Black Holes, how much energy do they give off?
The discussion revolves around the energy emitted by black holes, particularly in relation to their mass and the mechanisms involved, such as Hawking radiation and other processes. Participants explore theoretical frameworks, mathematical formulations, and implications of black hole thermodynamics.
  • One participant inquires about the energy output of black holes relative to their mass, seeking a percentage of mass converted to energy per second.
  • Another participant references Hawking radiation, explaining that as particles escape, a black hole loses energy and mass, and provides a formula for estimating power emitted by a nonrotating black hole.
  • A later reply notes that smaller black holes radiate more quickly than larger ones, but their lifespans are extremely long, potentially on the order of the age of the universe.
  • One participant introduces the idea that rotating black holes can lose energy through processes like the Penrose process and superradiance, suggesting that up to 29% of a black hole's mass can be extracted through these means.
  • Another participant discusses the implications of rotation on Hawking radiation, positing that a maximal Kerr black hole may not emit radiation at all.
  • Further contributions explore the concept of naked singularities and the stability of black holes, referencing theoretical work by notable physicists and discussing the conditions under which these phenomena may occur.
  • Participants also engage in mathematical discussions regarding the equations governing black hole horizons and their translation between different units.
There is no consensus on the exact mechanisms and implications of energy loss in black holes, with multiple competing views and interpretations presented throughout the discussion.
Participants reference various equations and theoretical models, indicating a reliance on specific assumptions and definitions that may not be universally accepted or resolved within the discussion.
sollinton
Sorry for the dumb question but...
My friend and I were wondering how much energy is given off by an average black hole relative to its mass. (like X black hole gives off Y% of its mass as energy per second)
Thanks in advance for your help.
Astronomy news on Phys.org
I'd start with wikipedia's article on Hawking Radiation:
Wikipedia said:
When particles escape, the black hole loses a small amount of its energy and therefore of its mass (mass and energy are related by Einstein's equation E = mc²).
The power emitted by a black hole in the form of Hawking radiation can easily be estimated for the simplest case of a nonrotating, non-charged Schwarzschild black hole of mass M. Combining the formulae for the Schwarzschild radius of the black hole, the Stefan-Boltzmann law of black-body radiation, the above formula for the temperature of the radiation, and the formula for the surface area of a sphere (the black hole's event horizon) we get:
It goes on to give the formula and more info.
Thanks a lot, this really helps. :smile:
A black hole gets hotter as it radiates and gets smaller, so a smaller black hole dissipates more quickly than a massive one...but the lives in general are extremely long...I believe on roughly the order of the age of the universe...or at least ,really, really slowly...in other words, you'll have to watch really carefully to see one die...
It might be worth noting that black holes (particulaly rotating ones) can also loose energy via other processes-
According to one source, the total mass-energy of a black hole is-
[tex]\tag{1}M^2=\frac{J^2}{4M_{ir}^2}+\left(\frac{Q^2}{4M_{ir}}+M_{ir}\right)^2[/tex]
where
[tex]\tag{2}M_{ir}=\frac{1}{2}\sqrt{\left(M+\sqrt{M^2-Q^2-a^2}\right)^2+a^2}[/tex]
The first term (J) is rotational energy, the second term (Q) is coulomb energy and the third term (Mir) is irreducible energy (in all cases, M is the gravitational radius, a is the spin parameter in metres and J is angular momentum).
The first and second are extractable by physical means, such as the Penrose process, superradiance or electrodynamical process.
The irreducible part cannot be lowered by classical (e.g. non-quantum) processes and can only be lost through Hawking radiation. As high as 29% of a black holes total mass can be extracted by the first process and up to 50% for the second process (but realistically, charged black holes probably only exist in theory or are very short lived as they would probably neutralise quite quickly after forming).
Interestingly, the above makes it appear that kinetic rotational energy does contribute to the overall total mass of a black hole (or any rotating object for that matter) as the rest mass would be less than the rotating mass.
