Interval Kinematics
  • Thread starter Thread starter neilparker62
The discussion focuses on interval kinematics under constant acceleration, emphasizing the use of key equations: velocity as a function of time, displacement as a function of time, and the auxiliary equation relating velocity squared to displacement. The traditional approach using initial velocity, displacement, and time intervals is validated as efficient and conceptually clear. The distinction between velocity, average velocity, acceleration, and displacement is stressed, with recommendations to define velocity as the slope of position vs. time and acceleration as the slope of velocity vs. time. The average velocity concept is highlighted as more useful for conceptual understanding than for problem-solving, exemplified by a speed trap problem illustrating the difference between instantaneous and average velocity. The discussion also critiques the use of notation, advocating for interval symbols (Δt, Δv, Δs) to avoid confusion with clock time.
  • Constant acceleration differential equation: \(\ddot{x} = \text{const.}\)
  • Kinematic equations for constant acceleration: \(v = v_0 + at\), \(x = x_0 + v_0 t + \frac{1}{2}at^2\)
  • Concept of average velocity as \(\bar{v} = \frac{v_i + v_f}{2}\) under constant acceleration
  • Graphical interpretation of motion: velocity-time graphs and area under the curve
  • Study the derivation and applications of the auxiliary kinematic equation \(2as = v^2 - u^2\)
  • Explore velocity-time graph analysis for constant acceleration and its geometric interpretations
  • Investigate the distinction and proper notation for interval quantities (Δt, Δv, Δs) versus instantaneous values
  • Analyze real-world problems involving average vs. instantaneous velocity, such as speed trap scenarios
Physics educators, students learning classical mechanics, and anyone seeking a deeper conceptual and mathematical understanding of constant acceleration kinematics and interval analysis in motion problems.
neilparker62
Homework Helper
Education Advisor
Insights Author
For interest - comments welcome.
Science news on Phys.org
Here are my comments, since you asked.
This approach is, of course, limited to cases where the acceleration is constant. Under constant acceleration, one has to solve the differential equation ##\ddot x = \text{const.}## and get two equations incorporating the initial conditions, $$\dot x(t)=\dot x(0)+(\text{const.})t \tag{1}$$ $$ x(t)=x(0)+\dot x(0)t+\frac{1}{2}(\text{const.})t^2. \tag{2}$$ I think that "rote memorization" should be minimized, not eliminated. We cannot expect students to start from first principles every time they solve a kinematics problem.
In my opinion, the least number of equations to memorize is the above two plus the auxiliary equation obtained by eliminating parameter ##t##, $$2(\text{const.})[x(t)-x(0)]=[\dot x(t)^2]-[\dot x(0)]^2 \tag{3} $$ I think that it is important to introduce this equation in kinematics because it will later evolve into mechanical energy conservation.
I am trying to understand why your approach is preferable to the traditional approach. Traditionally, I would say:
Part (a): Find the velocity ##u## at the top of the window.
The known quantities are the transit time ##\Delta t=0.1~##s, the transit distance ##\Delta h=1.5~##m and the height of the building ##H=100~##m. I choose the origin at the top of the window and time ##t=0## when the stone is at the origin. Taking "down" as positive, ##x(0)=0## and ##\dot x(0) =u##. Also at ##t=\Delta t=0.1~##s, ##x(t)=1.5~##m and ##\dot x(t)=u##. Equation (2) becomes, $$\begin{align} & x(t)=x(0)+\dot x(0)t+\frac{1}{2}(\text{const.})t^2 \nonumber \\
& \Delta h=u\Delta t+\frac{1}{2}g(\Delta t)^2 \nonumber \\
& \implies u=\frac{2\Delta h-g(\Delta t)^2}{2\Delta t}
=\frac{2\times1.5~\text{m}-9.8~(\text{m/s}^2)\times (0.1~\text{s})^2}{2\times 0.1~\text{s}} = 14.51~\text{m/s}.\nonumber
\end{align}$$Part (b): Find the height of the window.
This part can be answered by using the auxiliary equation as shown in post #1 and will not be repeated here.
So finding ##u## the old fashioned way is just as quick as using the average velocity perspective. The ##\pm## Relationship is obtained directly from Equations (1) and (2) by dividing through by time ##t## which more appropriately should be written as ##\Delta t## to distinguish it from "clock" time ##t##. My point here is if you use ## t ## for an interval, what symbol will you use for clock time to avoid confusion in students' minds? Clock time becomes important in categories such as "Catch up" problems.
