Derivation of Hyperbolic Representation from Lorentz/Minkowski equations in SR
The discussion focuses on the derivation of hyperbolic representations from the Lorentz and Minkowski equations in special relativity. Participants explore the algebraic and hyperbolic forms of these equations, emphasizing the invariance of the Minkowski metric and the relationship between rapidity and hyperbolic functions. A key point is the difficulty in transitioning from the algebraic to hyperbolic forms, with various attempts to clarify the connections between the equations. The conversation highlights the importance of precise definitions and the correct application of hyperbolic identities to establish the necessary relationships. Overall, the thread illustrates the complexity of these transformations and the need for a deeper understanding of hyperbolic functions in the context of relativity.
stevmg
This is a carryover from a previous thread:
https://www.physicsforums.com/showpost.php?p=2875138&postcount=68
Sports Fans:
I am familiar with the Minkowski equations and the Lorentz transformations in one or two dimensions:
A) In algebraic form
(1) t2 - x2 = t'2 - x'2
(2) t' = \gamma(t - xv/c2)
(3) x' = \gamma(x - vt)
Now, by using equations (2) and (3) and doing the right substituions, one gets equation (1) and by starhaus:
starthaus said:
The standard interpretationfollows correctly from the INVARIANCE of the Minkowski metric as follows:
(c d \tau)^2=(cdt)^2-dx^2
I am sure I have demonstarted this before.
Thus \tau^2 is invariant which is saying the same thing, no matter where on the hyperbola your x and t are, wherever you go on that same hyperbolic curve, t^2 - x^2 = \tau^2
Notice I am using the timelike format.
Now, the equivalent Lorentz equations in hyperbolic format are:
B) In hyperbolic form.
(4) t' = -xsinh \vartheta + tcosh \vartheta
(5) x' = xcosh \vartheta - tsinh \vartheta
where
(6) sinh \vartheta = (v/c)\gamma
(7) cosh \vartheta = \gamma
and where
(8) \vartheta = tanh-1(v/c)
Now, I have tried, tried and tried and I cannot get from A) to B)
In the figure posted we have the t-axis vertical and the x-axis horizontal and this is a time-like representation:
In this equation that starthaus presented:
c2t2 - x2 = \tau^2
\tau should be the t intercept at x = 0
any point on the hyperbola should be represented by the parametric equations of
x = \tausinh \phi and
t = \taucosh \phi
where tanh-1 \phi = x/t for any point (x, t) on the hyperbola
How do I make the connection?
Hey, didn't I tell you that once already? :biggrin:
https://www.physicsforums.com/showthread.php?p=2678572
(Start at "This is what I wrote in my notes:". After the first sentence, you can skip the stuff about adding velocities, and continue at "The definition of rapidity...".)
You have explicitly stated c in some equations, but not in others. Here are the same equations with all the c's explicitly stated:
(1) (ct)2 - x2 = (ct')2 - x'2
(4) t' = t cosh \vartheta - (x/c) sinh \vartheta
(5) x' = x cosh \vartheta - ct sinh \vartheta
where
Now starting from the Lorentz transformation for time:
t' = \gamma(t-xv/c) = t(\gamma) - (x/c)(v/c)\gamma = t\, cosh\, \vartheta - (x/c)\, sinh\, \vartheta
which is (2) --> (4)
and starting from the Lorentz transformation for distance:
x' = \gamma(x-vt) = x(\gamma) - (vt)\gamma = x(\gamma) - ct(v/c)\gamma = x\, cosh\, \vartheta - ct\, sinh\, \vartheta
which is (3) --> (5).
Now I am sure you are looking for something much deeper than that, but I thought we might as well get the algebraic relationship between the hyperbolic and regular expressions established in a (hopefully, barring typos) consistent way first.
t = \taucosh \phi
I think that should be:
x = c\tau sinh \phi and
ct = c\tau cosh \phi
where tanh \phi = x/(ct) = v/c = \beta for any point (x, ct) on the hyperbola.
(not tanh-1)
Fredrik -
That post: https://www.physicsforums.com/showpost.php?p=2678572&postcount=36 is way beyond me. This may disqualify me from going further but that is the case.
I haven't a clue what you wrote. Might as well be speaking Martian or some other alien tongue.