Another equation to calculate the rotational energy (which equals M-Mir) is-
[tex]\tag{3}E_{rot}=M-\sqrt{\frac{1}{2}M\left(M+\sqrt{M^2-a^2\right)}}[/tex]
Also, the effects of rotation on Hawking radiation is equal to-
[tex]\tag{4}T_H=\frac{\hbar\kappa}{2\pi k_bc}=2\left(1+\frac{M}{\sqrt{M^2-a^2}\right)^{-1}} \frac{\hbar c^3}{8\pi Gk_bm}<\frac{\hbar c^3}{8\pi Gk_bm}[/tex]
where [itex]\kappa[/itex] is the Killing surface gravity of the black hole, [itex]\hbar[/tex] is the reduced Planck constant and [itex]k_b[/itex] is the Boltzmann constant.<br /> <br /> The above effects of rotation on Hawking radiation imply that a maximal Kerr black hole (a/M=1) would give off no radiation.<br /> <br /> <br /> (1),(2)<br /> 'Black Holes: A General Introduction' by Jeane-pierre Luminet<br /> <a href="http://www.ece.uic.edu/~tsarkar/Goodies/Black%20Hole.pdf" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://www.ece.uic.edu/~tsarkar/Goodies/Black Hole.pdf</a><br /> pages 12 & 13<br /> <br /> (3)<br /> 'Compact Objects in Astrophysics' by Max Camenzind <br /> http://www.lsw.uni-heidelberg.de/users/mcamenzi/CObjects_06.pdf <br /> page 271<br /> <br /> (4)<br /> 'Black Hole Thermodynamics' by Narit Pidokrajt<br /> http://www.physto.se/~narit/bh.pdf <br /> page 10[/itex]
[tex]T_H = 2 \left(1 + \frac{M}{\sqrt{M^2 - a^2} \right)^{-1}} \frac{\hbar c^3}{8 \pi G k_b m} \leq \frac{\hbar c^3}{8 \pi G k_b m}[/tex]
If that equation is correct under zeroth law, what would prevent a maximal Kerr quantum black hole from becoming completely stable?
[/Color]
Reference:
'Black Hole Thermodynamics' by Narit Pidokrajt - pg. 10
Initially I would say cosmic censorship but I found this in the black hole electron section of wiki-
Some theorists, including Stephen Hawking and Kip Thorne, have recently concluded that the laws of nature do permit the formation of a naked singularity during gravitational collapse. In a later paper (2007) titled, Kerr Geometry as Space-Time Structure of the Dirac Electron, Burinskii writes:"In this work we obtain an exact correspondence between the wave function of the Dirac equation and the spinor (twistorial) structure of the Kerr geometry. It allows us to assume that the Kerr-Newman geometry reflects the specific space-time structure of electron, and electron contains really the Kerr-Newman circular string of Compton size". The Burinskii papers describe an electron as a gravitationally confined ring singularity without an event horizon. It has some, but not all of the predicted properties of a black hole. A new name other than "Black hole electron" is needed for this model.
At the radius [itex]3Gm/c^2[/itex], a special space curvature condition is found. An electromagnetic wave has a 50 percent probability of either orbiting and spiraling inward or spiraling away to infinity due to the gravitational space curvature at [itex]3Gm/c^2[/itex]. The radius [itex]3Gm/c^2[/itex] is the gravitational photon orbit radius or photon sphere radius. This radius is critical if self-gravitational attraction is required to produce a stable state.
The equation for the photon sphere that applies to both static and rotating black holes is-
[tex]\tag{1}R_{ph}=2M\left[1+cos\left(\frac{2}{3}cos^{-1}\frac{-a}{M}\right)\right][/tex]
which reduces to (what was) the event horizon radius for a maximal Kerr black hole. If the above statement is right, then the reduction of the photon sphere radius would appear to have some impact on the stability of a maximal Kerr quantum black hole (or maybe the photon sphere works differently at quantum level).
