Could life exist inside a black hole?
  • Thread starter Thread starter ubavontuba
    Black hole Hole
The discussion explores the concept of dark energy and its potential relationship with relativity and black holes. One participant suggests that the universe's expansion might be perceived as a gravitational effect similar to that of a black hole, where matter at the universe's edge appears to have infinite mass due to its relativistic speed. Others clarify that while the universe's expansion is modeled using general relativity, dark energy is not simply a consequence of relativity but may require additional explanations or components. The conversation also touches on the nature of cosmological horizons and the differences between black holes and the universe's expansion dynamics. Ultimately, the participants emphasize that the universe's behavior cannot be accurately described as that of a black hole.
ubavontuba
Hello,
I'm new here and I have a question I hope you might help me with...
Might "dark energy" be a natural consequence of relativity?
It seems to me that if the matter at the edge of the "known universe" is moving away from us at nearly the speed of light... that relative to us it must have nearly infinite mass.
Or in other words, could the universe be apparently "falling" outward toward a black hole shell, rather than simply accelerating from some invisible internal force like "dark energy?"
The weird part about this idea is that from every observational point in the universe, you'd observe the same thing (meaning there is no real shell, only a relative shell).
I think this might account for the time lag from the first expansion to the current expansion too do to matters of scale. What do you think?
ubavontuba
Space news on Phys.org
IIRC, the boundary conditions for the universe are, or can be described as that of a black hole. I know that Kaku says something close to this: "If you want to know what it looks like inside of a black hole, look around your room".
I'm in no position to vouch for this though, and it may be out of date.
The universe is like a BH only in that it is impossible to 'get out of' either.
The BH is one particlular solution of the spherically symmetric solution of Einstein's GR field equation, \rho = \rho(r), p = p(r), cosmology arises out of the cosmological solution \rho = \rho(t), p = p(t).
They are different and should not be confused. A BH is something within the universe, it is not the universe itself, even in the BB singularity - that expands whereas the BH solution does not.
Garth
This is a common enough question that we might want to consider putting it in a sticky (along some of the other common questions). Anyway, here's a link with more information:
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/universe.html"
Relating it more to "dark energy."
Hey guys,
Thanks for the responses.
I'm more intersted in how this relates to dark energy, rather than black holes.
My concept is that to the observer, the universe having seemingly been expanding at relativistic speed from any given point, the perceived black hole "shell" should not act inside like the interior gravitational effects of a normal gravitational sphere. This is because the mass is receding at near light speed in either perceived direction (sort of like shining two flashlights in opposite directions).
That is that from the standpoint of the observer, the energy and mass at the perceived edge of the universe on his left, let's say, is in a noncontiguos reference frame from the matter and energy on his right.
So, all the matter on his right, let's say, is going to be effected more and more by the matter at the perceived edge on his right, in a relationship to distance. The closer it is to the observer, the less it is thusly affected and conversely, the farther away it is, the faster it will seem to be accelerating outward (generally speaking).
As the universe expands, this effect should be perceived by the observer as an acceleration of the expansion of the universe. Ergo, as "dark energy." This is because the receding walls allow there to be more space for this effect to take place in, and therefore everything (including perceived motion) must seemingly get bigger (faster) too.
So, is dark energy an as yet unquantified force pushing outward? Or is dark energy merely a gravitational effect of relativity?
ubavontuba said:
Hello,
ubavontuba
Some, but not all, of your issues are addressed in the FAQ
Basically the singularity of the big bang is just in the wrong place for the universe to be a black hole - it's possible the universe is a white hole, but this is not a standard model and it' not particularly likely.
For more detail, see the FAQ.
Also, if I'm understanding you correctly, here you're relying on a common misconception about relativity:
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/black_fast.html"
Our models of the universe already use general relativity, so it wouldn't make sense to say that dark energy is a "natural consequence of relativity" unless:
1) General relativity is modified at large scales
2) We use a distribution of matter different from that observed (i.e. reject the cosmological principle)
3) We add an extra component of "dark energy"
There are also some folks who speculate that the acceleration could be explained by a back-reaction from large-scale inhomogeneities, but that appears to be quite different from what you're suggesting.
pervect and SpaceTiger:
Pervect, I guess I shouldn't have used the phrase "in a black hole," but rather; "Might that which is beyond our known universe be perceived by us as a sort of black hole?"
