Galaxies, which are the smallest and least luminous type of galaxy?
  • Thread starter Thread starter euphoria0697
    Direction Push
The discussion revolves around a series of multiple-choice questions related to astronomy, focusing on concepts such as apparent brightness, parallax, and characteristics of stars. Participants are seeking clarification on specific questions and concepts within the subject area of stellar astronomy.
  • Participants are questioning the correctness of answers to various multiple-choice questions, particularly regarding the concept of parallax and its implications. There is also discussion about the characteristics of different types of stars and the properties that require knowledge of distance.
The discussion is ongoing, with participants actively engaging in questioning and clarifying concepts. Some guidance has been offered regarding specific answers, but there is no clear consensus on the correctness of responses. Multiple interpretations of the questions are being explored.
Participants express uncertainty about specific terms and concepts, such as parallax, and there are indications of confusion regarding the questions and their respective answers. This suggests a need for further exploration of foundational concepts in astronomy.
euphoria0697
Here's my astronomy homework for the week.
bold = my answer.
Any help is appreciated!
Question 1 Multiple Choice 5 points
The apparent brightness of stars in general tells us nothing about their distances. In order for the apparent brightness of a star to be a good indicator of its distance, all the stars would have to be:
at the same distance
the same composition
the same luminosity
by themselves instead of binary or double-star systems
Question 2 Multiple Choice 5 points
Whic if the following stars is a Cepheid variable?
Sirius
Betelgeuse
Rigel
Polaris
Question 3 Multiple Choice 5 points
Astronomers must often know the distance to a star before thay can fully understand its characteristics. Which of the following properties of a star typically requires a knowledge of distance before it can be determined?
its luminosity
its radial velocity
its temperature
its apparent brightness
Question 4 Multiple Choice 5 points
Which of the following will show the smallest parallax shift?
the Moon
the planet Jupiter
the Sun
the star 51 Pegasi, about 50 LY away
Question 5 Multiple Choice 5 points
You are observing a binary star system and obtain a series of spectra of the light from the two stars. In this spectrum, most of the absorption lines shift back and forth as expected from the Doppler effect. A few lines, however, do not shift at all, but remain at the same wavelength. How can we explain the behavior of the non-shiftnig lines?
there is a star in the system which is not moving at all: it is just sitting there
there is a planet orbiting the stars in the system
there are huge clouds of dust just behind this star system from our perspective
the lines come from interstellar matter between us and the star, not from the stars themselves
Question 6 Multiple Choice 5 points
An astronomer wants to observe a cloud of cold neutral (not ionized) hydrogen, far away from any stars. What would be an instrument that could help in this task?
a telescope in space, able to pick up x-rays from space
a radio telescope , tuned to a wavelength of about 21 cm
a large telescope observin visible light, but with a very sensitive detector attached
a neutrino detector, deep underground
Question 7 Multiple Choice 5 points
Astronomers have found large quantities of cold, neutral hydrogen gas in our galaxy. How is this gas distributed?
it is located only near stars, and not in the large empty spaces between them
it is found mostly in a flat layer extending throughout the disk of our galaxy
it is found in a spherical distribution about 100 LY in size, cenetered on the Sun
if is found only in the outer regions of the galaxy, where we are, and not in the central areas.
Question 8 Multiple Choice 5 points
Observations show that some gas in interstellar space has been heated to temperature of a million degrees or so. What mechanism do astronomers believe is reponsible for this heating?
Stars like the sun shine on the gas, heating it
Th eatoms in the gas collide, heating each other
new stars are forming in the regions of hot gas, heating it
exploding stars are responsible for heating the gas with the energy of their explosion.
Question 9 Multiple Choice 5 points
A star whose temperature is increasing but whose luminosity is roughly constant moves in what direction on the H-R diagram?
to the right
to the left
upwards
downwards
Question 10 Multiple Choice 5 points
Astronomers identify the "birth" of a real star (as opposed to the activities of a protostar) with what activity in the star?
when it starts to contract rapidly from a cloud of gas and dust
when it first becomes visible inside its dust cloud
when a wind is observed coming from its surface
when nuclear fusion reactions begin inside its core
Question 11 Multiple Choice 5 points
The big surprise about the first planet discovered around another (liing) star was that it
was smaller than Mercury or Pluto in our own solar system
orbited so close too its star it took only 4 days to go around
has a mass greater than that of most stars
had a spectrum which indicated it was made of elements we never find on Earth
Question 12 Multiple Choice 5 points
With the technique used to discover the first planets around other living stars, only some kinds of planets can be found. The kinds of planets we are able to find with this technique today are:
only terrestrial planets
only cold planets
only planets that have masses like Jupiter or Saturn
only planets with giant orbits (like Pluto or larger)
Question 13 Multiple Choice 5 points
Which of the following types of stars will spend the longest time (the greatest number of years) on the main sequence?
