Can alpha radiation make other materials radioactive?
The discussion revolves around whether alpha radiation can induce radioactivity in materials, specifically in the context of aluminum. Participants explore the claims made by authoritative sources that only neutron radiation can cause this effect, while referencing historical experiments that suggest otherwise.
  • Some participants note that general sources assert only neutron radiation can induce radioactivity, citing examples from the Nuclear Regulatory Commission and the Health Physics Society.
  • One participant references the Joliot-Curie experiment, which demonstrated that aluminum bombarded with alpha particles produces radioactive phosphorus (30P), suggesting that alpha radiation can induce radioactivity.
  • Another participant questions whether the low probability of alpha-induced radioactivity is the reason it is not commonly discussed, suggesting that only a small fraction of aluminum atoms may capture alpha particles.
  • Concerns are raised about the implications of induced radioactivity, with one participant stating that the degree of concern depends on the specifics of the emitted radiation and the resultant isotopes.
  • One participant argues that the statement claiming only neutrons can induce radioactivity is overly broad and does not account for exceptions like alpha-induced radioactivity.
  • Another participant provides statistical context, indicating that the reaction occurs infrequently and that the probability decreases with lower alpha energy, suggesting that while the assertion may hold true in most cases, exceptions exist.
  • Some participants express skepticism about the completeness and accuracy of popular explanations regarding induced radioactivity.
Participants do not reach a consensus. While some agree that neutron radiation is the primary means of inducing radioactivity, others present evidence and reasoning that challenge this view, indicating that alpha radiation can also induce radioactivity under certain conditions.
Participants highlight the limitations of general statements regarding radiation and induced radioactivity, noting that the effectiveness of alpha radiation in causing radioactivity may depend on specific conditions and materials involved.
ErikSwan
Most general sources that describe the basics of ionizing radiation assert that the only type of radiation that can directly make other materials radioactive is neutron radiation (via "neutron activation").
Googling "does radiation make things radioactive?" produces a few examples, for instance, from the Nuclear Regulatory Commission:
Of the five types of ionizing radiation discussed here, neutrons are the only one that can make objects radioactive.
Or from this "Ask the Experts" answer from the Health Physics Society:
For most radiations that people, especially laypeople, encounter, which would include x rays, gamma radiation, beta particles, and alpha particles, the exposure of the people or objects to the radiation does not produce any radioactivity within them.
There is one radiation, well-known but less common than those mentioned above, that is capable of inducing radioactivity in an irradiated person or object; that is neutron radiation. The reason that neutrons are effective in that regard and other radiations are not is because radioactivity is a property of the nucleus of an atom, and the common x, gamma, beta, and alpha radiations interact with the electrons of atoms, but not within the nuclei, whereas neutrons are able to penetrate the electron cloud around an atom and be absorbed by the nucleus, changing the nuclear configuration and, in some cases, making it unstable against radioactive decay. For example, if a person is exposed to significant neutron radiation, one of the most notable radioactive products that we would expect to be produced would be 24Na (sodium-24), produced when stable 23Na captures a neutron. Sodium is a relatively abundant element in the body and is readily activated to the 24Na product. Similarly, many other materials, especially metals, are subject to neutron activation.
However, I am reading The Making of the Atomic Bomb by Richard Rhodes and just came across the description of the experiment (p. 201) which won Irène and Frédéric Joliot-Curie the 1935 Nobel Prize in Chemistry, in which they discovered that aluminum bombarded with alpha particles produced a radioactive isotope of phosphorus (30P):
$$^{27}\text{Al} + \alpha \rightarrow ^{30}\text{P} + \text{n}$$
The 30P is unstable and decays to 30Si via positron emission with a half life of about 3 minutes.
Although a neutron is emitted here (which could conceivably go on to cause neutron activation), from the description it seems like it is the capture of the alpha particle by the aluminum which directly causes the production of the unstable (radioactive) 30P.
This seems to imply that if I had an alpha source and some aluminum foil, the aluminum foil would become somewhat naturally radioactive from exposure to the alpha source because it actually now contains a small amount of radioactive 30P.