Doc
stevmg
(1) c2t2 - x2 = c2t'2 - x'2
(2) ct' = (ct - xv/c2)
(3) x' = (x - vct)
(4) t' = -xsinh \vartheta + ctcosh \vartheta
(5) x' = xcosh \vartheta - ctsinh \vartheta
where
and where
(8) tanh \vartheta = (v/c), or \vartheta = tanh-1 (v/c). The arctanh of v/c is \vartheta
Is that better?
Now, get me going as if I cannot further progress than this, there is NO POINT in you wasting your time in trying to explain it to someone with subnormal intelligence (in physics) such as me.
I wish I could get those damn quotes within quotes as you have done.
I will try but it will take thirteen forevers with edits and re-edits to try and I guaranatee you no success.
Go to post #7 below
Continuation from post #6 above,
I still can't get from A) to B) so my error isn't withing the typos but within the brain!
Doc
(by the way, when you address me in a post you can and should call me "Doc" as that's what everyone in the Air Force used to call me (better than some of the other phrases that I can't repeat here on PF.)
stevmg
stevmg said:
Fredrik -
Doc
stevmg
I didn't expect you to understand all of it, but I'm surprised that you that you claim to understand nothing of it. This is the essential part:
Fredrik said:
v^2=\tanh^2\phi=\frac{\sinh^2\phi}{\cosh^2\phi}=\frac{\cosh^2\phi-1}{\cosh^2\phi}=1-\frac{1}{\cosh^2\phi}
\frac{1}{\cosh^2\phi}=1-v^2=\frac{1}{\gamma^2}
\cosh\phi=\gamma
\sinh^2\phi=\cosh^2-1=\gamma^2-1=\frac{1}{1-v^2}-\frac{1-v^2}{1-v^2}=\frac{v^2}{1-v^2}=\gamma^2v^2
\sinh\phi=\gamma v
What part of that is impossible for you to understand? The third and fifth lines are the results that take you from A) to B).
Explanation of the equalities:
First line: 1) Definition of rapidity (\tanh\phi=v). 2) Definition of tanh. 3) The identity \cosh^2x-\sinh^2x=1, which is easy to derive from the definitions of sinh and cosh. 4) For all real numbers A,B with A non-zero, we have (A+B)/A=1+B/A.
Second line: 1) The result from the first line. 2) Definition of \gamma.
Third line: 1) The square root of the result in the second line.
Fourth line: 1) The identity \cosh^2x-\sinh^2x=1 again. (\cosh^2 should of course be \cosh^2\phi. I left out the variable by accident). 2) The result from the third line. 3) Definition of \gamma and the fact that 1=A/A for all non-zero real numbers A. 4) For all real numbers A,B,C with C non-zero, we have A/C+B/C=(A+B)/C. 5) Definition of \gamma.
Fifth line: 1) The square root of the result in the fourth line.
Fourth line: 1) The identity \cosh^2x-\sinh^2x=1 again. 2) The result from the third line. 3) Definition of \gamma and the fact that 1=A/A for all non-zero real numbers A. 4) For all real numbers A,B,C with C non-zero, we have A/C+B/C=(A+B)/C. 5) Definition of \gamma.
I'll download it to paper and with my calculus book that goes into hyperbolic functions and their derivatives I will pour over it until it sticks in my brain.
Below, I have posted a part of a lecture that sort of proves it, too but this author just made a wild a-- guess which turns out to be true (equation 32) or \beta = v/c which is just a WAG. Nothing like knowing the answer before you take the test. How do you think we doctors got through medical school? Certainly not on out of genius.
I wouldn't describe (32) as a guess. It's the definition of rapidity. (The same one I'm using, except that I'm calling it \phi instead of \beta. I don't like calling it \beta, because \beta is often defined as v/c). Of course, when it's presented this way, it looks like we were just lucky that the definition turned out to be useful.
Fredrik said:
Note that I'm using units such that c=1. Keeping that c around is like putting something sharp in one of your shoes before you go out running. It's a pain with no benefits.
I actually made the edit that added the quote above before I saw this below: :smile:
yuiop said:
LOL. Pesky c's. Missed a couple myself.
LOL. Pesky c's. Missed a couple myself. Things are still not quite right.
(3) x' = (x - vct)
where
and where
Is that better?
should be (2) ct' = \gamma(ct - xv/c)
(3) x' = (x - vct)
should be (3) x' = \gamma(x - vt)
should be (4) ct' = -x sinh \vartheta + ct cosh \vartheta
For some reason you dropped some gammas too, that I have put back in. You can probably go from there now.