O
A
G
K
Question 14 Multiple Choice 5 points
How long a main sequence star remains on the main sequence in the H-R diagram depends most strongly on
its initial composition
the number of companion stars or planets orbiting it
its radial velocity
its mass
Question 15 Multiple Choice 5 points
When the outer layers of a star like the Sun expand, and it becomes a qiant, which way does it move on the H-R diagram?
toward the upper right
toward the upper left
toward the lower right
toward the lower left
Question 16 Multiple Choice 5 points
A star with a mass like the sun which will soon die is observed to be surrounded by a large amount of dust and gas - all material it has expelled in the late stages if uts life. if asrtonomers want to observe the radiation from such a giant star surrounded by its own debris, which of the following bands of the spectrum would be the best to use ot observe it?
gamma-rays
x-rays
unltraviolet
infrared
Question 17 Multiple Choice 5 points
The event in the life of a star that begins its expansion into a giant is
the core reaches a temperature of ten million degrees
as much as 90% of the star explodes violently
almost all the hydrogen in its core that was hot enough for fusion has been turned into helium the star's internal structure reaches equilibrium for the first time in its life
Question 18 Multiple Choice 5 points
A white dwarf, compared to a main sequence star with the same mass, would always be:
redder in color
smaller in diameter
the same size
younger in age
Question 19 Multiple Choice 5 points
A neutron star as as dence as
water
the center of the Earth
a white dwarf star
the nucleus of an atom
Question 20 Multiple Choice 5 points
Astronomers have concluded that pulsars are
rotating black holes
rotating neutron stars
rotating red giants
supernovae that are about to explode
4 is wrong. Do you know what parallax is?
12 is wrong. This should have been obvious to you, since you got 11 right.
Also, euph, if you're not sure about number one, pick d.
So what is parallax? i don't know too.
not really sure what parallax is. As for #12, is it only planets that have masses like Jupiter or Saturn? Is #1 D? I got confused
How about changing #13 to K.?
#16 is wrong too.
No, he was right.
Hold your hand out at arms' length and cover a distant object with it while closing one eye. Then open the other eye. Now you can see the distant object. That's parallax (the parallax of your hand wrt a fixed background).
thanks for everyone's help so far, or lack thereof
Right. Now. Your hand is about two feet away from your eye. If it were two hundred feet away, would you get more or less parallax?
OK, now, what will show only a little parallax -the Moon only 300,000km away or a star light years away?
bold = my answer.
the same luminosity
same distance.
Sirius
Betelgeuse
Rigel
Polaris
correct.
its luminosity
its radial velocity
its temperature
correct.
the Moon
the planet Jupiter
the Sun
51 Pegasi. More distant = less parallax.
correct.
a radio telescope tuned to 21 cm - you can only detect absorption lines in a neutral hydrogen cloud, which is at 21 cm.
correct.
Exploding stars. Radiation from ordinary stars will not be energetic enough to heat interstellar gas clouds to these temperatures.
to the right
to the left
upwards
downwards
correct.
correct.
correct.
only cold planets
Only massive planets.
O
A
G
K
K. OBAFGKM - Oh Be A Fine Girl Kiss Me [Quick Right Now]. K stars start out less massive than G stars hence remain longer on the main sequence.
its radial velocity
its mass
correct.
correct.
gamma-rays
x-rays
unltraviolet
infrared
Infrared. A star like the sun will become a red giant and emit most strongly in the red wavelengths.
Correct.
redder in color
smaller in diameter
the same size
younger in age
correct.
water
a white dwarf star
correct.
rotating red giants
correct.
Higher temperatures are on the left side of the HR Diagram.
And I find it stunning you got most of the answers right and you don't know what parallax is! That is some kind of astronomy course you are taking.
yeah to be honest I still don't understand what all this arm's length parallax stuff is..
the same luminosity
same distance.
Chronos, are you sure about that? I'm inclined to go with euphoria's initial answer: knowing the luminosity of a star and its apparent brightness gives you its distance from us. If all stars were to be equally luminous, their apparent brightnesses would indicate their different distances from us. I don't see how putting stars of different luminosity at the same distance from us would tell us how large that distance would be. I could be missing something, of course!