Are the assertions made by the NRC and HPS that non-neutron radiation (specifically alpha radiation in this case) cannot induce radioactivity simply wrong? Or is there some subtlety that I'm missing?
Even the Wikipedia article on Induced radioactivity explains how it was discovered by the Joliot-Curies with their alpha particle + aluminum experiment but then goes on to explain that neutron activation is the main form of induced radioactivity, with photodisintegration (via high-energy gamma rays) as a less common form, with no mention at all of alpha-particle induced radioactivity.
So, what am I missing?
Thanks!
I think it's more a case of the 'rule' applying 99% of the time and not bothering to worry everyone about the 1% they'll never encounter.
Aluminum isn't exactly some rare element, though... Is it the case that only a very small fraction of the aluminum atoms will capture an alpha particle, and/or that the positrons emitted from the 30P are very low energy, so the induced radioactivity is negligible?
From my understanding, exposing aluminum to an alpha source will make the aluminum at least slightly radioactive. I'm trying to understand why from a practical standpoint that doesn't seem to be of any concern, so much so that alpha-induced radioactivity is never really mentioned.
That I can't answer. Perhaps only certain alpha sources cause this effect?
"Radioactive" is a very broad term. The degree to which it should be concerning depends upon the details, particularly the type and strength of the the emitted radiation and the chemical and biologic activity of the resultant. The question is sort of like asking "are chemicals dangerous?" The answer is maybe (the devil is in the detail). A positron emitted inside a conductive foil is probably not a big deal but I am no expert.
But the statement that "only" neutrons can induce radioactivity is overly broad.
Popularizations cut some corners, and different ones cut different corners. You are not going to get a consistent and accurate picture by stitching together what you read in different popularizations.
I did some checking, and out of ~300 or so stable nuclei, the number that make acceptable targets for this reaction (alpha in, neutron out) appears to be 3. Which is about 2 more than I would have guessed. There are probably several more, but these are themselves radioactive, so the reaction is as likely to decrease the radiation as increase it.
Furthermore, at 5 MeV (virtually all alphas are at 4-5 MeV) this reaction doesn't occur often - only 1% of the time or less. So this process happens for 1% of the nuclei 1% of the time - so the statement is 99.99% correct in some sense. For a popularization, that's not horrible.
It's also true that this probability falls like a stone with decreasing alpha energy, and alphas lose all their energy in a few mm of air. So if you actually wanted to do this, you would alloy your aluminum with radium or whatever which would make it far, far, far more radioactive than your aluminum daughters.
Finally, "radioactive" is a matter of degree. Look hard enough and you will find it. There is tritium everywhere. There is radon everywhere. Thorium and uranium everywhere. Carbon-14 everywhere. Need I go on?
Googling "does radiation make things radioactive?" produces a few examples, for instance, from the Nuclear Regulatory Commission:Or from this "Ask the Experts" answer from the Health Physics Society:However, I am reading The Making of the Atomic Bomb by Richard Rhodes and just came across the description of the experiment (p. 201) which won Irène and Frédéric Joliot-Curie the 1935 Nobel Prize in Chemistry, in which they discovered that aluminum bombarded with alpha particles produced a radioactive isotope of phosphorus (30P):
Thanks!
The (alpha,n) reactions are the biggest source of background in low background laboratories, and a hot topic of research. The cross section of the reaction is extremely low, and it is challenging to measure. See this conference slides for further details.
I am aware this thread is about 2.5 years old (OP Aug 9, 2023 with last response Sep 28, 2023), but it is a somewhat important topic. Context of the statements by NRC and HPS is important to understand. In the normal course of every day life, one would not expect aluminum foil in contact with an alpha source. The alpha source is important. Two natural sources of alpha particles are heavy metals, those heavier than Bi, e.g,. certain isotopes of Po, At, Rn, Fr, Ra, and actinide elements, which are decay products of U, Np, Pu, which were formed in the beginning of the solar system, and solar and cosmic radiation, which include protons, alpha particles (and other nuclei), which collide with atoms in the atmosphere and induce 'spallation' reactions, e.g., the cited example of 27Al + α -> 30P + n.
