Can Light Emission Be Explained Through Newtonian Physics?
The discussion revolves around the possibility of explaining light emission through Newtonian physics, particularly focusing on the behavior of photons in relation to their emission direction and the motion of the source. Participants explore concepts such as momentum conservation, the transformation of energy-momentum, and the implications of light's speed and direction in different frames of reference.
  • Some participants suggest that light emitted orthogonally to motion behaves like a Newtonian particle with conserved longitudinal momentum, raising questions about the implications of this analogy.
  • Others inquire about the meaning of "conserved longitudinal momentum" and discuss the transformation of the energy-momentum four-vector across different frames.
  • One participant describes a scenario involving a hydrogen atom emitting a photon and calculates the energy and momentum of the photon in both the rest frame and a moving frame, concluding that the photon has no mass in either frame.
  • Some participants assert that while the scalar speed of light is invariant, its vector velocity can change direction when transitioning between frames, and that photon momentum behaves similarly to that of massive particles.
  • Questions arise regarding the behavior of massive particles and photons when emitted transversely, including how their momentum vectors change relative to different frames.
  • One participant expresses skepticism about the possibility of a photon traveling in a straight linear path orthogonal to the emitter's motion, prompting further exploration of the implications of this perspective.
  • Another participant proposes that the light detector's position relative to the emitter's motion may affect the perceived trajectory of emitted photons, suggesting a tilted perspective due to the emitter's motion.
Participants do not reach a consensus, as multiple competing views remain regarding the implications of Newtonian physics on light emission and the behavior of photons in different frames of reference. The discussion includes various interpretations and calculations that highlight the complexity of the topic.
Limitations include the dependence on specific definitions of momentum and energy, as well as unresolved mathematical steps in the transformations discussed. The discussion reflects a range of assumptions about the nature of light and its interaction with motion.
Austin0
From what I have learned so far, it appears that a light emission orthogonal to motion acts exactly like a Newtonian massive particle with conserved longitudinal momentum. Is this correct?
If so it would seem to be a cosmic coincidence of monumental proportions.
Having given it some thought all I have arrived at is: Possibly Newton was right and photons do have mass, Then the massless staus would appear to be a conventional calibration of the metric and a lack of rest photons.
In this case the independence of light from the motion of the emitter would seem to only strictly apply wrt emissions parallel to motion where the physical cap of c would prevent momentum conservation while all other angles of emission would retain coordinate speed of c but would have different velocity vectors
Is there any conceptual mechanism to explain this??
Am I totally misinformed regarding beaming?
Thanks
What do you mean by "conserved longitudinal momentum" here?
For what it's worth, the energy-momentum four-vector (E/c, p_x, p_y, p_z) transforms from one frame to another (via a Lorentz transformation, of course) in exactly the same way as the time-position four-vector (ct, x, y, z). This is true for both massive and massless particles.
In particular, for a relative velocity in the x-direction (only), the Lorentz transformation affects only p_x, leaving p_y and p_z unchanged, just as it affects only x, leaving y and z unchanged.
I mean that a photon emitted transversely in a moving system and reflected within that system bounces straight up and down just like a Newtonian ball. It retains the forward motion of the system. i.e. conserved forward momentum. It is not independent of the motion of the source except with regard to emissions along the path of motion.
As I understand it, this is true as observed from other inertial frames as well. Photon beaming.
So if the frame is moving in x and the photon is emitted with a pure y vector relative to that frame , as observed in other frames the photon would have an x velocity component as well. Is this incorrect?
Unless I am misunderstanding what I have been reading.
Consider a hydrogen atom with the electron emitting a 2p-1s transition photon (~10.2 eV) in the y direction transverse to its motion with velocity βc in the x direction. What is the energy, direction, and mass of the photon in the moving frame?
Use Lorentz transform (in thumbnail)
In hydrogen atom rest frame, the photon is:
E = 10.2 eV =pyc, and pxc = pzc = 0
The photon mass is M2 = E2 - (pyc)2 = 0
In moving frame:
E* = γE
pxc*=- βγE
pyc* = pyc = E
pzc* = 0
Photon mass in moving frame is
(M*)2 =(E*)2 - [(pxc*)2 +(pyc*)2]
= (γE)2 -[(βγE)2 + E2 ] = γ2(E22E2) - E2 = 0
Photon has no mass in moving frame.
angle in moving frame is θ = tan-1(pyc*/pxc*) = tan-1(1/βγ)
Bob S
Thanks, Bob S. Good answer.