Also, if you insist on using intervals, why is the "drop" relationship limited to ##u=0##? Why not use the more general expression and say, $$
\begin{align} & \bar v = \frac{(v+u)}{2}~;~t=\frac{(v-u)}{a}~; ~s=\bar v t \nonumber \\
&\therefore~~s=\frac{(v+u)}{2}\frac{(v-u)}{a}\implies 2as=v^2-u^2 \nonumber
\end{align}$$and then narrow Equation (3) down to ##u=0## if you must?
From my experience, the average velocity concept in constant acceleration problems has limited use in problem-solving but becomes useful in conceptual explanations. A classic example is the speed trap:
The speed limit on a highway is 90 kmh. Two sensors are placed 100 m apart on a straight portion of the highway. When a car passes the first sensor, it triggers a clock and when it passes the second sensor it stops the clock. Software divides the distance (0.1 km) by the measured time interval converted to hours. If the result exceeds "90", a photograph of the license plate is taken and a citation issued.
A speeding motorist notices the trap and starts slowing down but passes the first sensor at 144 kmh. What must his minimum deceleration be (assume it is constant) so that he does not get a ticket?
Most students start solving this problem by assuming that the "safe" exit velocity must be the speed limit of 90 kmh. If you exit at the speed limit, who's to say that you have been speeding, right? Wrong.
They reconsider when they are told that the gadget calculates the average velocity, therefore if the exit velocity is equal to the 90 kmh speed limit, the instantaneous velocity in the 100-meter interval must be always higher than that and the ticket will be issued.
I apologize for saying more than I planned and I stop here.
Intuitive: Treats motion as a deviation from the mean.
Did you mean non-inertial motion?
So, with your ##a=9.8\rm\ m/s^2##,
upward-increments along the Velocity-axis are associated with "downward acceleration".
Interesting presentation.
I never thought of , for constant-acceleration,
$$v_{i} ,\ v_{f} \quad = v_{avg} \mp (a\Delta t)/2 \quad = \frac{\Delta x}{\Delta t} \mp (a\Delta t)/2 $$
In my opinion,
  • "velocity" MUST be defined FIRST as the "slope-of-x-vs-t"
  • "average-velocity" MUST be defined LATER as the "time-weighted-average of velocities"
    (and that ##v_{avg}=(v_f+v_i)/2## is only for constant-acceleration, as @kuruman suggests)
    [My preference is that "velocity" is the first definition students see, otherwise, in my experience, it seems when I ask for "velocity" at certain time [in an accelerated motion, like freefall], I often get (sadly) average-velocity.]
  • "acceleration" MUST be defined as the "slope-of-v-vs-t"
  • "displacement" can be interpreted as the "area-under-v-vs-t"
  • "average-velocity" should also be interpreted as
    "the [steady] constant-velocity needed to complete the same displacement in the same time-interval",
    which means (as you suggest):
    on a v-vs-t-graph, the height of the rectangle with base ##\Delta t## that has the same area as the area under the v-vs-t graph (here, the area of the trapezoid)
To add more "geometry" to the "Geometry of Motion",
it might be good to point out more geometrical information encoded in the trapezoid,
which could help connect to the standard textbook kinematics equations for constant-acceleration.
See below for details.
For your problem,
using your diagrams,
here is your step 1 (with my emphasis on ##(-t/2)##)
here is your step 2 (not to scale)
See my desmos.com/calculator/00069a84c7
Hi @neilparker62, Here are a few additional comments - just in case the presentation will be given again.
______________
Some references to ‘distance’ should be to “displacement”. Similarly for ‘speed’ and ‘velocity’.The distinctions are important.
E.g. in the slide “The Symmetric Equations”:
“s = distance covered during that interval.”
should be
“s = displacement during that interval.”
“The average velocity (s/t) sits exactly halfway between the start and end speeds.”
should be
“The average velocity (s/t) sits exactly halfway between the start and end velocities.”
______________
In the slide entitled ‘The “Drop” Relationship’ you say:
“Since it starts from zero, the average velocity is v/2.
The time taken to reach that velocity is t = v/g.”
The term “that velocity” suggests you are referring to the average velocity, which you are not, So the second sentence should be:
“The time taken to reach the final velocity is t = v/g”
______________
You might want to check your use of significant figures. You have data with precisions of 1 or 2 sig. figs. but give the final answer to 4 sig. figs.
______________
Apologies if I'm being too pedantic!