(1)
page 259
In reference 1 - pg. 253, the equation stated in relativistic units for the dual outer and inner horizons:
[tex]r_{\pm} = M_H \pm \sqrt{M_H^2 - a_H^2}[/tex]
Where the key is:
[tex]M_H = r_g = \frac{Gm}{c^2}[/tex]
[tex]a_H = a \cdot r_g[/tex]
Therefore, the equation for the dual outer and inner horizons in physical natural units (S.I.) is:
[tex]\boxed{r_{\pm} = r_g \pm \sqrt{r_g^2(1 - a^2)}}[/tex]
Is this equation translation from relativistic to natural units correct?
[/Color]
Reference:
Kerr metric...
The effects of angular momentum on Hawking radiation in physical units (S.I.):
[tex]\boxed{T_H = 2 \left(1 + \frac{1}{\sqrt{(1 - a^2)} \right)^{-1}} \frac{\hbar c^3}{8 \pi G k_b m} \leq \frac{\hbar c^3}{8 \pi G k_b m}}[/tex]
Kerr metric angular momentum:
[tex]\alpha = \frac{J}{mc}[/tex]
Radii for the dual outer and inner horizons in physical units (S.I.):
[tex]{r_{\pm} = r_g \left[1 \pm \sqrt{(1 - a^2)}\right][/tex]
Ergosphere radius:
[tex]r_{e} = r_g \left[1 + \sqrt{(1 - a^2 \cos^{2} \theta)}\right][/tex]
[tex]r_{\pm} = \frac{r_{s} \pm \sqrt{r_{s}^{2} - 4\alpha^{2}}}{2}[/tex]
Ergosphere radius:
[tex]r_{e} = \frac{r_{s} + \sqrt{r_{s}^{2} - 4\alpha^{2} \cos^{2}\theta}}{2}[/tex]
[tex]r_s = 2 \cdot r_g[/tex]
Establishing the equations between the Kerr metric angular momentum terms [tex]\alpha[/tex] and [tex]a[/tex] for the inner horizon radius:
[tex]r_{-} = \frac{1}{2} \left(2 r_g - \sqrt{(2 r_g)^{2} - 4 \alpha^{2}} \right) = r_g \left[1 - \sqrt{(1 - a^2)}\right][/tex]
Solving for [tex]a[/tex] for the inner horizon radius:
[tex]\boxed{a = \frac{\alpha}{r_g}}[/tex]
[/Color]
Reference:
Kerr Metric - Important surfaces - Wikipedia
For some reason, wikipedia do not recognise the inner Cauchy horizon of Kerr black holes, so when they talk about the outer horizon, they refer to the static limit or the ergosphere and when they talk about the inner horizon, they refer to the outer event horizon (I don't know if it's still recorded under discussion but there was a request to remove any mention of the inner Cauchy horizon which went ahead). This would mean the following would apply-
ergosphere-
[tex]r_{e} = \frac{r_{s} + \sqrt{r_{s}^{2} - 4\alpha^{2} cos^{2}}}{2} = r_g \left[1 + \sqrt{(1 - a^2 cos^{2} \theta)}\right][/tex]
(wiki has this down as the outer event horizon)
outer event horizon-
[tex]r_{+} = \frac{r_{s} + \sqrt{r_{s}^{2} - 4\alpha^{2}}}{2} = r_g \left[1 + \sqrt{(1 - a^2)}\right][/tex]
(wiki has this down as the inner event horizon)
And to extrapolate-
inner event horizon-
[tex]r_{-} = \frac{r_{s} - \sqrt{r_{s}^{2} - 4\alpha^{2}}}{2} = r_g \left[1 - \sqrt{(1 - a^2)}\right][/tex]
(which wiki has ignored)
In regard of your solution expressing [itex]a[/itex] as a unitless spin parameter between 0 and 1, the following would apply-
[tex]a=\frac{\alpha}{r_g}[/tex]
It's worth noting that while wikipedia use [itex]\alpha[/itex] (alpha) to represent the spin parameter in metres, I have seen [itex]\alpha[/itex] represent redshift in frame-dragging equations (which derive from Kerr metric) and [itex]a[/itex] is used to represent the spin parameter in metres. To represent the spin parameter as a unitless number between 0 and 1 (or in natural units), I've seen the following terms used- [itex]|a|[/itex], [itex]a_\ast[/itex] or even simply [itex]a/M[/itex] as in the 'black hole parameters' section on scholarpedia.
