Bohmian Mechanics of DCES (swaps), featuring several papers
  • Level: Graduate
  • Thread starter DrChinese
68 replies · 6K views · last reply
Matterwave said:
The guidance equation operates on the whole thing. But the thing that's real which a measurement reveals the value of in a lab is only ##\vec{r}_1## or ##\vec{r}_2##.
I can't detect anything in this description that would pick out a particular preferred basis in ##\mathbb{C}^4##.
So the question that comes to my mind is this: Is pilotwave ontic? If not, what is doing the action at the distance thing?
Consider the analogy with classical Hamilton-Jacobi (HJ) function ##S(x,t)##. Would you call it ontic? If not, then why the classical particle has velocity determined by the HJ function?
The answer is that the HJ function and the wave function are not ontological, but nomological. This means that it is an object that serves as a law of motion, similarly to Hamiltonian or Lagrangian.
In classical physics the answer to the second question would be: fields. So extending the parallels with classical physics would you say that pilot wave implies some kind of non-classical FTL field?
zonde said:
No, I am not saying that. I am sort of hoping that that's the case. What I have on my mind when I am saying that ##|\chi\rangle## in only one particular (spin) basis is ontic is this paper:
Ultra-bright source of polarization-entangled photons
Looking at the abstract this is a paper about efficiently producing many Bell entangled photon states. I'm not seeing the connection to what you're saying about ##|\chi\rangle##. Could you elaborate or point me to the relevant section/paragraph/sentence?
At least the traditional view (e.g. from DeBroglie and Bohm) would be that it is ontic. The wave function works very similarly to a field that guides the particle. But one issue with this wavefunction-as-field picture is even just the position basis wave function doesn't live in space(time). Only for a single particle would it be a scalar function over space. A general N particle wave function lives in 3N dimensional configuration space. Entanglement forces this.
As for modern views of the pilot wave, I will defer on that since I'm not sure. Maybe a more nomological view (it is a dynamical law, not a "thing that exists") is preferred nowadays. But I do believe I heard Tim Maudlin still advocating for the ontic view, just not ontic as a physical field in physical space.
That's not the answer to my question. I asked about classical mechanics, which, in its narrow sense, does not involve fields, only point particles. And I asked a question about the HJ equation. If you want to understand Bohmian mechanics, you have to first understand HJ mechanics.
I tried to explain the connection in this thread with relevant equation and quote. I hope it helps.
Well, no. Particles are not enough. You have to have some interaction, between particles or between particles and fields or some other hypothetical way.
What's so fundamental about HJ equation that is so important to understand versus other formulations of classical mechanics?
In classical mechanics of ##N## particles, the interaction is described by a potential ##V(x_1,x_2,...x_N)##, which is not called a field.
The HJ equation is similar to the Schrodinger equation. The basic guiding equation in Bohmian mechanics has the same form as that in the HJ theory.