(1),(5),(6),(7) and (8) are OK.
I have edited post #3 for the "c" I missed in equation (1) so all the equations in #3 should be exactly correct now, but they are presented slightly differently to the equations presented here.
The complete and hopefully finally correct set of equations should be:
(9) x = c\tau sinh \phi
(10) ct = c\tau cosh \phi
(If they are not correct, PM me. We can't spend the whole thread correcting typos :-p )
To yiuop and Fredrik -
Using the equations (ct)^2 - x^2 = \tau^2 I KNOW there has to be a more direct and intuitive way to prove the hyperbolic assertions.
Using the timelike diagram where the ct axis is up and down and the x-axis ls the left and right, sinh \vartheta = x/\tau and cosh \vartheta = ct/\tau there has got to be a way of working v and c into this.
x = \tau sinh \vartheta and t = \tau cosh \vartheta
tanh \vartheta = x/t
\vartheta = arctan x/t
Now, let's get from x/t to v/c
Everyone, go to post 12 above. All else is superfluous. I could not edit, correct and re-edit in time.
Doc
This is the equation of a specific hyperbola in the diagram, so it's not a good starting point if you want to find a result that's valid for all events in the diagram.
I would say that about post 8. I think you should start by writing down the definitions of sinh, cosh and tanh, and using them to prove that cosh2x-sinh2x=1 for all x. Then study every equality in post 8 carefully. I don't think there is a way to do it that is simpler than the way I did it.
Perhaps we should start with two images:
Source: http://hubpages.com/hub/Hyperbolic-Functions
Maybe this is a place to start (using c=1 as recommended by Fredrick :wink: ).
The hyperbolic identity (similar to the trigonometric identity) is defined as:
cosh^2(\phi) - sinh^2(\phi) = 1
From this we can create:
\tau^2 cosh^2(\phi) - \tau^2sinh^2(\phi) = \tau^2
We also know the Minkowski metric is:
t^2 -x^2 = \tau^2
So we can say:
\tau^2 \, cosh^2(\phi) - \tau^2 \, sinh^2(\phi) = t^2 -x^2
From the above equation it is easy to make the natural associations:
\tau \, cosh (\phi) = t
\tau \, sinh(\phi) = x
and:
v = \frac{x}{t} = \frac{\tau \, sinh(\phi)}{\tau \, cosh(\phi)} = tanh(\phi)
Now we already know that gamma is equal to t/\tau so from \tau \, cosh(\phi) = t we can get cosh (\phi) = (t/ \tau) \rightarrow \, cosh(\phi) = \gamma and from \tau \, sinh(\phi) = x we get sinh(\phi) = (x/\tau) = \gamma(x/t) = \gamma v which is the celerity or proper velocity (w). The mysterious quantity \phi is defined as the hyperbolic velocity angle or rapidity and is obtained from the preceding equation as \phi = asinh(w). The rapidity can also be obtained in various other forms from any of the earlier equation that include \phi.
Passionflower - I have seen those diagrams at hubpages before
How does that get one from
Now, let's get from x/t to v/c?
Make the connection for me. Right now all I see is "true - true - not related."
Doc
yiuop, I again remove the quotes so that we have the text in "real time" and we can work with it, is that OK? You liked that as I used it before and also I tried your "quotes within quotes" and it didn't work for me, as nothing ever does.
cosh^2(\phi) - sinh^2(\phi) = 1 - OK, even though I am not being sarcastic, that's rocket science!
\tau^2 cosh^2(\phi) - \tau^2sinh^2(\phi) = \tau^2 beautiful!
t^2 -x^2 = \tau^2 Thank God for starthaus!
So we can say:
\tau^2 \, cosh^2(\phi) - \tau^2 \, sinh^2(\phi) = t^2 -x^2 by algebraic substitution
Now, where does this come from?
Oh yes! I think I postulated that in my prior post but that was based on the geometry of (ct)^2 - x^2 = \tau^2. That's the basic geometric definitions of hyperbolic cosines and sines.
and:
By algebraic division and equality. Good, so far we are on the exact same page. Ge that, folks? v = x/t
Now we already know that gamma is equal to t/\tau How did we get this?
is that because \gamma = 1/\sqrt{1 - v^2)} We are assuming c = 1 for ease of calculations
= t/\sqrt{t^2 - x^2)}
= t/\tau
THERE! I was right! It is s-o-o-o nice to be such a genius!
so from \tau \, cosh(\phi) = t we can get cosh (\phi) = (t/ \tau) \rightarrow \, cosh(\phi) = \gamma and from \tau \, sinh(\phi) = x we get sinh(\phi) = (x/\tau) = \gamma(x/t) = \gamma v which is the celerity or proper velocity (w). The mysterious quantity \phi is defined as the hyperbolic velocity angle or rapidity and I already knew this. starthaus got me going on this - a way of adding up velocities in hyperbolic functions directly is obtained from the preceding equation as \phi = asinh(w). The rapidity can also be obtained in various other forms from any of the earlier equation that include \phi.