What I'm getting at is that it seems to me that the "edges" of the known universe should essentially behave (from our viewpoint) essentially the same as a black hole, only concave rather than convex/spherical. That is, that there is an event horizon, intense gravity and even Hawking radiation (we'd see this as the cosmic background radiation").
SpaceTiger,
I do not mean that we are a black hole because we are traveling at relativistic speeds as compared with other arbitrary masses.
In my concept, every observer notes that they are centrally located (as far as they can tell) and everything else is redshifting away from them (generally, as a matter of distance).
To us, an arbitrary point at the edge of the perceivable universe is moving at relativitic speeds and therefore any mass in that point will have relativistic properties (in the perspective of our reference frame). One of these properties being increased mass (relative to us).
Our mass doesn't increase because of this. And were we to move over to that far away point, we'd see that the matter there was normal and that the matter where we were (very far away now) has these same relativistic properties.
Wherever we are, the local reference frame seems normal. It's only in looking out and far away that we'd see the apparent effects (they're not local).
If you mean beyond the observable universe, then no, read the first link. Most models of the universe extend beyond the limits of our observational capabilities (i.e. beyond those points at which galaxies appear to be moving at relativistic speeds from us).
No, read the second link.
I feel like you're only reading the titles or something, since both of your questions are answered in the text of the links we provided. If you don't understand a particular point, please ask for clarification. Matter that is moving at relativistic speeds does not form a black hole, even "apparently". There are different kinds of cosmological horizons, beyond which our observational capabilities are limited in various ways, but there are no black holes involved. I'll be happy to elaborate if you're interested in horizons.
Again, models of the universe are fully general relativistic, so there is no room for the kind of error you're talking about.
On the horizons issue, can things (if they exist) beyond the universe's horizon have an effect on the way things inside the horizon (in our universe) behave?
I guess light effects are out the question, but are gravitational effects out of the question?
More generally, can our universe be connected (via what?) to areas beyond our horizon?
Eww, wasn't planning on getting into multiverse issues, but I guess just did...
Right, I've read that. Referring to the portion that states:
The standard big bang models are the Friedmann-Robertson-Walker (FRW) solutions of the gravitational field equations of general relativity. These can describe open or closed universes. All these FRW universes have a singularity at the origin of time which represents the big bang. Black holes also have singularities. Furthermore, in the case of a closed universe no light can escape which is just the common definition of a black hole. So what is the difference?
The first clear difference is that the big bang singularity of the FRW models lies in the past of all events in the universe, whereas the singularity of a black hole lies in the future. The big bang is therefore more like a white hole which is the time reversal of a black hole. According to classical general relativity white holes should not exist since they cannot be created for the same (time-reversed) reasons that black holes cannot be destroyed. This might not apply if they always existed.
Doesn't the edge of the perceivable universe lie in the future? Isn't it in the future for mass to move toward it?
I've read that too. Referring to:
In fact objects do not have any increased tendency to form black holes due to their extra energy of motion. In a frame of reference stationary with respect to the object, it has only rest mass energy and will not form a black hole unless its rest mass is sufficient. If it is not a black hole in one reference frame, then it cannot be a black hole in any other reference frame.
I am not stating that anything forms a black hole due to its relative kinetic energy/momentum. I am asking if objects receding away from us at relativistic speeds would appear to us as if they are entering a black hole horizon.
Like an object entering a black hole horizon, the object should appear compressed and highly red-shifted. In other words, the edges of the universe (if we could see them) would apppear to us like a concave black hole. Again, I'm not stating it is a black hole.
Eventually, mass moving away from us should appear infinitely red shifted (it disappears into the apparent event horizon).
So, supposing that any of this makes sense, isn't it possible to expect black hole behavior from the boundaries of the perceivable universe?
Garth
Just wondering, but have we proven that we can't escape from the universe? I think I read somewhere that if we created some massive amount of energy, we could rip a hole in the fabric of space-time. Also, we can't rule out wormholes.