Wikipedia said:
A rotating black hole has two photon spheres. As a black hole rotates it drags space with it. The photon sphere that is closer to the black hole is moving in the same direction as the rotation, whereas the photon sphere further away is moving against it. The greater the angular velocity of the rotation of a black hole the greater distance between the two photon spheres. Because the black hole has an axis of rotation this only holds true if approaching the black hole in the direction of the equator. If approaching at a different angle, such as one from the poles of the black hole, to the equator there is only one photon sphere. This is because approaching at this angle the possibility of traveling with or against the rotation does not exist.
The effects of angular momentum on photon sphere radius in physical S.I. units:
[tex]r_{ps} = 2 r_g \left[1 + \cos \left(\frac{2}{3} \cos^{-1} -a \right) \right][/tex]
[tex]\boxed{r_{ps} = 3 r_g \; \; \; a = 0}[/tex]
[tex]\boxed{r_{ps} = r_g \; \; \; \; a = 1}[/tex]
Does anyone have the radius equations for the two photon spheres?
[/Color]
Reference:
Photon sphere - Wikipedia
Inside a black hole - the Kerr black hole
[tex]r_{ps \mp} = 2 r_g \left[1 + \cos \left(\frac{2}{3} \cos^{-1} \mp |a| \right) \right][/tex]
[tex]-|a|[/tex] - prograde photon orbit
[tex]+|a|[/tex] - retrograde photon orbit
[tex]\boxed{r_{ps-} = 3 r_g \; \; \; a = 0}[/tex]
[tex]\boxed{r_{ps+} = 3 r_g \; \; \; \; a = 0}[/tex]
[tex]\boxed{r_{ps-} = r_g \; \; \; \; \; a = 1}[/tex]
[tex]\boxed{r_{ps+} = 4 r_g \; \; \; \; a = 1}[/tex]
[/Color]
Reference:
http://www.physics.nus.edu.sg/~phyteoe/kerr/"
There seems to be a problem with the equation at the poles. As a increases, the prograde orbit passes through the event horizon. (EDIT: Equation in post #15 removed)
Below is a link to images from the 'Spherical Photon Orbits' website of example orbits (which look fairly spherical)-
http://www.physics.nus.edu.sg/~phyteoe/kerr/table.html
The graphic model shown in attachment #1 of post #13, displays the dual photon spheres as oblate spheroids, this graphic model appears to be incorrect.
[/Color]
That seems to be the case.
Regarding the OP's question of how much energy do black holes give off, there is also a process called Penrose Pair Production (PPP)-
A variant of the classical http://en.wikipedia.org/wiki/Penrose_process" is the Penrose Pair Production. The mechanism is based on another ingredient, the photonsphere. Photons are instably trapped in the photon sphere. Other photons may now infall on radial null geodesics and hit these trapped photons. If the energy of the quanta exceeds the rest frame energy of about one MeV, gamma photons produce pairs of leptons. For rather large values of the black hole spin, a > 0.7, the spherically symmetric photon sphere plunges into the oblate ergosphere. Then, the PPP is expected to occur dominantly. PPP is sketched in Fig. 3.14. (R.K.) Williams applied this model to explain the populations of ultrarelativistic electrons in the quasars 3C 279 and 3C 273
key to Fig. 3.14-
Illustration of the production of a pair plasma via Penrose processes in
the ergosphere (blue) of a Kerr black hole (violet). The gamma photons
annihilate in the photon sphere (yellow) to produce electrons (cyan) and
positrons (green).
