the entry and a citation for information about the person(s) it is named after if it is named after a person)