We will know that is possible when you do it, enjoy the trip! :smile:
Garth
Both Black Holes and the Observable Universe have an Event Horizon. You already know about the Event Horizon of Black Holes. The Observable Universe has a Cosmological Event Horizon. This is the distance from us where the expansion of space has caused objects at that distance to recede away from us at the speed of light so that we can no longer see them. And just like a BH, galaxies that approach the Cosmological Event Horizon appear to red shift and slow down in their motion; they freeze just before they disappear.
Some have suggested that just as in the case of BH's, an entropy can be calculated for the area of the Cosmological Event Horizon with the same formula for calculating the entropy of a BH using the area of its event horizon. And they suggest that the area of the Cosmological Event Horizon constraines the entropy inside it just as in the case for a BH. The area is emmense for the Cosmological Event Horizon. But that suggests some interesting consequences for an accelerating universe.
If the expansion of the universe is accelerating, then the distance to the Cosmological Event Horizon is shrinking, and the area associated with the Cosmological Event Horizon is decreasing as well. That would mean that the entropy enclosed inside the Observable Universe is decreasing. And we should expect some form of structures to emerge to compensate for the decreasing entropy of the collapsing Cosmological Event Horizon. Not only that, but we are losing material behind the Cosmological Event Horizon as galaxies recede away from us. So there seems to be a need for more complex and stable structures required of ever decreasing amounts of material. I find it interesting that life arose on Earth at just about the same time that the universe started it accelerated expansion. But what can we expect of the future if this process continues? Will some people have to rise from the dead to make up for this decreasing entropy? I wonder.
Garth
Thanks! Don't worry, I'll tell you how it went. :wink:
Just had a thought. The Unruh effect assigns a temperature to acceleration, and points in space are accelerating away from each other - the farther away points of space get, the faster they move away from us. And there must be an energy density for a given temperature. So does someone want to do the calculation: What is the energy density associated with the expansion of space? Is it anywhere close to the dark energy density? If no one else wants to venture this question, I'll try to get to it when I get time. Thanks.
What you can correctly say is that the universe has a cosmological event horizon, if that's what you're getting at.
Note that the the redshift and apparent disappearing of an object at the horiozn is what an outside observer sees.
An observer inside a black hole would not observe these effects, he would see light from the outside observer just fine - the horizon is a one way barrier. This barrier is "outside can't see inside" for a black hole, it's "inside can't see outside" for the universe.
Thus what's similar is the existence of a horizon in both cases, but it's not right to think of the universe as being a black hole.
As far as the gravity of rapidly moving objects go, it doesn't behave like you think it does.
For instance, take the following scenariospaceship1-------------->black hole
spaceship2
Spaceship1 heads directly towards a black hole at a high rate of speed, passig spaceship2 which is stationary with respect to the black hole.
Does the black hole appear heavier to spaceship 1 when it passes spaceship2, because of the relative motion? (Spaceship1 can consider that the black hole is moving directly towards it.)
The answer as to the black hole's apparent gravity depends on the coordinate system used, but a simple measurement that's easy to do on the two spaceships is to measure the difference in gravity along the length of the ship (the tidal force). If the black hole appeared heavier, we would expect that spaceship1 would experience more tidal force than spaceship2.
However, spaceship1 and spaceship2 will both measure the same tidal force in the above scenario.
If spaceship1 was moving away from the black hole we would have the same result.
If spaceship1 was moving up the page instead (with the black hole still to its right), it _would_ measure increased tidal forces as compared to spaceship 2.
If you could give me the expansion rate in units of meters and seconds and the dark energy density in SI units of Joules per meter cubed, I'll see what I can do. Thanks.
I've been trying to find the time to put together a good summary of cosmological horizons, but I'm afraid I'm still falling short. Start by taking a look at hellfire's brief review:
https://www.physicsforums.com/showthread.php?p=845204#post845204"
The edge of the perceivable universe actually lies in the past. In theory, the maximally redshifted light would reach us from the moment of the Big Bang. In practice, we can't see anything before recombination (z ~ 1100).
