Series with rotating phase
  • Level: Graduate
  • Thread starter Thread starter hilbert2
    Series convergence
3 replies · 739 views
Insights Author
TL;DR
About series where the complex phase of the terms rotates around the unit circle.
It's a basic fact that the harmonic series
##\displaystyle\sum_{n=1}^{\infty}\frac{1}{n}##
diverges, while the similar series with alternating sign
##\displaystyle\sum_{n=1}^{\infty}\frac{(-1)^{n-1}}{n}##
converges to the value ##\log 2##.
If I compute partial sums for the series
##\displaystyle\sum_{n=1}^{\infty}\frac{e^{ic(n-1)}}{n}##
where ##c## is a real-valued constant, the real and imaginary parts seem to approach a finite value for any nonzero value of ##c##. The case ##c=\pi## is just the series with alternating sign.
Do these series with rotating phase factor appear in any applications? It seems to be a generalization of the concept whether a series of real-valued terms is alternating or has only terms of same sign.
Mathematics news on Phys.org
It is a Fourier series which has abundant applications. it has relation with delta function.
[EDIT]
Though a bit different from your formula, complex Fourier series for Heaviside step function, H(x)=0 for x<0 H(0)=1/2 H(x)=1 for x>0 in period 2##\pi##, is
$$H(x)=\frac{1}{2}+\frac{1}{\pi}\sum_{k=-\infty\ odd}^{+\infty}\frac{e^{ikx}}{ik}$$
With period ##2\pi## this is a square wave.
$$H'(x)= \frac{1}{\pi}\sum_{k=-\infty\ odd}^{k=\infty}e^{ikx}= \sum_{n=-\infty}^{\infty} [\delta(x-2n\pi )-\delta(x-(2n+1)\pi)]$$
where
$$\delta(x)=\frac{1}{2\pi}\sum_{k=-\infty}^{\infty} e^{ikx}$$
A good point, I didn't think of it as defining a function of ##c##, just as a series that produces a number when summed.
The sum of that rotating phase harmonic series seems to be
##\displaystyle\sum_{n=0}^{\infty}\frac{e^{i(n-1)x}}{n} = e^{-ix}\log (1-e^{ix})##,
which clearly diverges when ##x\rightarrow 0## and has a finite value for ##x>0## no matter how close to zero ##x## is.
Here's a discussion about something that can be interpreted as similar but with accelerating phase rotation: https://math.stackexchange.com/questions/2229263/convergence-of-sum-frac-sinn2n
You can prove ##\ln (1-z)## converges everywhere on the unit circle except at ##z=1## by Dirichlet's test: Fix ##z## in the unit circle, i.e. ##|z|=1##.
If ##\{ a_n \}## are real numbers and ##\{ b_n \}## complex numbers such that: (i) ##a_1 \geq a_2 \geq \cdots## (ii) ##\lim_{n \rightarrow \infty} a_n = 0## (iii) There exists ##M## such that ##\left| \sum_{n=1}^N b_n \right| \leq M## for all ##N \in \mathbb{N}##; then ##\sum_{n=1}^\infty a_n b_n## converges.
Choose ##a_n = 1/n## and ##b_n = z^n##, then the first two conditions obviously hold. For the third condition:
\begin{align*}
\left| \sum_{n=1}^N z^n \right| = \left| \dfrac{z-z^{N+1}}{1-z} \right| \leq \frac{2}{| 1-z |}
\end{align*}
for all ##N \in \mathbb{N}##. This shows the series converges for ##|z|=1## where ##z \not= 1##.