Austin0
  1. The scalar speed of light is invariant (the same in all frames) but the vector velocity of light is not. It can change direction when you change frames.
  2. Photon momentum behaves like any other kind of momentum. The total momentum of a system is conserved (remains unchanged over time when measured in the same frame throughout).
  3. Momentum is conserved but not invariant.
  4. Momentum of a massive particle relative to a frame is given by [itex]p = \gamma mv[/itex].
  5. Momentum of a photon relative to a frame is given by [itex]p = E / c = h \nu / c = h / \lambda[/itex]
DrGreg said:
Austin0
From these posts I seem to understand that my initial grasp was basically correct as far as the behavior if not on any implications of mass.
As a self test:
1) A massive particle accelerated transversely changes vector magnitude as well as direction relative to an observing frame for both velocity and momentum??
2) A photon emitted transversely changes direction of the velocity vector but not the magnitude??
Changes both the direction and magnitude of the momentum vector with the magnitude decreased relative to the magnitude in the emitting frame??
3) With regard to a massive particle say a bullet that is rotating around the axis of motion: in a relative frame the forward momentum would result in a sideways drift relative to the spin??
Wrt a photon this is not such a comfortable picture. If we consider a photon as a traveling waveform this would mean it would be out of phase along an orthogonal front relative to its linear motion, yes?
It would seem to be more realistic to view the angle derived from the vector sum of conserved momentum as an actual propagation angle with the wave front in phase, relative to travel, does this make any sense??
4) Given the picture I have so far it would seem impossible for any photon to have a straight linear path orthogonal to the emitter motion.
That if there is a light detector at the end of a long light absorbtive tube aligned directly perpendicular to the source motion that it would seem impossible for a photon to reach the detector??
Whats wrong with this picture?
Thanks to all for your help in elucidating this question
My first thought on this is that from the point of view of the moving emitter, the tube will appear to be tilted towards the emitter, giving a point on its trajectory when a photon can be fired down the tube.
I'll try the calculation tomorrow unless someone (please :smile:) beats me to it.
[edit]
The scenario is shown in the picture. The tube has end coordinates (0,0) and the (0,L). The emitter travels along (V t, yE ). We can define the tube in 4 dimensions by imagining a light beam emitted at the bottom end and sent to the top end. This gives a 4D position vector of the event when the light reaches the top ( L/c, 0, L ). From the emitter frame this transforms
[tex]( L/c,0,L) \rightarrow ( \gamma L/c, \gamma \beta L/c, L)[/tex]
The x-coord of the top moves left, tilting the tube. I've cheated by choosing axes so the bottom doesn't move, but it shows the effect.
The important thing is that the bottom and top of the tube have different relative velocities with the emitter, and so the change in the x-coords will be greater at the top than the bottom, giving the tilt. As the emitter passes over the tube, it appears to the emitter that the tube becomes vertical then starts tilting the other way.
Because every point of the tube has a different relative velocity with the emitter frame, the tube will appear bent and tilted.
I could have got this wrong but it seems right.
Look at it this way. Consider an emitter in the CM system emitting a photon in the direction perpendicular to its direction of motion at velocity βc with respect to an observer in the Lab system. The photon is moving down a long straight absorptive tube, at rest in the CM system. Regardless of the velocity of the emitter and the absorptive tube relative to the observer, the photon will always exit the end of the tube, independent of the emitter's velocity in the Lab system. The observer sees the photon exiting the absorptive tube, at an angle θlab = tan-1(1/βγ) relative to its direction of motion. (see Post #4).
So why does the absorptive tube appear to be rotated in the Lab system? It is due to the Terrell effect:
http://en.wikipedia.org/wiki/Terrell_rotation
Also see visual effects in
http://www.anu.edu.au/physics/Searle/
also see Post #9 in thread https://www.physicsforums.com/showthread.php?t=19860&highlight=terrell+relativistic
Bob S
This is embarassing, I came back to delete my post #8 but I'm too late.