There may exist an event horizon; that is, a comoving distance at which a light ray fired from Earth at the present time would never reach. I don't know if that's what you mean. It's not the same as a black hole event horizon, but is, in some ways, analogous to it.
In current theory, an infinitely redshifted "object" would sit at the particle horizon at t=0 (the Big Bang). The particle horizon is always growing with time, so nothing disappears behind it. The event horizon can shrink with time and objects can "disappear" behind it, but it doesn't represent a boundary of infinite redshift.
So how far away is the Cosmological Event Horizon at present. I don't think this is the same as asking how far away the presently observeable horizon is because that is what it was in the past, right?
Would it be right to calculate the accelerataion of points in space from other points in space as the universe expanse as follows: Take the distance to the Cosmological Event Horizon (at present?) and say that there is a constant acceleration from zero to the speed of light over that distance over that time? Thanks.
"Horizons"[/URL]
[/quote]
I don't think this is the link you intended :-(
[quote]
[/quote]
They way I recall it is that such a horizon does in fact exist in FRW cosmologies [b]IF[/b] the expansion of the universe is acclerating. (Current data suggests that this is the case). I suppose I should go look for some references to support my recollections.
If the expansion of the universe is deaccelerating, we will (again IIRC) see all of it eventually.
Oops, I typed the link name in place of the path (now edited)...no, I meant this link:
They way I recall it is that such a horizon does in fact exist in FRW cosmologies IF the expansion of the universe is acclerating. (Current data suggests that this is the case). I suppose I should go look for some references to support my recollections.
You're right, I hope I didn't give the wrong impression here...I don't have so much faith in the standard model that I would confidently extrapolate it to t->infinity. :smile:
There may be an event horizon. We are by no means confident that this is the case.
Yup. And if it accelerates for a while, then decelerates (like the post-inflation universe), then an event horizon calculated assuming \Lambda CDM would be incorrect. It's for this reason (among others) that I view Mike2's entropy arguments with great suspicion.
That depends on the model, but you should be able to get the result by just integrating:
\int_{a_0}^{\infty}\frac{dt}{a}
For that integral, you would need the time dependence of the scale factor and it will give you a result in comoving coordinates (it would diverge in physical coordinates). I have to run soon, so I don't have time to do the integral.
I think I perceive the point of misundertanding
I'm thinking you mean in the case of observing a regular black hole (not an extra-universe observer, observing the universe).
Right, with an ordinary black hole. What I'm suggesting is to take all of these effects and turn them inside-out (the infinite density is beyond the sphere, not within the sphere).
Actually, I'm thinking of the extra-universe as a black hole (perceived, not real), not the universe itself.
spaceship2
Sure, but spaceship 1's mass will appear to change (relative to spaceship 2) as it approaches the black hole. But, I'm not talking about black holes (in general) here anyway.
I will reiterate as delicately as I can. I am not talking about black holes. I am talking about an apparent effect of relativity. There is no real black hole in question to consider.
Mike2
It looks like you're getting it. I'm not too sure about the decreasing size of the cosmological event horizon though. I don't think the horizon is even real (in the sense that you can visit it). The size of the event horizon should always be determined by the relative speed of a lot of galaxies way out there. Where a large percentage of them approach c will determine the boundary (it needn't even be smooth).
Unruh!
Mike2,
I think this is a step in the right direction.
I think one can get an estimation about this considering that the universe will end in a phase of exponential expansion due to the action of the dark energy which will become dominant. In such a case (considering that the scale factor today is a_0 = 1):
\int_{a_0}^{\infty} \frac{dt}{a} \quad = \quad \int_{a_0}^{\infty} \frac{dt}{e^{Ht}} \quad = \quad \frac{1}{H}
This means that the event horizon will be at same distance than the Hubble sphere. I guess that an exact calculation for \Omega_{\Lambda} = 0.73 and \Omega_M = 0.27 must be done numerically.
You've totally missed the point, partially because of my choice of example.
Spaceship 1 is approaching a planet or a black hole - it doesn't matter. (I said black hole in the first post, but it doesn't really matter, black holes are just convenient to calculate with - and the example in my textbook that this is drawn from involves a black hole).
