Zeros of functions analytic in 2 variables
  • Context: Graduate
  • Thread starter Thread starter Paul Colby
6 replies · 3K views
TL;DR
Let, ##f(z_1,z_2)##, be entitre analytic in both ##z_1## and ##z_2##. If ##f(z_1,z_2)=0## has a solution, is it true that ##f## is zero along some curve in ##z_1,z_2##?
This question crops up in solving electromagnetic boundary value problems. For problems with rotational symmetry, if ##f## has a node at ##(\theta,\phi)## then ##(\theta,\phi')=0## for all other ##\phi'##. This (I think) implies that, $$f(\theta,\phi)=F(\theta)G(\phi)$$ which, for the problems I'm considering, isn't going to happen except under very special circumstances.
My thinking is, if a node exists at ##(z_1,z_2)##, then some curve in ##(z_1,z_2)## must exist along which ##f## is zero.
Ah, problem solved. In the form asked, one simply solves ##f(z_1,z_2)=0## for ##z_2## in terms of ##z_1##. The real problem that was troubling me is addressed by realizing real polar coordinates, ##(\theta,\phi)##, are in fact just a single complex coordinate. The functions, ##f##, are really entire functions of a single complex coordinate. The zeros of analytic functions that are not identically zero, are all isolated points.
Reply
mathwonk said:
are z1, z2 complex variables? if so, the zeroes of an analytic function of 2 complex variables are never isolated.
I was slowly tumbling to this fact. ##z_1## and ##z_2## correspond to analytically continued polar coordinate angles. In my problem, each zero corresponds to a new vector in a separable Hilbert space. Non-isolated zeros are problematic. Fortunately, the sphere is conformally mapped to the complex plane using, $$\xi=e^{i\phi}\cot(\theta/2)$$. So looking for isolated zeros makes more sense.
I don't know if the argument for my statement is of interest, but it is nice and fairly short; namely, Riemann showed for analytic functions of one complex variable, if they are bounded in a punctured neighborhood of an isolated point, then they extend analytically also to that point.
Hartogs proved the analogous result for analytic functions of 2 complex variables, without assuming boundedness; i.e. a function of two complex variables which is analytic in a punctured neighborhood of an isolated point, always extends analytically also to that point.
Taking logs gives the desired result: i.e. if f is an analytic function of 2 complex variables, and f is non zero on a punctured neighborhood of an isolated point p, then since such a punctured neighborhood is simply connected, f has an analytic logarithm g = ln(f), on that punctured neighborhood. But then by Hartogs that logarithm g extends analytically to p, so f extends also to p as f = exp(g). Since the exponential function is never zero, f(p) = exp(g(p)) ≠ 0.
Reply
Cool. For an analytic function, ##f##, in two complex variables one may solve ##f(z_1,z_2)=0## for ##z_2## as a function of ##z_1##. Zeros, as you pointed out, are not isolated points. For analytic functions of a single variable, the zeros are isolated if the function is not identically 0.
If the z2- partial derivative of f at p is non -zero, then near p, on f=0, z2 is indeed a single valued function of z1; but if both partials of f are zero at p, then in general z2 is locally near p only a multiple valued function of z1. I.e., in appropriate coordinates, with p = (0,0), there is in general a parametrization t-->t^n = z1(t), and t-->z2(t), of (each branch of) the curve f=0 in a neighborhood of p.
I.e. in appropriate coordinates, a punctured neighborhood of p on the curve f=0 always projects as an n to 1 covering space of a punctured neighborhood of z1=0, but when the partials both vanish at p, we will have n > 1.
E.g. y is a 2-valued function of x on every small nbhd of (0,0) for the curve y^2 - x^3 = 0, (with x, y complex).
https://en.wikipedia.org/wiki/Cusp_(singularity)