If in the rest frame of the emitter, the photon reaches a detector at the end of the tube, then it follows that in any other frame the same must be true, in relativity and in Newtonian physics. Considering a vertical tube in a train. A ball is dropped in the top of the tube by an observer on the train and the ball appears to follow a path straight down to the bottom of the tube. To an observer outside the train, the ball follows a diagonal path that is combination of the balls vertical path due to gravity and trains horizontal motion. In the Newtonian context, the ball follows a diagonal path while staying within the confines of the vertical tube at all times. In the relativistic case, it is pretty much the same. If the tube is exactly orthogonal to the motion, then it does not rotate or bend. If the tube is tilted at some angle other than orthogonal or parallel to the motion, the tube angle relative to the motion appears different in the different frames and appears to be tilted differently (but not bent). Either way the ball (or a photon) stays inside the tube in both frames and hits the target or detector in both frames. I gave an equation for calculating the velocity of a particle or photon that is emitted at an angle to the relative motion of two frames, in a similar thread: https://www.physicsforums.com/showthread.php?t=423338
Bob S
Hi Bob S ...I am afraid I was not clear enough in my post.
The tube and detector are both at rest in the lab frame. There is clearly no problem if the tube is in the emitter frame otherwise a light clock could not work.
As for Terrell rotation I am very interested , even if it is an optical effect that would not really apply to this situation. I read about the effect years ago and can't remember the source , From what I do remember the effect only involved length contraction and the optical effects resulting from light propagation time from vatious parts of the object.
I have searched for more detailed links other than the one you cited but without success.
I will try the thread you referenced , thanks.
BYW thanks for your post wrt momentum and mass. Some of the notation was unfamiliar to me but I think I got the gist.
Ooops I was too ambiguous . In this case it is dropping a ball from the train down a vertical tube in the track frame. Thanks
Looking at your post I don't exactly get the source of any embarrassment.
Perhaps you could explain in detail just how you screwed up:-p
[edit]
Is it perhaps the different relative velocities wrt the emitter that you are unhappy with?
If the tube and detector are both in the Lab (observer's) frame, then the tube tilt angle is
θlab = tan-1(1/βγ)
as shown in my earlier post #4. The tube is not bent in the lab frame, nor is the observed trajectory of the emitted photon. If the photon reaches the end of the tube and the detector in the lab frame, then it will also, when observed in the CM frame.
Bob S
θlab = tan-1(1/βγ)
Bob S
Hi Bob I understood that the angle in post #4 was the vector sum i.e. direction of the photon relative to the lab frame.
If the tube (in the lab) is orthogonal to the path of the emitter where does the tilt come from? The terrell effect is purely optical as far as I know.
SO the question is; can a photon follow a path directly perpendicular to the motion of the emitter?
If not then how could it travel through the tube?
Thanks for your responce
The tube in the lab cannot be orthogonal to the direction of motion; it has to be at an angle
θlab = tan-1(1/βγ).
Bob S
θlab = tan-1(1/βγ).
Bob S
What do yu mean "can't" As in " if its not at an angle the photon won't make it through "
or that somehow it is not possible to align a tube orthogonal to the motion of the emitter?
Thanks
Thanks
If the tube is stationary in the lab frame, then it has to be aligned at an angle θlab = tan-1(1/βγ) relative to the direction of motion.. If the tube is stationary in the rest frame of the emitter, it has to be aligned orthogonal to the direction of motion.
Bob S
Bob S
Hi Bob S I am sorry but I am still unsure as to your meaning.
1) It has to be aligned at angle tan-1(1/βγ) in order for the photon to make it through??
2) If it is orthogonal to the motion of the emitter in the lab frame , the photon will not get through to the detector??
So are both of these true?
Thanks for your patience
(1) is always true: "aligned at angle tan-1(1/βγ) in the lab frame".
(2) is always true, unless the emitter is at rest in the lab frame.
[added] See thumbnail
Bob S
Bob S
The equation you quote is correct for the angle of the photon's trajectory relative to the motion in the lab frame, but the tube does not rotate in the way your diagram suggests. See the attached modified diagram for what actually happens.
If the tube is aligned orthogonal to the direction of motion in the CM system, and a photodetector at the end of the tube verifies that the emitted photon reaches the photodetector, then any observer in any moving reference frame will also observe that the photon does indeed reach the photodetector. So how can you say that an observer in a moving reference frame will see the photon blocked by a misaligned tube? Or are the laws of physics different in different reference frames?
Because the photon velocity is the same in all reference frames, the observer sees the photon at different locations at different times depending on time of flight, and her distance from the location of the photon. The same holds for the absorbing tube. So maybe the Terrell effect is relevant. In any case, all observers will agree that the photon hits the detector.