Now, Passionflower, starthaus, DrGreg, et al... This is what I have been looking for!
You have to approach me like I'm four years old and assume I know less than nothing, because that's true. What is obvious to you and unspoken is totally oblivious to me. But guess what now? It isn't any more because I was brought from A \rightarrow B and could understand every algebraic step on the way and it was intuitive. I AM teachable. Lot of work, but it can be done!!
You know something, if I ever got to learn this stuff I would be the best damn teacher in the world because I would know every nook and cranny and blind alley the students would go through and would know how to get them out of it. When I taught medicine, I was the same way. I read every pertinent text and made every mistake you could make so when my students and residents made mistakes I was already there, knew what they did wrong, why they did it wrong and got them going on the right track.
Such is the price of a learning disability, when you get it right, you really get it right.
yiuop, DrGreg, Passionflower, starthaus - thanks for your help. Couldn't have done it without you.
Doc
Start doing what? It's not clear what you're trying to do in this post. Are you trying to explain how someone who hasn't yet done the calculations I did in #8 might have guessed that \tanh\phi=v would be a useful definition?
t^2 -x^2 = \tau^2
This is just the equation of a hyperbola. If you're going to use it, you should explain why it's relevant. The Minkowski metric has the property that such hyperbolas are preserved by linear transformations that preserve the metric (i.e. Lorentz transformations), but is that relevant for what you're trying to do?
I don't see how those diagrams could be helpful. Doc, what you want to prove is a simple algebraic fact. You just want to show that the definition \tanh\phi=v implies \cosh\phi=\gamma and \sinh\phi=\gamma v. The easiest way to do that is to do exactly what I did in #8. I explained every equality in that post, so there's no reason for you to ignore it.
Fredrik - not ignoring it. Have downloaded it onto paper and will pour over it.
Do not avoid your input into my future threads or postings. Trust me - all is appreciated and so is yours (most highly, I say.)
And thanks for calling me "Doc" - reminds me of the good old days when the troops called me that as I was their "father protector."
Doc
Fredrik -
I have not ignored what you posted and have included it below in all germane posts regarding the subject from you. I will place the quotes in this post and then, in the following post (so that I can get PF to "swallow it" without kicking me out as too long) I will discuss it.
Fredrik said:
Stevemg, the Minkowski bilinear form g (I won't call it a scalar product, or an inner product, since it isn't positive definite) is defined by
g(x,y)=x^T\eta y
I usually take
\eta=\begin{pmatrix}-1 & 0 & 0 & 0\\ 0 & 1 & 0 & 0\\0 & 0 & 1 & 0\\0 & 0 & 0 & 1\end{pmatrix}
to be the definition of \eta, but you could choose the opposite sign if you want to. This wouldn't change any of the physics. It would just change a few signs here and there. The two different "norms" (they're not really norms, since they're not positive definite) are just different choices of what sign to use in the definition of \eta.
My definition above is more common in GR books, and the opposite sign is more common in QFT books. Some people prefer to write \langle x,y\rangle instead of g(x,y).
Since you have taken an interest in the concept of rapidity, you may find the notes I made for myself useful. Note that I'm using units such that c=1. Keeping that c around is like putting something sharp in one of your shoes before you go out running. It's a pain with no benefits. This is what I wrote in my notes:
In special relativity, we define the rapidity \phi of a particle moving with velocity v by \tanh\phi=v. Note that the rapidity and the velocity are approximately the same when the velocity is small. To be more precise, in the limit \phi\rightarrow 0, we have v=\phi+O(\phi^2).
