Gerry and Knight solution to single-mode Maxwell equation
  • Context: Graduate
  • Thread starter Thread starter Kekeedme
4 replies · 834 views
Kekeedme
TL;DR
I have two questions concerning treatment of the single-mode solution to Maxwell's equation presented in Gerry and Knight's. Namely, where does the expression for the amplitude of the electric field comes from, and secondly how did they handle the integral over dV in the classical E-M Hamiltonian that contains the V^-1 term, without it blowing up.
In the book, they present the solution to the maxwell equation for a wave propagating in 1-D. My only issue is determining where the specific expression for the amplitude of the electric field comes from. Their solution is:
Even if we use the classical energy in the field and equate it to the single-photon energy (ignoring zero point) as such:
we'd get 𝜔 inside the parentheses not 𝜔^2? Can someone help shed some light please?
Secondly, when we go from:
to:
I understand what they are trying to get, the only thing that trips me up is I don't see how they handled the integral, seeing that you have to integrate over d𝑉/𝑉 because of the coefficient in front (mentioned above in the amplitude ). What am I missing please?
Thank you!
I'll try to answer as best I can.
For the first part, the "missing ω" is effectively hidden inside the definition of q(t). In the quantized theory,
q=\sqrt{\frac{\hbar}{2\omega}}(a+a^\dagger),
so q already contains a factor ##1/\sqrt{\omega}##.
For the second part, it seems to me that the notation is somewhat unfortunate because the same symbol V is used both for the total volume and in ##dV## for the volume element. Then the factor ##1/V## is not problematic because V is the total cavity (quantization) volume, i.e. a constant, not the integration variable. More explicitly, one could write the quantization volume as ##\mathcal V##, so that
\int_{\mathcal V}\frac{dV}{\mathcal V}
\frac{1}{\mathcal V}\int_{\mathcal V} dV
1.
Also, if I'm not mistaken, for the cavity mode
\int_V \sin^2(kz)\,dV = \frac{V}{2},
which exactly cancels the explicit ##1/V## factor in the field normalization.
Reply
Thank you so much for the reply.
So at first, does it mean that we should indeed get this expression by ignoring zero-point energy and equation the classical field energy to that of the single-photon?
For the V portion, that is very helpful, and also very unfortunate that they have this confusion in there. But I think I see what you mean. Thank you so much for this! Sorry for the late reply
This seems amazing! Thank you so much for this resource
Reply
