Physics Forums photography thread and image sharing
1,418 replies · 277K views · last reply
A neat idea to test the extremes, I tried the dining area for that,
(all shots converted RAWs from the defaults, no post processing)
First with the Tokina 12-24mm at 12mm (equivalent to 19mm FX format):
Dining room with a long wooden table, brown upholstered chairs, a glass tulip centrepiece and a pendant light, plus a close crop of a pink orchid and a green glass bottle on a wooden tray.
The aperture was 5.5 and it was focussed manually more in front to optimize depth of field as can be seen on the center crop and the little bottle down and slightly right off center.
Then from the same tripod position the 70-300mm zoom at 300mm (FX equivalent 480mm) F5.6 again:
Two photos stacked: a close crop of a magenta orchid showing a dark red lip with yellow-orange speckled center; below, a pink phalaenopsis orchid bloom with a dark red center on a bent stem, against white window blinds.
The center crop is not too crisp, but that was to be expected.
I also wanted to know if I should use the 100mm macro lens some more for shots that were taken with the 70-300mm. So I wanted to know how those two compared under the same condition, for that I made this shot, close at minimum range for the 70-300mm with both lenses (F6.7):
Close-up of a branch with two pink orchid flowers with dark red centers, several unopened reddish-purple buds, against a blurred grey slatted background.
Interestingly you have to zoom to 90mm to get the same image as the 100mm macro. The reason for that is that the macro lens does not change it's length during focussing, so what it actually does, is changing its focal length.
Anyway, compare center crops of both lenses:
Close-up of a magenta phalaenopsis orchid showing a dark red lip with a yellow-orange crest flecked with red spots, and pale pink petals beside it.
Close-up of a magenta orchid flower showing a dark red-purple lip with dark spots and a yellow-orange center.
Can you tell, which is the better lens? I can't
Surprisingly, the 70-300 seemed to have produced the sharper result albeit by a tiny notch :rolleyes: Maybe the 100mm needs some micro adjusting
Andy Resnick said:
Based on the star images, I suspect my main culprit is mirror flap- the stars consistently got distorted into short lines, even for 1/10 second shutter speed- and the lines were always the same length and orientation
7.3 microradians, perhaps :biggrin:
<snip>
<snip>
The upper image appears brighter and more vivid- is that an aperture difference?
Good question- I'm not sure what the subtended angle is. Let's see: 800mm on a 35mm frame gives a total subtended angle of 2.5 degrees, and given the sensor format (6k x 4k, 7200 on the diagonal), each pixel subtends about 1.25 arcseconds (6 microradians). By my count, the 'fundamental' streak length is about 30 pixels, or 0.18 milliradians (0.6 arcminutes).
So there's a lot of room for improvement.
Curious, isn't? However, everything was identical, including the flash settings. Yet he colors are clearly different. Here are both orginal jpg's with EXIFs, slightly higher compressed to limit filesize.
http://dl.dropbox.com/u/22026080/70-300.jpg
http://dl.dropbox.com/u/22026080/100.jpg
No, actually I don't use filters at all. I am hoping one day to upgrade to a much better camera, but for now I'm using a Canon Powershot a520 and adjusting the contrast on my computer. Thank you for the complement. Oh and I always shoot my photos in color and change them to black and white later. I do this just in case the color version looks better in the end.
Hi, Andy. The moon is out, so a couple of minutes ago, I shot this. 1600 ISO to minimize atmospheric refraction and (human) shake. 100-400mm Canon L lens at full zoom, hand-held (no bracing of any kind) and cropped hard. I got a tad of color-noise at that ISO, so I converted the image to grayscale, since the Moon is a pretty white-gray place. Not the same quality that I could get with one of my APO refractors, but not bad for strolling (limping, actually) out onto the back deck and making a snapshot. The moon is a pretty featureless (low contrast) place when it is nearly full, but check near the lower limbs.
Grayscale photo of a gibbous Moon against a black sky, showing dark maria and bright highlands with crater detail near the edges.
Nice!
I've been working with the 400mm lens today (and dodging raindrops)- with the teleconverter, the image is soft until I set the lens to f/8- then it's incredibly sharp (that is, an 800mm f/16 lens). Without the teleconverter, the image is much sharper always, and gets tack-sharp around f/4.
Consistently, any point-like 'sparkles' get rendered as short lines, always in the same orientation and length. This supports my idea of lens flap, but I won't know for sure until I can remotely trigger the shutter.
Another moonshot made around midnight last night. Hardware the 7D with the 70-300mm at full tele
Exposure manual trial and error, I ended up with this ISO 100 F6.7 Shutter 1/180
Raw processing: a tad more sharpening. contrast high tones priority and noise reduction off
100% size crop:
Nearly full moon photographed against a black sky, showing dark maria and bright highlands with crater detail across the disc.
