Two balls, dropped with a delay of ##\Delta t##, meet after rebound
The discussion revolves around a physics problem involving two balls dropped from a height, with a delay between their releases. The problem explores the dynamics of their motion, including the effects of gravity and the timing of their rebounds, as they meet at a certain height after being dropped.
  • Mixed
  • Participants explore the equations of motion for both balls, considering the timing of their drops and the symmetry of their trajectories. There are discussions about calculating the time of collision and the implications of the height of the first ball's rebound.
Several participants have offered hints and suggestions for approaching the problem, including focusing on the motion of the first ball and considering the symmetry in the equations of motion. There is an ongoing exploration of different interpretations and methods to analyze the situation, but no consensus has been reached.
Participants note the given height of the first ball's rebound and question the implications of this value on the overall problem. There are also discussions about the assumptions made regarding the timing of the drops and the nature of the motion involved.
  • #31
brotherbobby said:
Hi @erobz, can you check your working that I put below which you did in post #18 above? I think you are off by a factor of 2. I put your workings on the right, with the mistakes in red ink.
Let me copy and paste what I am getting. I mark the final expression for ##u## in orange.
View attachment 339078What's more, I did not understand your reason for keeping the positive (##+##) sign for ##u##. I copy and paste your reason to the right.
Indeed, ##u = t-\sqrt{\frac{2H}{g}}## and since ##t>\sqrt{\frac{2H}{g}}\Rightarrow u>0##. But is that the reason to keep the ##+## sign?
See my reasoning below to the right on dark page.
What I am saying basically is that the second term is less than the first in the expression for ##u##. So keeping the ##-## sign continues to keep ##u>0##.
Many thanks.
Yes, you are correct on both accounts. I goofed on the algebra, and one of the solutions cannot be ruled out by negative time.
So if both solutions are positive for ##u##, must we then take the smallest of the two as the desired solution? ( i.e. ## u = \frac{1}{g}\sqrt{2gH} - \sqrt{\frac{2(H-h)}{g}} ## ) or do we just work with both solutions ##\pm## ( I'm leaning towards the former)?
  • #32
@erobz, you were right. I think I have solved it, though a question lingers. Since it has been sometime that I have posed the problem, let me state things from the beginning to refresh.
Attempt :
Taking ##g = 9.8\:\text{m/s}^2##, we have the equation of motion of the first ball as (see my post #1) shown on the right. Here ##h## is the height where the balls meet, ##t## is the time when they meet (from the start, when the first ball was dropped). The equation of motion of the second ball (see my post #1) is also shown on the right. The question is now to find the height of the cliff H (=?).
In ##(1)##, let us put ##\color{blue}{u = t-\sqrt{\frac{2H}{g}}}\qquad \color{brown}{(3)}##
This, after some algebra, we obtain ##\small{u^2-\sqrt{\frac{8H}{g}}u+\frac{2h}{g}=0\Rightarrow u = \sqrt{\frac{2H}{g}}\pm\sqrt{\frac{2(H-h)}{g}}=\sqrt{\frac{2}{g}}(\sqrt H\pm \sqrt{H-h})}##
Substituting from ##(3)## for ##u=t-\sqrt{\frac{2H}{g}}=\sqrt{\frac{2}{g}}(\sqrt H\pm \sqrt{H-h})\Rightarrow t = \sqrt{\frac{8H}{g}}\pm \sqrt{\frac{2(H-h)}{g}}##.
From equation ##(2)##, we have ##\sqrt{\frac{2(H-h)}{g}}=t-2\Rightarrow \color{blue}{t = \sqrt{\frac{8H}{g}}\pm (t-2)}\qquad \color{brown}{(4)}##
There are two possibilities to ##(4)## as evidenced by the ##\pm## sign.
##1. \;\mathbf{(-)\,\text{sign}}## :
This yields from ##(4)##, ##2t-2 = \sqrt{\frac{8H}{g}}\Rightarrow t= \sqrt{\frac{2H}{g}}+1\Rightarrow t-\sqrt{\frac{2H}{g}}=1\quad(=u)##. Putting this value of ##t## in ##(1)##, we have,
##\small{h = \sqrt{2gH}-\frac{1}{2}g\Rightarrow h+\frac{1}{2}g = \sqrt{2gH}\Rightarrow 55+5=\sqrt{20H}\quad\text{(putting values here)}\Rightarrow 60^2=20H\Rightarrow} \boxed{H = 180\,\text{m}}\quad\large{\color{green}{\checkmark}}##
This agrees with the answer.
##2. \;\mathbf{(+)\,\text{sign}}## :
This yields from ##(4)##, ##t=\sqrt{\frac{8H}{g}}+t-2\Rightarrow \sqrt{\frac{8H}{g}} = 2\Rightarrow H = \frac{4g}{8}= 5\,\text{m}\quad\huge{\color{red}{\times}}##.
Of course this answer is incorrect, as the problem states that the ball collide at ##h = 55\,\text{m}##. But it should mean something that I am not able to figure out.
  • #33
Good job. Thanks for finishing it out zee messy vay!
As for the extraneous solution, I'm not concerned because temporally it makes sense to exclude the positive root solution of ##u##, because the solution corresponding to the negative root ##u## must be the first collision temporally (if there were indeed two).
If it were the other way around and we found the solution corresponding to the positive root (coming after the other solution in time), I would be concerned...
  • #34
Glad the thread remains open. I had a question for @PeroK, if you're here.