The concept of rapidity is useful because it's easier to "add" rapidities than velocities. If the velocity of frame B in frame A is v, and the velocity of a particle in frame B is v', then the velocity of the particle in frame A is
v\oplus v'=\frac{v+v'}{1+vv'}
If the rapidity of frame B in frame A is \phi, and the rapidity of a particle in frame B is \phi', then the rapidity of the particle in frame A is just \phi+\phi'. This follows from the velocity addition formula above, the definition of rapidity, and the identity
\tanh(\phi+\phi')=\frac{\tanh\phi+\tanh\phi'}{1+\tanh\phi\ \tanh\phi'}
The definition of rapidity also implies that
\cosh\phi=\gamma=\frac{dt}{d\tau}
\sinh\phi=\gamma v=\frac{dx}{d\tau}
Proof:
\cosh\phi=\gamma
\sinh\phi=\gamma v
\tau=\int\sqrt{dt^2-dx^2}=\int dt\sqrt{1-\dot x^2}=\int\frac{dt}{\gamma}
\frac{d\tau}{dt}=\frac 1 \gamma
\frac{dt}{d\tau}=\gamma=\cosh\phi
\frac{dx}{d\tau}=\frac{dt}{d\tau}\frac{dx}{dt}=\gamma v=\sinh\phi
These results enable us to express an arbitrary proper and orthochronous Lorentz transformation as a hyperbolic rotation by an "angle" equal to the rapidity.
\Lambda=\gamma\begin{pmatrix}1 & -v\\ -v & 1\end{pmatrix}=\begin{pmatrix}\cosh\phi & -\sinh\phi\\ -\sinh\phi & \cosh\phi\end{pmatrix}
stevmg said:
Cyosis -
Would this be the correct representation with the hyperbolic functions?
<br /> \begin{pmatrix}<br /> ct&#039; \\ x&#039;<br /> \end{pmatrix}<br /> <br /> =<br /> <br /> \begin{pmatrix}<br /> \cosh \(arctanh(v/c) &amp; -\sinh\(arctanh(v/c) \\<br /> -\sinh\(arctanh(v/c) &amp; \cosh\(arctanh(v/c)<br /> \end{pmatrix}<br /> <br /> \begin{pmatrix}<br /> ct \\ x<br /> \end{pmatrix}<br />
If this is the case, then all one would have to do is look up the arctanh of v/c or (\beta) and plug that into the cosh and sinh to get your matrix. That can be done on a scientific calculator directly.
Yes, but if you look at my last equation before the quote, I'm sure you'll see an easier way. :smile:
Go to post #23, https://www.physicsforums.com/showpost.php?p=2877552&postcount=23
Doc
Continued from post #22 above, https://www.physicsforums.com/showpost.php?p=2877463&postcount=22
Fredrik-
I tried numerous times to answer you but PF would not let me continue with symbols, even with small posts as it would lock up and go no further. Very frustrating.
You have the posts I quoted above. I will write out what I was trying to say but "in prose" as the symbols do not work.
Basically we have the equation of a hyperbola tau^2 = t^2 - x^2 (for below, tau = SQRT(t^2 - x^2) with y intercept of +- tau at x = 0. There are no x-intercepts.
sinh phi = x/tau
cosh phi = t/tau, tanh phi = x/t
gamma = 1/SQRT(1 - v^2)
If v = x/t, tanh phi = x/t = v (this is "proven" and not assumed)
Then gamma = 1/SQRT(1 - x^2/t^2) = t/tau
Substituting back into the Lorentz transformations:
x' = xt/tau - v(t/tau)t = xcosh phi -tsinh phi
t' = (t/tau)t - (t/tau)xv = tcos phi -xsinh phi or the more familiar -xsinh phi + tcos phi which can be represented in matrix format which I cannot do as yet on PF.
This makes intuitive sense. For a given tau we have a hyperbola which represents all x's and t's which are different coordinates in different frames of reference but which "go back" to the same "proper time" or "tau." If one were totally inertial and not moving, x would = 0. If one were moving, for the initial FR where x does = 0, then any x and t on the hyperbola would represent the coordinates which would calculate back to that initial inertial frame where x = 0. It would take a speed of x/t = v to get to that point from x = 0 and t = tau.
I hope this makes sense and there are no assumptions other than what Minkowski himself projected that tau^2 = t^2 - x^2.
This is for timelike phenomena. Spacelike should be similar but the t's and x's would be reversed and the hyperboa would be "left and right" and a proper distance would be
distance^2 = x^s - t^2 and x = tau cosh phi while t = tau sinh phi.
I hope I am right.
Doc
That was a freakin' bear!