Bob S
Bob S
I agree that all observers will agree that the photon hits the detector. I did not say the the photon is blocked by a misaligned tube. It is not blocked despite being misaligned! You can see this if you actually look at the diagram I uploaded (and I assume you have not, because the image has had zero views so far). The photon travels diagonally in the lab frame while at the same time traveling up the length of the moving tube and eventually arriving at any detector located on the far end of the tube.
Think of the famous light clock example. Let us say the mirror is at the top of the tube as the tube goes from left to right in the lab frame. If the tube had to tilt to accommodate the diagonal light path in the lab frame, it would have to tilt one way as the light pulse went on its outward journey and tilt the other way when the photon is on its return journey. This obviously does not happen.
I did look at your thumbnail before, and I just did again. I now understand what you are saying, and I think you are right. But this is not what the observer in the lab frame actually sees, however, because according to the Terrell rotation effect, the tube will appear rotated to the observer. This simple movie of a relativistic tram going from right to left shows the observer's view of the tram apparently rotating, so the observer sees the back side of the tram as it passes. Without Terrell rotation, the observer would not see the back at all.
http://www.anu.edu.au/physics/Searle/Tram_fast.mpg
Bob S
Bob S
Thanks Bob S It appears to me that kev is talking about a different thing.
As I understand your diagram the angled tube is stationary in the lab frame .
In kevs diagram the tube is stationary in the emitter frame. In that case there has never been a question about it reaching the detector.
So am I correct in thinking that if the tube is orthogonal in the lab frame no photon emitted at any angle from the moving emitter can reach the detector at the end of the tube?
I think the Terrell effect as perceived in the emitter frame would make the tube in the lab appear tilted forward on approach and even more forward [away from the observer] on reccession. And likewise from the lab if the tube is in the emitter frame.
Thanks for your helpful time
This is false, light does not act like a "Newtonian" and most definitely photons are not "massive"
No, this is also false.
This is incomprehensible.
This is also false since there is a whole class of experiments on this subject that falsifies the above statement.
No, the "physical cap of c" does not prevent conservation of momentum. Conservation of momentum, as explained by DrGreg, is a general law.
What is this supposed to mean?
Yes.
The tube rotates in the moving frame , this was established in the another thread on the Thomas-Wigner rotation. In fact, the Terrell-Penrose effect is nothing but another facet of the Thomas effect.
The light beam also appears inclined in the moving frame due to the well-known effect of aberration. For the particular case of light traveling along the y-axis in frame S, it will travel at an angle [tex]cos(\theta')=\frac{cos(\theta)+\beta}{1+\beta cos(\theta)}=\beta[/tex] with axis Ox' in frame S'. This is exactly the same angle the tube rotates as well, so both light beam and the tube rotate by [tex]\theta'=arccos(\beta)=arctan(\frac{1}{\beta \gamma})[/tex]. So the photon does not hit the sides of the tube in either frame S or S', it travels perfectly centered along the axis of the tube in both frames.
ETA : If it iwere any different we would have devised an experiment that violates PoR :-)
SO in the actual context of the question are you saying that a photon does not conserve the forward momentum of the source motion??
In this context how is the motion path of a photon different from a Newtonian massive particle?
How can this stated possibility be definitively false. Especially given the equivalence of mass and energy
No rest photons= no rest mass to measure. But electrons and atoms react to the imparted momentum so it is not completely off the wall to consider there might be equivalent mass , in which case it is a matter of convention that they are regarded as massless.
I think these experiments were related to light parallel to motion. My comment was not made in reference to light speed independence from the motion of the source but wrt to the conservation of the source foward motion wrt photons emitted transversely.
In this instance it is not the general law under discussion but a specific limited aspect.
The constancy of the speed of light itself means that emissions in the direction of motion cannot conserve the forward motion of the source as would be the case with unlimited speed and simple additive velocities. No?
See below
Thanks
starthaus said:
Yes.
So far you have said nothing constructive to add to my understanding.
Perhaps you might have some insight on the question below??
Austin0 said:
Given the picture I have so far it would seem impossible for any photon to have a straight linear path orthogonal to the emitter motion as observed in any other frame.
That if there is a light detector at the end of a long light absorbtive tube aligned directly perpendicular to the source motion but in another frame, that it would seem impossible for a photon to reach the detector??
  • · Replies 21 ·
  • · Replies 159 ·
11K
  • · Replies 16 ·