Ref http://hyperphysics.phy-astr.gsu.edu/hbase/Nuclear/radser.html
Artificial or man-made sources of alpha particles involve are variety of particle accelerators and cores of nuclear reactors.
The nucleus of an isotope of a given element has a characteristic energy threshold for a photon or charged particle reaction (be absorbed) and induce a nuclear reaction (decay or expulsion of a gamma or other charged particle) from the excited nucleus. If an alpha particle does not have sufficient energy, it is simply deflected (scattered) by the nucleus (as demonstrated by Ernest Rutherford and his scattering of alpha particles in gold foil). All the time a charged particle travels through matter, e.g., air, water, solid, it interacts with the electrons in the atoms with which it interacts and slowly or quickly loses energy (material and density dependent).
Vanadium 50 gave a good example of the significance of alpha particles from the decay of most common alpha emitting radionuclides. Energies greater than 6 MeV generally require an accelerator for practical applications, otherwise particular nuclides. For most practical applications, accelerlators are preferred, since one can simply turn off the accelerator in contrast to an alpha-decay source, which annot be turned off and must be stored in a shielded container when not in use. When in use, appropriate shielding is required for radioactive sources (radionuclides and accelerators).
Some nuclei have alpha energies in the 6 to 7 MeV range.
Ref: https://arxiv.org/pdf/1409.1772
Adding to the previous response, where ORF mentioned the significance of (α,n) reactions, see the ORNL report "(α,n) NUCLEAR DATA SCOPING STUDY".
https://info.ornl.gov/sites/publications/Files/Pub148054.pdf
I have used several types of (α,n) neutron sources in the past during experimental work during my undergraduate and graduate programs in nuclear engineering. The sources where used in a pool system in addition to lead shielding. One must use remote handling, e.g., a long pole in order to protect agaiinst radiation exposure. Use of radionuclides and accelerators requires strict safety protocols within a controlled and restricted environment. Operation requires one to have special training before handling and use of radioactive materials and accelerators. Members of the general public would not have access to radioactive materials and accelerators; access requires training and a license (or authorization). Mishandling of radioactive materials may incur severe civil and criminal penalties, the latter is mishandling is willful or malicious.
Production of radionucllides requires special processing. Nuclides are usually separated (from source and other products) and purified, then placed in a special container according to need. That container is then placed in an appropriate shielding for storage and transport.
That aluminum example is a good reminder that the “only neutrons activate materials” idea is more of a practical rule than a strict one. Sure, alpha particles can trigger reactions in very specific cases, but the conditions and probabilities are so limited that it’s basically irrelevant outside lab setups. That’s why most explanations simplify it. I found a clearer breakdown in alpha induced nuclear reactions explanation
To give you an idea of why α particles are inconsequential to activating materials, in the lab to get signifcant amont of interactions with an accelerator, you would need many µamps of particles for an extended time. I µamps of α has a fluence of about 3x1013 particles/sec., which is equivalent to about the rate that an 860 Curies α source would emit, a very large amount of radioactivity. Additionally, α loses energy extremely fast, limiting their linear range for an interaction to less than 0.1 mm.
Since every emitted α must overcome the coulomb barrier to interact, and since the cross-section* (related to the probability of interaction that an interaction will occur when possible) is usually small, the interactions are greatly reduced. Also, when the Q-Value is negative (+Q-Value, the energy released for an interaction) and the particle energy(CM) is less than this, no reaction is possible.
In the case of the aluminum α- n interaction, the maximum cross-section for the reaction (35x10-27cm2 ) is so small that less than 10-9neutrons would be emitted for every α emitted. You would need to fuse a finely divided aluminum powder with a finely divided high activity α source, even to get that. This would be equivalent to an order of magnitude of a 1 µCi neutron source, which was produced by that 860 Ci α source.
There are neutron sources mixing alpha emitting isotopes like Plutonium and Beryllium, called a PuBe source with about two time more of Pu as Be by mass. these sources can produce up to 107 neutrons per second for a large source.
* cross-section(cm2)= Interactions per second/ particles/sec/cm2
Note: This is a rough estimate. The calculations are based on a fictitious alpha emitter. Real alpha emitters will probably give even a smaller yield.
  • · Replies 24 ·
