What is the relationship between two lines and their coordinates?
  • Context: Undergrad
  • Thread starter Thread starter aek
The discussion focuses on finding the intersection of two lines, specifically the line represented by the equation 2x + 3y - 8 = 0 and the line y = ax + 7. The coordinates of points A and B, where the first line intersects the x-axis and y-axis respectively, are determined as A(4, 0) and B(0, 8). The discussion also involves calculating the value of 'a' such that the line y = ax + 7 divides the segment AB internally in the ratio 1:3.
  • Understanding of linear equations and their graphical representation
  • Knowledge of coordinate geometry concepts, including points of intersection
  • Familiarity with the concept of dividing a line segment in a given ratio
  • Ability to solve simultaneous equations
  • Study the method of finding intersection points of linear equations
  • Learn about the section formula for dividing line segments in a specific ratio
  • Explore the graphical representation of linear equations in two dimensions
  • Practice solving simultaneous equations involving two variables
Students studying coordinate geometry, mathematics educators, and anyone looking to strengthen their understanding of linear equations and their intersections.
aek
Hi all,
can some-one be kind enough to help me through this question. Thanks i highly appreciate it.
The line 2x+3y-8=0 cuts the x and y-axis at A and B respectively. The line y=ax+7 is called l. Find
(i) in terms of a, the coordinates of the point where l cuts AB
(ii)the value of a if l is to divide Ab internally in the ratio 1:3
Mathematics news on Phys.org
Are you sure this isn't homework? Looks a lot like it!
On the x-axis, y= 0. If y= 0, then 2x- 8= 0. Solve for x to find A.
On the y-axis, x= 0. If x= 0, then 3y- 8= 0. Solve for y to find B.
The line y= ax+ 7 cuts the line 2x+ 3y-8= 0 at (x,y) that satisfies both equations simultaneously. Solve y= ax+ 7 and 2x+ 3y- 8= 0 for x and y (which will, of course, depend upon a).
If that point divides AB "in the ratio 1:3" then it must also divide the x (and y) values in that ratio. Determine a so that the difference between 0 and the x coordinate of the dividing point is 3 times the x-difference between A and the x coordinate of the dividing point.
thanks for the hints HallsofIvy..yes it is homework, i just needed help to do it. Thanks again, i highly appreciate it.