The glass keeps amazing me.
I planned to take a picture as well, but it was hazy. Seems like tonight can be better.
The weather was highly cooperative this past weekend, and I was able to spend time sussing out the 400mm. There's definitely a 'sweet spot' to use the lens- in terms of shutter speed, either < 1/60s or >0.5s overcomes the mirror flap issue, and > f/5.6 gives tack-sharp images.
Here's the full moon last night, 100% (sorry, it's a bit over 650 pixels on a side): This was taken at 400mm, f/11, ISO 100, 1/80s
[PLAIN]http://img25.imageshack.us/img25/9360/dsc6119.jpg
Looking carefully at the limb, you can see atmospheric effects- the atmospheric currents act like a lens, creating a 'mirage' kind of flicker. At 800mm, the effect is very pronounced (100% crop): 800mm, f/5.6, ISO 100, 1/80s:
[PLAIN]http://img849.imageshack.us/img849/1358/dsc61261.jpg
It was pretty cool to watch through the lens, even though it limited the ultimate resolution.
I was able to get an acceptable image of Mizar (300% cropped image): 800mm, f/5.6, ISO 6400, 1/80 s:
[PLAIN]http://img685.imageshack.us/img685/9362/dsc6134.jpg
I can tell it's a multiple, but perhaps not that it's a double binary. Atmospheric blurring is quite obvious here.
iBOOM said:
I really love the moon photos :O
They are the first real astrophotos that most amateurs could make during the age of photographic films. Sometimes, purists got wrapped up in trying to capture fainter and fainter stuff, so Moon photography fell out of favor, especially since the extra light would wash out faint details on long-exposure astrophos of galaxies, globulars, nebulae, etc. Now, technology allows photographers to take Moon shots as snapshots. That's a pretty good thing. The Moon is our closest neighbor and it changes from night to night. You don't have to set up a $$$$ telescope and accept washed-out astrophotos of faint objects on nights when the Moon is up. It took me probably 30 seconds total to grab a couple of snapshots.
It always feels good to solve a problem. Here's a 100% crop taken through the 800mm with a shutter speed of 1/6s (10-second delay) of the label on a nitrogen tank in the lab (from across the room):
[PLAIN]http://img98.imageshack.us/img98/3740/dsc61401.jpg
The delay allows all transient vibrations to dampen out, but when the mirror comes up for exposure, the induced vibrations cause what you see above. 1/6s is about the worst-case scenario: long enough to really capture the vibration, and short enough to *only* capture an image while everything is moving. The workaround was to use either shutter speeds very fast or very slow- either using the lens wide-open with very high camera gains (ISO) to get the exposure time down, or use very high f/# to force long exposure times. Both introduce restrictions- long exposures mean the subject has to be motionless, while high ISO introduces a lot of noise and using the full aperture of the lens also maximizes the aberrations.
Adding the $9 remote shutter results in this image - again, 1/6s exposure, using the mirror lockup option and waiting 3 seconds between the mirror lock and exposure:
[PLAIN]http://img808.imageshack.us/img808/2161/dsc6141.jpg
I don't think the improvement could be any more dramatic.
Nice work, Andy. I knew about that problem too and I use a remote as well, locking the mirror, using the life view mode. Etc.
Recently I changed studio work by using the laptop as remote 'wired' control. It also locks up the mirror, ad it stores the image, where it should go anyway, directky on the computer.
Interesting idea- I don't know if I can computer-control the Sony, but there's a variety of ports on the body... I'm finally getting a dedicated TB hard drive for my photos, in any case.
Also- I very much enjoyed the museum pics. Your country is considerably more picturesque than Cleveburg.
Passiflora (also known as the passion flower or passion vine) bloomed today on my window sill:
Close-up of a pale green and white passion flower with purple filaments, three stigmas and stamens at its center, growing on a green vine in a pot.
Center of the flower - close-up:
Close-up of a passion flower (Passiflora) with pale green-white petals, purple filaments in a ring, and yellow-green stamens and stigma at the centre.
More fun with filters: I have a bunch of excess fluorescent filters left over from upgrading the microscope, and the results I got last week with the BG3 filter motivated me to try and use them. I seem to get decent results using bandpass filters at the extremes of color vision- center wavelengths shorter than 440 nm or longer than 650 nm- even very narrowband filters in the green-orange range excite multiple types of cones, so those monochrome images don't look much different than a (colorized) black and white image.