Thanks very much for your detailed comment - no apologies needed. Yes - for this particular lesson on interval kinematics we should indeed be using ##\Delta t## and probably ##\Delta v## and ##\Delta s## as well. I think the use of this equation is indeed conceptual since one can visualize exactly what is happening rather than just use a formula. A moot point since the formula itself (as pointed out by @robphy) can be derived directly from area under the velocity / time graph so can also be 'visualized' although I think not many students will actually appreciate that. Am in the process of developing lesson(s) which will emphasize the geometric / graphical origins of these equations rather than just presenting and using them. Have a few different derivations of the key equation v^2=u^2+2as. (area under v-t curve, conservation of mechanical energy and average velocity x time).
A confession - if it wasn't obvious - is that such lessons (including the above) are "AI-assisted". I come up with the basic lesson idea (eg u,v formula and drop equation above) and AI implements in Latex code. If asked, it can also include graphics (tikz code) and slide presentation (beamer) both via packages available within Latex. So the 'drop equation' in this case is limited to cases where initial velocity = 0 by design. The 'raw' AI lesson can then be modified based on feedback received as I will do here. Minor changes can be directly implemented by Latex code 'tweaks' but mostly AI simply regenerates from scratch.
______________
should be
should be
______________
______________
______________
Not at all. Will try to implement with emphasis on vector rather than scalar quantities. Thanks very much for the feedback. The 'presentation' hasn't been used yet. Am busy developing a set of lessons on kinematics. I thought I would pick that topic that as a 'testing ground' for rapid AI-assisted lesson development. This particular lesson is something of an "aside" from the main 'tree' which focuses on the standard kinematic equations.
@robphy
Thanks for your kind comment and desmos graph. As mentioned above, I'm working on developing kinematics lessons along the lines you suggest. In addition to the trapezoid area, I also split the area into two triangles leading to the equation s=(u+v)/2 x (u-v)/a.
I also have done some work on showing how the areas work when up is positive and the graph slopes downward with gradient ##-9.8 ms^{-2}##
For the particular lesson on interval kinematics and the "drop" equation, I should probably redo the graph so that u-0 = v-u =g (ie passes through the origin). Will have to somehow distinguish between u=0 and v=u for the drop distance calculation against u=u and v=v for the calculation of u and/or v. And - yes - in this instance the graph only makes sense if "down=positive" since it has a positive gradient. The lesson will need to state that explicitly.
Instead of initial and final, it might be better to use event-labels: at event A, at time ##t_A##, the position is ##x_A##, and the velocity is ##v_A##, and the acceleration is ##a_A##.
Encourage good bookkeeping, especially for multi-stage processes, like your posed problem.
Therein lies the rub. If you intend the students to use the interval kinematic analysis as a tool for answering conceptual type questions, i.e. no numerical calculations, then it's fine. If you want your students to calculate numbers, they will have to memorize one or more equations to use as a starting point. What equations can these be? Nothing different from what can be obtained by using the two solutions of the diff-eq plus the auxiliary equation in post #2. So memorizing and using a formula is not necessarily something to be avoided.
That said, I would encourage you to extend the use of interval kinematics to the use of velocity vs. time plots as a geometric alternative to algebraic manipulation for solving problem. Here are two examples drawn from PF threads.
Problem 1
A car is at a stop light, when the light turns green a truck blows through the intersection at ##V_{\text{Truck}}##, and remains constant. The car begins to accelerate (assume at the exact same time as the truck goes through intersection) with acceleration ##a##.
(a) How far away from its initial point is the car when it passes the truck?
(b) How fast is the car going?
Solution
Draw a Velocity vs. Time diagram for the two vehicles as shown on the right. The car velocity is a sloping straight line while the truck is a straight line parallel to the time axis. The vehicles have traveled the same distance at time ##t_c## when the area of the rectangle is the same as the area of the triangle.
Part (a) $$\begin{align} & V_{\text{Truck}}t_c=\frac{1}{2}at_c^2 \implies t_c=\frac{2V_{\text{Truck}}}{a} \nonumber \\
& \Delta x= V_{\text{Truck}}t_c=\frac{2V_{\text{Truck}}^2}{a}. \nonumber
\end{align}$$
Part (b)
Note that the areas under the triangle and rectangle consist of a common piece plus a yellow right triangle completing the rectangle's area and a red right triangle completing the triangle's area. These triangles are obviously similar and also congruent because their sides parallel to the time axis are equal. Therefore the sides parallel to the velocity axis are also equal. It follows that at time ##t_c## the instantaneous velocity of the car is twice the constant velocity of the truck.
