baguyette
- 3
- 0
How is it possible that 'quantum grains' are many orders of magnitude smaller than 'strings' or the 'Planck length'?
baguyette said:The ScienceDaily story was taken, verbatim, from the European Space Agency (ESA) website (http://www.esa.int/esaCP/SEM5B34TBPG_index_0.html). One of the authors of the original paper, Dr. Laurent, is quoted in the ESA article, but I could not tell if he made the statement that "quantum grains must be at a level of 10-48m or smaller". Not sure who made that determination or if it is even an accurate presumption from the facts.
baguyette said:How is it possible that 'quantum grains' are many orders of magnitude smaller than 'strings' or the 'Planck length'?
vela said:I might just be talking out of my butt here, but I'm guessing Laurent is referring to hypothetical violations of Lorentz invariance at high-energy scales.
http://en.wikipedia.org/wiki/Lorentz_covariance#Lorentz_violation
In the paper, Laurent et al. wrote, "On general grounds, Lorentz violating operators of dimension N = n + 2 modify the standard dispersion relations E2 = p2 + m2 by terms of the order of fnpn/Mn-2Pl where MPl is the reduced Planck scale ... used as a reference scale since LIV is expected to arise in the quantum regime of gravity." They derive a correction to the polarization of order
[tex]\frac{\xi k}{M_\mathrm{Pl}}[/tex]
and extract an upper limit of [itex]\xi \lt 1.1\times 10^{-14}[/itex] from their data. LIV will manifest when
[tex]\frac{\xi k}{M_\mathrm{Pl}} \backsim 1[/tex]
which corresponds to a length scale of 1/k~10-48 m. If LIV and quantum gravity arise at the same length scale, the results suggest quantum gravity doesn't kick in when most physicists expect it to. Laurent is interpreting this to mean spacetime remains smooth down to at least that length scale. (The paper does mention, though, that some symmetry, like supersymmetry, could imply [itex]\xi = 0[/itex].)
baguyette said:, space is made up of 'quantum grains' which have been shown to be many magnitudes of order smaller than the Planck length. I quote from the article;
which models?yoda jedi said:... but some quantum gravity models suggest that Lorentz Invariance may break down near the Planck length, 1.62 x 10-33cm, causing high-energy photons to travel at different speeds than their low-energy peers.
tom.stoer said:which models?
yoda jedi said:"a value this close to the Planck length means that quantum gravity models in which there's a linear relationship between photon energy and speed are "highly implausible." that leaves other quantum gravity options open, including those in which the the relationship is non-linear"
string and loop model predicts a linear relationship.
yoda jedi said:for lqg:
http://arxiv.org/PS_cache/gr-qc/pdf/9809/9809038v1.pdf
http://arxiv.org/PS_cache/hep-ph/pdf/0402/0402271v1.pdf
http://arxiv.org/PS_cache/hep-th/pdf/0603/0603002v1.pdffor string theory
http://arxiv.org/PS_cache/arxiv/pdf/0804/0804.3566v1.pdf
http://arxiv.org/PS_cache/gr-qc/pdf/9904/9904068v1.pdf
unusualname said:Please post links to abstracts if possible
http://arxiv.org/abs/gr-qc/9809038v1
http://arxiv.org/abs/hep-ph/0402271v1
http://arxiv.org/abs/hep-th/0603002v1
http://arxiv.org/abs/0804.3566v1
http://arxiv.org/abs/gr-qc/9904068v1
suprising; again:is there a reference? a paper? or a talk?yoda jedi said:june 2011
"we show that non-perturbative treatments like those of loop quantum gravity may generate deviations of Lorentz invariance"
tom.stoer said:suprising; again:is there a reference? a paper? or a talk?
yoda jedi said:.
http://arxiv.org/PS_cache/gr-qc/pdf/0502/0502093v1.pdf
"Much research has been done in the latter years on the subject of Lorentz violation induced by Quantum Gravity effects. On the theoretical side it has been shown that both Loop Quantum Gravity and String Theory predict that Lorentz violation can be induced at an energy near to the Planck scale. On the other hand, most of the experimental results in the latter years, have confirmed that the laws of physics are Lorentz invariant at low energy with very high accuracy"
"Quantum Gravity effects would modify the dispersion relations for particle propagation, such as photons. These modifications in turn would change the propagation velocity of photons, introducing delays for particles of different energies which could be detected if these particles would travel cosmological distances. Such modifications of the dispersion relations have been found in the two most popular approaches to Quantum Gravity: Loop Quantum Gravity and String theory. These theories predict corrections to the dispersion relations which depend on energy in the form (EℓP )n, with ℓP = 1.6×10−33 cm the Planck length scale"
yoda jedi said:.