From the frame of spaceship 1, the planet is more massive. (Not its invariant mass, which is invariant, but it has a greater energy, and hence a greater "relativistic mass".)
(Technical note: to define the mass at all, you need an asymptotically flat space-time.)
However, the gravity of the planet/black hole is not spherically uniform in the moving frame. Thus when spaceship1, directly approaching (or fleeing) the planet, fires up its Forward mass detector (a real device, which however measures tidal forces, and not mass directly), it finds that the gravity (specifically, tidal gravity) of the planet has not increased _even though_ the relativistic mass (energy) of the planet has increased.
The same thing happens if the spaceship is moving away from the planet. The same thing happens if the planet is moving away from the spaceship.
Motion towards or away from a planet (or black hole) does not affect tidal gravity.
The same thing does _not_ happen if the spaceship is moving perpendicularly to the line connecting it to the planet - in that case, the tidal gravity actually does incease.
This can be understood (in an approximate sense) by thinking of the gravitational field of a moving object being compressed, much like the electric field of a moving charge is. (The anology is not exact, mainly because gravity isn't really a field in GR).
The bottom line is your idea does not work - there is no "infinite mass" due to the expanding universe, even when the velocity of recession is very large. The velocity of recession is on a direct line, and thus it does not affect the gravitational forces.
There's another way of saying something similar that is more in the spirit of true GR and perhaps simpler. The net gravitational effect of a spherically symmemtric expanding shell of matter can be shown to be zero inside the shell.
The cosmological horizon (assuming it exists, which means assuming that the universe's expansion is accelerating and will continue to accelerte) is thus not due to the effects of the matter outside - it is due to the effects of the matter (and dark energy) inside the horizon.
[add]
Here's a reference (unfortunately it's in postscript - but with google you can view it as text, though it won't be quite as intelligible). The theorem is called Birkhoff's theorem.
www.ucolick.org/~burke/class/grclass.ps
What this means, roughly, is that spherical symmetry is enough to ensure that the spacetime is static, without separately requiring it. Another way to appreciate the content of the theorem is to consider any spherical object. If you go inside it and do anything you wish that does not disturb the spherical symmetry, then the external gravitational field cannot change. This is consistent with our earlier result that there is no monopole gravitational radiation. Yet another meaning for the theorem is than inside of a spherically symmetric distribution of mass there are no gravitational effects, just as in Newtonian theory, despite the nonlinearities.
So for the case \Omega_{\Lambda} = 1 the event horizon is located at the Hubble sphere. The Hubble radius for H = 71 km/s Mpc is equal to 13,7 Gly.
I have calculated the integral for the case \Omega_{\Lambda} = 0.73 and \Omega_M = 0.27. The event horizon should be located about 15,5 Gly away from us. I had some problems with the numerical integration, but nevertheless I think this should be a good estimation (I can provide details if someone is interested).
I think what you're calling the presently observable horizon is the following. A "galaxy" is on the presently observable horizon if, at t = 0, the worldline of the galaxy intersects the past lightcone for us at t = now. You colud also mean at t = photon decoupling. The distance to the presently observable horizon is then the distance between our worldline and the galaxy's worldline as the measured using the spatial scale at t = now.
A galaxy is on what (I think) you're calling the Cosmological Event Horizon if, at t = now, the worldline of the galaxy intersects the past lightcone for us at t = infinity. I think you're asking for the spatial distance between our worldline and the galaxy's worldline.
As Space Tiger says, the coodinate distance between these worldlines is
\int_{a_0}^{\infty}\frac{dt}{a}.
The physical distance between our wordline at the galaxy's worldline is the spatial scale multplied by the coordinate distance. At t = infinity, the scale is infinite, so the physical distance between the worldlines is infinite. But I think you're asking for the physical distance between the worldlines as measured along the spatial hypersurface t = now, i.e., the coordinate distance multiplied by the scale at t = now. With appropriate normalization, this physical distance is same as the coordinate distance.
Hellfire computed this physical distance to be 15.5 gigalightyears, and this also is what I calculate.
Regards,
George
  • · Replies 134 ·
11K
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 29 ·
  • · Replies 20 ·
