My questions about QFT and the standard model
  • Context: Graduate
  • Thread starter Thread starter planck999
4 replies · 992 views
planck999
TL;DR
My questions about qft and standart model
First of all, I guess classifying particles as excitations of fields stem from the fact that fields can be decomposed into plane waves which are particles in some sense and since they are infinite we have infinitely many of them. Like, any continious electric field can be decomposed into plane waves, for which those plane waves are em waves which are in turn photons when they behave like particles. In the same wave they said all elementary particles are plane waves of some field. Like electron being a dirac plane wave.
I also learned from schwartz that any fundemental particle is characterized by spin and mass, and it's lagrangian and equations of motion are determined from spin. Gauge freedom stems from the extra degrees of freedom in the tensors we embed them into while there are less freedom for given spin, 2j+1 degrees of freedom namely.
I also understood the non-abelian gauge theories of su2 and su3.
Now my questions are:
how does obtaining form of lagrangian just from the spin work? And why is gauge invariance necessary? I can do the calculations but my intuition is missing. And, how did parity experiment of wu, while it does explain the left handedness, lead to a su2 symmetry and the concept of doublets? I can understand the maths of them very well but I don't get why did that experiment result in the concept of doublets and an su2 symmetry?
Also, I didn't quite understand what the degrees of freedom are. Are they linearly independent components of a field? And about the local symmetries, why did the original inventors promoted global symmetries into local ones? Does every global symmetry which dictates consevration of charge imply a local symmetry too?
Textbooks don't build the intuition very well, they give all tools to calculate but even getting the idea of why particles are excitations of fields was too consuming.
To summarize:
1- Why do we need local symmetries, and do we need one for each global continious symmetry?
2- How did they come up with su2 and su3 symmetries?
3- How is form of a lagrangian determined from the spin of the particle alone?
4- What actually is the degrees of freedom of a given particle?
This is a very long question which covers quite a bit of the QFT machinery. It might be more productive to focus on one specific question.
For example, ultimately why does nature follow ##SU(3)\times SU(2)\times U(1)## symmetry is unknown.
Reply
1. Local and global symmetries are essentially different concepts. Electromagnetism has a local U(1) gauge symmetry that is essential to understand the properties of the e/m field. The other gauge theories are generalization that were found to work well. This is the real justification for their use.
2. By ingenious guesswork. SU(2) is the well-known isospin symmetry, and the U(1) x SU(2) gauge symmetry was found by Glashow, Weinberg and Salam to unify the electromagnetic and the weak interaction. SU(3) is the symmetry for hadrons guessed by Gell-Mann, which ultimately lead to the SU(3) gauge theory called QCD.
3. By writing down the most general Lagrangian with a given symmetry pattern. See Vol. 1 of Weinberg's quantum field theory book.
4. Position, momentum and the vector encoding spin or helicity.
Reply
Just for clarification, the excitations of fields that represent the quanta, which are (confusingly) often referred to as "particle" are not individual plane waves. Although a single quantum can theoretically be parameterised as a plane wave, such a representation would not be normalisable. Therefore, a single quantum (single excitation of a field) typically consist of a spectrum of plane waves in superposition.
This is going to become a bit technical. If something is not clear, please let me know.
All fields in quantum field theory are irreducible representations of the Poincare group, which combine Lorentz invariance (from special relativity) and translation invariance. That basically gives us scalar fields (like the Higgs fields), fermion fields and gauge boson fields. These fields only allow a few specific terms, formed from contractions among them that are Lorentz invariant scalars. Some terms represent kinetic terms and other terms are interaction terms. Lagrangians are formed by adding these terms, sometimes with constant parameters like masses or coupling constants. In a good textbook on quantum field theory (Like Peskin and Schroeder), one can find explanations of how these terms are formed and why there are so few of them.