'Magnetohydrodynamics on the Kerr Geometry' by A Mueller
http://www.wissenschaft-online.de/astrowissen/downloads/PhD/PhD_AMueller.pdf
pages 47 & 48
Kerr metric quantum black hole evaporation time...
Effects of angular momentum on a (4+n)-dimensional Kerr metric quantum black hole Hawking radiation evaporation time:
[tex]\boxed{t(n, a)_{ev} = \frac{320 G^2 m_p^3}{\hbar c^4 \sqrt{\pi}} \left[ \frac{E_{BH}}{E_p} \left( \frac{8 \Gamma\left(\frac{n+3}{2} \right)}{n+2} \right) \right]^{\frac{3}{n+1}} \left(1 + \frac{1}{\sqrt{(1 - a^2)} \right)^{4}}} \; \; \; a < 1[/tex]
[tex]\boxed{t_0 = \frac{320 G^2 m_p^3}{\hbar c^4 \sqrt{\pi}}}[/tex]
[tex]\boxed{t_0 = 9.733 \cdot 10^{-42} \; \text{s}}[/tex]
[tex]E_{BH} = 14 \; \text{Tev}[/tex]
[tex]\boxed{t(10, 0.999)_{ev} = 3.275 \cdot 10^{-40} \; \text{s}}[/tex]
Note:
[tex]\boxed{\lim_{a \to 1} t(n, a)_{ev} = \infty}[/tex]
Wikipedia said:
Computer simulations of the collapse of a disk of dust have indicated that these objects can exist, and thus the cosmic censorship hypothesis (stating that singularities are always hidden) does not hold.
Computer models of gravitational collapse have shown that naked singularities can arise, but these models rely on very special circumstances (such as spherical symmetry).
[/Color]
Reference:
http://www.youtube.com/watch?v=kVsZdgz5oFM"
http://en.wikipedia.org/wiki/Hawking_radiation#Black_hole_evaporation"
http://www.physto.se/~narit/bh.pdf"
https://www.physicsforums.com/showpost.php?p=1946387&postcount=11"
http://en.wikipedia.org/wiki/Micro_black_hole#Stable_micro_black_holes"
http://eprints.may.ie/archive/00000240/01/fuzzyBH-4.pdf"
https://www.physicsforums.com/showpost.php?p=1891354&postcount=454"
http://en.wikipedia.org/wiki/Naked_singularity"
http://en.wikipedia.org/wiki/Cosmic_censorship_hypothesis"
https://www.physicsforums.com/showpost.php?p=1877224&postcount=428"
http://www.lsw.uni-heidelberg.de/users/mcamenzi/CObjects_06.pdf"
http://www.wissensnavigator.ch/documents/OTTOROESSLERMINIBLACKHOLE.pdf"
The "Figure 3.14" referenced in post No. 19 relates specifically to the Alexander Burinskii electron model that includes a naked ring singularity. The electron angular momentum is so great that the electron cannot collapse to its event horizon radius and so its ring singularity is naked. Electron mass energy relationships imply that electron gravitational collapse is halted at the equatorial photon sphere radius which is larger than the projected event horizon. In the equatorial plane, the static limit is (4/2) times the projected event horizon while the photon sphere radius is (3/2) times the projected event horizon. See:
http://www.absoluteastronomy.com/discussionpost/Electron_as_a_ring_singularity_56595
In the Burinskii electron model rotational energy accounts for all of the electron mass energy. The ingrediants of the electron are an electromagnetic field and rotating space-time.
