Demystifier said:
I don't pick and choose anything. It's the Bohmian equation of motion that determines when the position of one particle influences the motion of the other, and when it doesn't. But there is not a good way to explain it by words. You must read the math of the Bohmian equation of motion.
It's not that complicated of a Bohmian scenario. I have 2 entangled photons 1 and 2 as part of a Bell test, while photon 2 is still midflight.
i) What is the initial influence of photon 1 on photon 2 as to polarization and momentum, while photon 1 is midflight?
ii) What is sum influence of the atoms of the PBS measuring photon 1 on photon 2 as to polarization and momentum?
iii) What is sum influence of the atoms of the detector registering photon 1 on photon 2 as to polarization and momentum?
iv) What is influence of the rest of the universe on photon 2 as to polarization and momentum?
Norsen mentions i) in his discussion (Fig. 6), but does not really mention the others. But you have mentioned ii) iii) and iv) previously. If the influence of any of these 4 is negligible, then I'd be interested to know that. Presumably, distance is not a factor. Or, if distance is a factor in the Bohmian equation of motion, just say so.
I would claim oQM says:
i) there is no influence whatsoever of Photon 1 on photon 2 while they are both midflight.
ii) there is no influence whatsoever of the individual atoms of a PBS on photon 1 or photon 2 (only the orientation - a single variable - is relevant).
iii) there is no influence whatsoever of the individual atoms of a detector on photon 1 or photon 2.
iv) there is no influence whatsoever of the rest of the universe on photon 1 or photon 2.
So... in experiment after experiment, the statistical results seems to only depend on one single variable: polarizer orientation. None of the other items you input into "
the math of the Bohmian equation of motion" seem to matter at all. Why is that? If you don't pick and choose, why is it that all these inputs always seem to vanish (i.e. net to zero) in polarization experiments?
In other words: I know that we don't know the precise particle positions, point accepted. But if you specified them exactly in an even easier example, can you tell me what the polarization results would be? In other words: If BM has deterministic features, I would think you could fabricate an example where I start with a |+> polarized photons that I will run into a H/V oriented PBS (or some other theta); and you could tell me (using Bohmian math) which specific port it would exit and be detected (H or V). You can specify whatever initial conditions you like to create the example (apparati, source, etc).
In oQM the answer is plain: This problem cannot be solved exactly, and there is only 1 variable (theta). I don't think it can be solved in BM either, but I am trying to understand how many variables are involved "under the hood" so to speak.