In post# 9, you said that
PeroK said:
The symmetry (of free fall - my addition) is inherent in the equations of motion
I am trying to investigate the matter but I am stuck somewhere I want to tell you about. Let me begin simply.
##(1)##. If an object is thrown vertically up, the time of rise = time of fall as well we the initial velocity of projection = final velocity. [I can prove both of these - they are elementary].
##(2)##. From (1) above, we can show that the time to climb to a height ##y## = time to fall from the height ##y## to the ground, even though at the height ##y## the ball has a finite speed. [Contrast with (1) where the speed at the highest point is 0].
##(3)##. Is it also true that for a ball thrown vertically up and which rises to a maximum height ##h##, the time to scale a height ##y## is the same as the time that the ball dropped from the height ##h## will take to fall a distance ##y## down?
[ I cannot show ##(3)## either using symmetry arguments or algebra using the kinematic equations ].
Many thanks.
  • #35
Many thanks.
That can't be the same because the initials speeds are different.
For an elastic ball, the time to fall from height ##h## is the same as the time to bounce back up to height ##h##.
First, we have the same acceleration due to gravity, ##g##. Second, we have the same distance. Third, we have the same final speed in the first case as the initial speed in the second case.
This implies that the initial speed in the first case (speed at height ##h##) is the same as the final speed in the second case (also height ##h##). This can also be seen directly from conservation of mechanical energy. Note that conservation of energy also covers the case of a varying gravitational force/potential.
For constant acceleration, you can use the kinematic equations to show that the time is the same up and down.
  • #36
kuruman said:
One can easily set up the relevant equation by using a speed vs. time graph. Shown below is the speed of the first ball in red and the second ball in blue. The point of intersection C is the collision point at the time when the speeds are equal as required by energy conservation. The velocities are in opposite directions, of course.
The height of the cliff ##H## is the area of triangle OAB. The base of this triangle is the time it takes the first ball to hit the ground ##OB=t_f=\sqrt{\frac{2H}{g}}.## Triangle EAD is similar to OAB. Therefore, $$\frac{(AD)}{(AB)}=\frac{(ED)}{(OB)}\implies \frac{\sqrt{2gH}-\sqrt{2g(H-h)}}{\sqrt{2gH}}=\frac{\frac{1}{2}t_0}{\sqrt{\frac{2H}{g}}}.$$
On edit
Edited to fix the incorrectly applied "area under the curve" equation.
Excellent diagram. Can solve by finding the area under the blue curve between it's x-intercept and point C.
  • #37
Why on Earth would you think that to be true? When throwing upwards, the ball has initially its maximal speed. When dropping, the ball has initially zero speed.
Before using any algebra, use your common sense.
  • #38
I had asked at @A.T. :
``Is it also true that for a ball thrown vertically up and which rises to a maximum height ##h##, the time to scale a height ##y## is the same as the time that the ball dropped from the height ##h## will take to fall a distance ##y## down?"
What I meant was, if the ball rises to a height ##h##, does it take the same time to scale a height ##y## as it does to fall from the height ##y## to the ground on its way down? The answer is yes, due to symmetry of the situation. It is true no matter how fast you throw the ball on its way up.
  • #39
I don't understand your use of ##h## vs. ##y## here.
The time for reaching the maximal height ##h## when thrown upwards, is the same as for falling that same height ##h## from rest. But the times for the intermediate distances ##y<h## traveled in either directions are different.
  • #40
brotherbobby said:
What I meant was, if the ball rises to a height h, does it take the same time to scale a height y as it does to fall from the height y to the ground on its way down? The answer is yes, due to symmetry of the situation. It is true no matter how fast you throw the ball on its way up.
First, let me describe what you are asking more precisely.
You allow ball A at height ##H## to drop from rest. Next to the ball is a vertical rod with a marking at some height ##y## between the ground and height ##H##. The ball takes time ##~T=\sqrt{2H/g}~## to hit the ground with speed ##~v=\sqrt{2gH}.~## You videotape the dropping ball from ##t=0~## to ##~t=T.##
Now you project ball B from the ground up with initial speed ##v=\sqrt{2gH}.~## It will rise to the same height ##H## in the same time ##~T=\sqrt{2H/g}.~## You videotape the rising ball from ##t=0~## to ##~t=T.##
Your question is whether ball A drops from initial height ##H## to ##y## in the same time as ball B rises from ##y## to its maximum height ##H.~## The answer is yes.
The simplest way to see this is by playing the second video backwards and comparing it with the first video. Ball B will be seen dropping and, frame by frame, it will be at the same distance from its starting point as ball A including, of course, the marking at ##y.## So if it takes, say, 132 frames for the two balls to drop to ##y## when the video for B is reversed, it should take the same 132 frames for ball B to rise from ##y## to ##H## when the video is played normally in the forward direction.
On edit
Mathematically, you can argue that since the speed at height ##y## is ##v_y## and at height ##H## it is zero regardless of whether the ball is rising or falling, the average speed is ##\bar v = \dfrac{1}{2}(v_y+0)~##. Therefore, whether rising or falling, it will cover distance ##H-y## in the same time interval $$\Delta t=\frac{H-y}{\frac{1}{2}v_y}=\frac{2(H-y)}{v_y}.$$ This equation says that at the two extremes, when ##y=H,~## the time interval is zero because the ball is already there.
When ##y=0## at which point ##v_y=\sqrt{2gH}##, $$\Delta t=\frac{2(H-0)}{\sqrt{2gH}}=\sqrt{\frac{2H}{g}}=T$$ as expected.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 21 ·