A paper referenced in post #20 "Quantum Black Holes: the Event Horizon as a Fuzzy Sphere" is interesting because the author finds (page 3) the smallest possible mass for a black hole in this scheme is (1/2) (Planck mass). This is confirmed when the angular momentum value h/4pi is included as a requirement.
mcr = h/4pi
mc (2Gm/c^2) = h/4pi = angular momentum
(m)^2 = (h/4pi) (c^2/2G) (1/c) = (1/4) (hc/2pi G)
m = (1/2) (hc/2pi G)^1/2 = (1/2) (Planck mass)
The mass value that relates to electron mass, is collapsed to its photon orbit radius where forces are balanced. When space-time spin is canceled (by merging with a positron) all of its mass energy is radiated away.
mc (3Gm/c^2) = h/4pi = angular momentum
(m)^2 = (h/4pi) (c^2/3G) (1/c) = (1/4) (hc/3pi G) = (hc/12pi G)
m = (hc/12pi G)^1/2 = (1/2) (2/3)^1/2 (hc/2pi G)^1/2 = (1/2) (2/3)^1/2 (planck mass)
In this model, the electron is not fully collapsed to produce an event horizon. Without an event horizon, it has some but not all of the properties predicted for a black hole.
We can add to the Alexander Burinskii electron model by introducing the concept of a "limit gravitational time dilation factor" as shown:
Limit time factor = (3/2)^1/2 (Planck time) divided by (2pi seconds)
Limit time factor = (3hG /4pi c^5)^1/2 (1/2pi) seconds per second
(Limit time factor)^1/2 = (3hG /4pi c^5)^1/4 (1/2pi)^1/2 seconds per second
In this ratio equation, one second is the time required for light to travel 299792458 meters. The quantized mass value noted in post #22 was (hc/ 12 pi G)^1/2. We find that this mass value, when degraded (reduced) by the (limit time factor) exponent 1/2 is equal the electron mass.
electron mass = (hc/ 12pi G)^1/2 (3hG /4pi c^5)^1/4 (1/2pi)^1/2 kg
This equation implies that the true gravitational constant value G, must be very close to 6.67174557x10 exponent -11.
electron mass = 9.10938215x10 exponent -31 kg
Ths implies that the time (3/2) exponent 1/2 times (Planck time) is the smallest amount of time that has meaning.
We can now see that the electron mass, muon mass and tau mass are each related to the Planck mass by three factors. The first two factors are (1/2) and (2/3)^1/2. The third factor is the square root of the ratio, 4pi (3Gm/c^2) divided by (Compton wavelength of the particle). This third factor is the gravitational time dilation factor that applies at the collapsed particle radius, 3Gm/c^2. In the special (electron) case, this time dilation value is equal to the square root of the proposed limit time dilation value. These equations are either precisely correct, or so very close that we are unable to define their error. Many theorists expected that the Planck mass should relate to the electron mass. A serious effort is now needed to determine if these equations are just due to coincidence or if these equations can lead to an improved understanding of particles. I suggest that Orion 1 has worked in this area and so he could provide help with this.
We find that photons have ever greater energy density as a photon wavelength is reduced. An interesting (limit) short wavelength value is found when photon energy density is so large that photon energy is correctly specified by either the Planck constant h, or the gravitational constant G. Photon energy at this limit is h times frequency or (hc/ wavelength) and also equal to (wavelength) (c^4/3pi G).
Energy = hc/ wavelength = (wavelength) (c^4/3pi G)
We find, (wavelength)^2 = (hc) (3pi G/c^4). Then the wavelength is:
wavelength = (3pi hG/c^3)^1/2
This wavelength is (2pi) (3/2)^1/2 (Planck length). This photon wavelength has energy that is specified by light velocity and the gravitational constant. Photon energy is inversely proportional to wavelength and so the energy of any longer wavelength photon can be specified by light velocity and the gravitational constant. The photon wavelength with energy equal to two electron mass particles or (h/2mc) meters can also be specified by light velocity and the gravitational constant. The rato (2pi) (3/2)^1/2(Planck length) divided by (h/2mc) meters becomes very significant when we try to understand how the electron mass is quantized. This ratio relates to gravitational blueshift and gravitational time dilation.
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 22 ·