Hopefully this week or next I'll be able to measure how sensitive the Exmor is to different wavelengths (I'm not sure the bandpass values of the Bayer filter are standardized) to get an idea about how far out I can go. Some cameras (and independent repair guys) can remove the IR cut filter, but I'm not doing that. Ditto the UV: I'm not sure how deep the lens will pass, and I'm not about to take sandpaper to my lenses:
http://www.naturfotograf.com/uvstart.html
The image I submitted in this week's contest was taken with a excitation filter used for blue/violet excitation (436 +/5 nm, I think I quoted the FWHM incorrectly) at night- Hg lamps can be seen, but Na cannot. This one I took during the day- it was very overcast, but the open sky peeked through now and then:
[PLAIN]http://img806.imageshack.us/img806/3996/dsc6235.jpg
The red color is from (I suspect...) "blooming", which is a digital sensor phenomenon that occurs when the pixel wells are not fully zeroed out during a read- excess charge 'leaks' into neighboring pixels in the column.
http://learn.hamamatsu.com/articles/ccdsatandblooming.html
Becasue of the Bayer filter, the neighboring pixels are different colors, so the camera interprets the light as activation of the green/red pixels.
I also got some promising images using a 380 +/ 10 nm filter, but for various reasons the images are not worth posting here. Once I get a more reliable mounting scheme, I'll post a few.
I entered this one in the contest 'flowers for fukushima'. The orchids come from the local windowsil.
Close-up photo of a cluster of white phalaenopsis orchid blooms with yellow and orange centres on a dark green blurred background, with a thin stem at lower right.
Used the 100mm at 2.8 aperture for shallowest depht of field. Unfortunately my 50mm f1.8 lens is broken after a fall
Obviously the exposure is a real challenge, so I just took several shots in manual, each time checking the saturation of the white, it's a function on the camera, making pure white flashing, the idea is to minimize that, allowing only minor portions of pure white.
So in the bright sunlight that came down to 1/3000 of a second, but almost all the white has detail
Taking a picture of white flower petals so that there is a texture visible is tough, usually it looks just boring flat. Nice effect.
That's exactly what I do as well (same process for the blacks).
Also being busy in the yard, I found some lillies of the valley today, modestly tucked away somewhere in a corner (using the same exposure method):
Photo of a lily of the valley stem with several nodding white bell-shaped flowers, some still in bud, against a blurred dark green background.
Remember the orchid from this post?
Andre said:
... ..with both lenses (F6.7):
Close-up photo of a Phalaenopsis orchid spray with pink-purple flowers with red-magenta centers, several closed red-tipped buds, and dark brown stems against a blurred grey slatted background.
Well this is how it looks now;
Tinypic logo on a blue background with the message: THIS IMAGE OR VIDEO HAS BEEN MOVED OR DELETED
This time I "exposed to the right" and then processed the RAW back to normal. That should take care of some of the noise
For some reason, I wondered how an ant would see a lilly of the valley:
Close-up photo of a sprig of lily of the valley, with six small white bell-shaped flowers hanging from a green stem against a deep blue background.
100% crop:
Close-up of a white bell-shaped lily of the valley flower against a blue background, showing green stamens with pink-tinged tips inside the bloom.
Finally- a sunny day. I took the 400mm to the top of a parking garage to get a clear view of the city and then also down by the lakefront to get a few shots of the Terminal Tower:
http://en.wikipedia.org/wiki/Terminal_Tower
Here's a shot at 400mm, f/8, ISO 100, 1/160s
[PLAIN]http://img836.imageshack.us/img836/5038/dsc6587y.jpg
And then at 800mm f/16, 1/60s:
[PLAIN]http://img807.imageshack.us/img807/2146/dsc6591.jpg
and a 100% detail showing a tiny little observation room which I *have* to figure out a way to get into:
[PLAIN]http://img7.imageshack.us/img7/3082/dsc65911.jpg
Just like wideangle lenses distort perspective, telephotos also distort perspective, but the other way; parallel lines remain parallel, removing depth information. For the tower photos, it appears that I am (nearly) at the same height as the subject when in fact it is about 500 feet above me. Angled surfaces appear flattened as well- here's another top of an office building:
[PLAIN]http://img844.imageshack.us/img844/6278/dsc6592u.jpg
The side facing me appears vertical, when it is actually angled in- the overall roof shape is a pyramid.
Here's why telephotos are used for other purposes- this is a 100% crop from 1/2 mile-
[PLAIN]http://img856.imageshack.us/img856/9611/dsc6593.jpg
It's possible to see the individual slats in the blind.
Finally, here's a shot of the "5 mile crib"- the source of Cleveland's water supply. It's about 3 miles from the shoreline and 5 miles from me:
[PLAIN]http://img859.imageshack.us/img859/5762/dsc6579m.jpg
The image is actually quite sharp- the image displays "shimmer"- thermal currents in the air, caused by the sun warming the ground and water. Here's the 100% crop:
[PLAIN]http://img405.imageshack.us/img405/166/dsc6580t.jpg
I'll have to try this again on a calm day.
Why do you get that vignetting? Are you using a crop sensor lens on a full frame camera?