Problem 2 (More complex)
Two balls are dropped from a top of a cliff at a time interval of ##t_0##. The first ball hits the ground and rebounds elastically, essentially reversing its direction instantly without losing speed. It collides with the second ball at height ##h## above the ground. What is the height ##H## of the cliff?
As shown here, the relevant equation obtained from a Speed vs. Time plot is $$\frac{\sqrt{2gH}-\sqrt{2g(H-h)}}{\sqrt{2gH}}=\frac{\frac{1}{2}t_0}{\sqrt{\frac{2H}{g}}}.$$ It needs to be solved for the height of the cliff ##H## in terms of the other quantities.
If you are determined to incorporate interval analysis in your teaching, you might wish to consider asking the students to solve problems both with interval analysis and algebraically. I think this will consolidate their understanding better.
Still working on problem 2 - here is a graph so long but hasn't solved things.
I think I might write that as: $$ \frac{\Delta v}{\Delta t}=\frac{\sqrt{2gH}-\sqrt{2g(H-h)}}{\frac{1}{2}t_0}= \frac{\sqrt{2gH}}{\sqrt{\frac{2H}{g}}}=g$$
You might, but then you need to justify it. The second half of your equation, $$\frac{\sqrt{2gH}}{\sqrt{\frac{2H}{g}}}=g$$is an identity and doesn't contribute anything new. You need to justify the first half, $$\frac{\sqrt{2gH}-\sqrt{2g(H-h)}}{\frac{1}{2}t_0}=g.$$ The numerator is the speed change of the first ball when it reaches height ##h## after it bounces. Why must the denominator be half the delay interval ##t_0## and what does this have to do with the mid-air collision anyway?
Symmetric
neilparker62 said:
Symmetric
Sure, but how does the symmetry relate to the solution? How will you explain this to a student who is trying to understand how to solve the problem using intervals rather than equations? How does ##t_0## figure in all this?
The equation above does use intervals - there's a ##\Delta t## and a ##\Delta v##. I think what it boils down to is to prove that the projectiles collide at time ##T_0+\frac{t_0}{2}## where ##T_0=\sqrt{\frac{2H}{g}}## and ##t_0## is the delay interval. To do this we can note that the bounce equation is just a shifted version of the original and solve $$H-\frac{1}{2}g(t-t_0)^2=H-\frac{1}{2}g(t-2T_0)^2$$. Have done the algebra but for brevity will post a Wolfram link here.
Edit: comes to the same thing but it is probably more intuitive to solve the velocity equation: $$g(t-t_0)=-g(t-2T_0)\implies 2t=2T_0+t_0 \implies t=T_0+\frac{t_0}{2}.$$ If the two balls are at the same height they have the same kinetic energy and therefore their velocities are equal and opposite.
Velocity vs time graphs for ball 1 and ball 2
To more specifically address the questions above we may note:
1) Mechanical energy is conserved for both balls and always totals mgH where H is the drop height.
2) Following from 1) the velocity of both balls originates from "converted" potential energy. Hence velocity at height h above the ground is ##\sqrt{2g(H-h)}##
3) The first ball strikes the ground at time ##T_0## and the second (assuming an uninterrupted trajectory) at time ##T_0+t_0## where t_0 is the delay interval between dropping ball one and ball two. In between the upward bouncing ball meets the other on its downward trajectory at height h above ground. At this point the respective velocities are equal and opposite with magnitude ##\sqrt{2g(H-h)}##.
4) Ball one started its bounce with velocity ##+\sqrt{2gH}## and had velocity ##+\sqrt{2g(H-h)}## when it collided with ball two. Upon collision, ball two had the same velocity in the opposite direction and (had it continued its trajectory uninterrupted) would strike the ground with velocity ##-\sqrt{2gH}##. The change in velocity for ball one's bounce till it collided with ball two is therefore the same as the projected change in ball two's velocity from collision to time of impact with the ground.
5) Dividing the time interval ##t_0## into ##t_1## and ##t_2## (where ##t_1## is the time during which ball1 bounces before collision) we therefore have ##t_1=t_2=\frac{t_0}{2}##. Hence: $$\frac{\Delta v}{\Delta t} =\frac{ \sqrt{2g(H-h)}-\sqrt{2gH}} {\frac{t_0}{2}}=g$$. Unsurprisingly when we solve for h, we obtain: $$h = \sqrt{2gH} \frac{t_0}{2} - \frac{1}{2}g\left(\frac{t_0}{2}\right)^2$$
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 39 ·
12K
  • · Replies 21 ·
  • · Replies 36 ·
12K