By the way, what is this "\Lambda" from the above post with the matrices? I've seen it before but haven't got a clue what it represents!
stevmg
Doc
\Lambda is a common symbol for the matrix form of the Lorentz transformation.
\Lambda is the uppercase version of the greek letter "lambda", and I used it the way jtbell described. Regarding your problem with "symbols", you're probably just experiencing the latex preview bug that's bothering all of us the same way. The only workaround is to refresh and resend after each preview. (I haven't read the rest of your post yet. Give me a few minutes to do that).
That's the equation of a hyperbola alright, but I don't know why you're considering a specific hyperbola.
stevmg said:
sinh phi = x/tau
What are you doing here? Are these supposed to be definitions, calculations, or guesses?
This is the standard definition of \gamma.
It looks like you're just writing down the same equalities you wrote down earlier, so I don't see what you have proved, or how you did it.
Here it looks like you have used v=x/t, t^2-x^2=\tau^2, t>0 and \tau&gt;0, but that means that your "proof" is only valid for the specific event (t,x) that lies at the t>0 intersection of the line t=x/v and the hyperbola t^2-x^2=\tau^2.
I tried refreshing, resending, etc and the website would freeze and not let me go further. It wasn't just a mix-up of symbols as used to happen. Maybe it is my proxy server.
I used the general equation of a hyperbola. In this sense
t2 - x2 = t'2 - x'2 which is from Einstein's book on Relativity. This demonstrates the invariance of time2 - distance2. This should be proper time for a given family of points in (t, x). i.e., all the points on a hyperbola that satisfy a specific invariance as defined should all give the same \tau^2.
Oh well, enough for now. My brain cannot absorb any more today. As I have said before in prior posts, I have nobody local to talk to (that can give quick fixes) or go over scenarios with so it is a very stoccato way of learning and tedious.
The reason I think you shouldn't be looking at specific hyperbolas, fancy diagrams, results from special relativity, etc., is pretty simple. All you want to do is to prove the following claim:
\text{If }\tanh\phi=v\text{ and }\gamma=\frac{1}{\sqrt{1-v^2}}\text{, then }\sinh\phi=\gamma v\text{ and }\cosh\phi=\gamma.​
This requires absolutely no knowledge of special relativity; it doesn't involve physics in any way. In fact, it would be wrong to use any knowledge of physics when you do this.
You only need to use the identities
\tanh x=\frac{\sinh x}{\cosh x}
\cosh^2x-\sinh^2x=1
The first is just the definition of tanh, and the second is very easy to prove from the definitions of sinh and cosh. The definitions are
\sinh x=\frac{e^x-e^{-x}}{2}
\cosh x=\frac{e^{x}+e^{-x}}{2}
\cosh^2x-\sinh^2x=1
Yea, I got that:
If one chooses tanh \phi = v We will use v instead of \beta because it is easier to write
then tanh \phi = sinh \phi/cosh \phi = v
cosh^2 \phi - sinh^2 \phi = 1
1 - tanh^2 \phi = 1/cosh^2 \phi
1 - v^2 = 1/cosh^2 \phi
cosh \phi = 1/\sqrt{(1 - v^2)} = \gamma
sinh^2 \phi = 1 - cosh^2 \phi, sinh^2 \phi = 1 - \gamma^2 = (1 - 1 + v^2)/(1 - v^2)
sinh \phi = v/\sqrt{(1 - v^2)} = v\gamma
Thus the standard hyperbolic Lorentz transformations are proven.
x&#039; = xcosh \phi - tsinh \phi
t&#039; = tcosh \phi - xsinh \phi
x&#039; = \gamma x - \gamma vt
t&#039; = \gamma t - \gamma xv
Thus, choosing tanh \phi = v is an educated guess which makes things work out. We started with the conclusion and worked backward through logically equivalent statements until we arrived at the original Lorentz transformations. This technique is oft used in mathematics but one must be careful so as to use a series of logically equivalent statements.
What I mean by logically equivalent statements is
A \Leftrightarrow B
B \Leftrightarrow C
C \Leftrightarrow D
D \Leftrightarrow E
In this case we start at D \Leftrightarrow E and work backwards to A \Leftrightarrow B
So, I was mistaken in looking for a hyperbola to match the hyperbolic functions.
According to yuiop on post # 11: https://www.physicsforums.com/showpost.php?p=2876438&postcount=11
one does exist but I probably read his post wrong.
stevmg
Doc
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 29 ·