I was about to post the (approximate) same reply. Quite sure that you are correct on this one.
#9 is to the left
#5 is the last choice
#1 is the answer I picked..
even with everyone's help i still got 2 wrong
but, thanks for everyones help
more help needed
hey guys.. this is my last homework and I want to make sure I do well and understand the material for the approaching final exam.
Question 1 Multiple Choice 10 points
The principle of equivalence says that
the amount of energy released by fusion is equivalent to the amount of mass that is lost
gravity is equivalent to the strong nyclear force inside of any nucleus
the effects of gravity are equivalent to the effects of acceleration
far away from a black hole, its pull is equivalent to the pull of the star that is formed from
Question 2 Multiple Choice 10 points
The region around a black hole where everything is trapped, and nothing can get out to the rest of the universe, is called
the singularity
the neutron star radius
the gravitational redshift zone
the event horizon
Question 3 Multiple Choice 10 points
Far away from a black hole (at the distance of another star), which of the following is a possible way to detect it?
notice what a large amount of star light it blocks from behind it
look for the pulsed radio waves it gives off as it rotates like a lighthouse
look for the neutrinos that always escape from the event horizon
search for flickering x-rays being given off as it "eats" part of a neighbor star.
Question 4 Multiple Choice 10 points
An astronomer needs to measure the distance to a globular cluster of stars that is part of the Milky Way Galaxy. What method should she try to use to find the distance?
measure the parallax of the cluster
count the number of O and B stars in the cluster
look for flickering x-rays coming from a black hole in a binary star system in the cluster
find a variable star (ceoheid or RR Lyrae) in the cluster
Question 5 Multiple Choice 10 points
Which of the following statements about the nuclear bulge of our Galaxy is FALSE?
it is significantly thicker that the disk of the Galaxy
typically consists of older stars
it is difficult for us to see with visible light because of cosmic dust
the best way to learn more about it is yo observe ligher energy radiation, such as UV and x-rays
Question 6 Multiple Choice 10 points
Where would you look for the youngest stars in the Milky Way Galaxy?
in the halo
where there is the dark matter
in the disk
in the nuclear bulge
Question 7 Multiple Choice 10 points
If I want to find a sizable collection of Population II stars in the Milky Way Galaxy, where would it be a good place to look?
near the Sun
in a globular cluster high above the Galaxy's disk
in the Orion Spiral Arm
on the outer surface of giant nolecular clouds
Question 8 Multiple Choice 10 points
Our Milky Way Galaxy is what type of galaxy?
spiral
elliptical
dwarf elliptical
irregular
Question 9 Multiple Choice 10 points
Which galaxy is observed to contain mostly older stars?
spiral
elliptical
dwarf elliptical
irregular
Question 10 Multiple Choice 10 points
Which type of Galaxy is very difficult to see but (astronomers recently relized) may be very common?
spiral
elliptical
dwarf elliptical
irregular
You might want to think more about #5, #7, and #10. What kind of light does dust obscure? What is a Population II star? What would make a galaxy difficult to see?
No, you are not missing anything, I had a dyslexic moment.
You have to do it to get it.
1] Close one eye.
2] Hold your thumb in front of your eye at arm's length - about two feet away.
3] Move your thumb to hide something on the wall across the room, say a picture.
4] Now, switch eyes: close one, open the other. Is the picture still hidden? It's off to the side a little bit, right?
Now, do it again, but this time hold your thumb only 6" away:
1] Close one eye.
2] Hold your thumb in front of your eye about 6" away.
3] Move your thumb to hide the picture.
4] Switch eyes: close one, open the other. The picture, rather than being a little off to the side, is now waaay off to the side, right?
The closer your thumb is to your eye, the more parallax shift (movement against the wall) is observed. If you knew nothing about your thumb except how much shift it exhibited, you could tell how far away it was from your eye.
Now, scale it up.
- The distance between your eyes is equiv. to the diameter of the Earth's orbit
- Your thumb is a star of unknown distance
- The wall is the background of stars (which is effectively at infinite distance, so no shift)
By seeing how much parallax shift the star undergoes over six months of the Earth's orbit, you can estimate its distance from us.
1] Close one eye.
1] Close one eye.
Now, scale it up.
That has to be the best explanation of Parallax I've read, thank you very much.
is
5=thicker
7=globular clusters
10=? have no idea
thanks guys
euphoria0697 said:
is
5=thicker
7=globular clusters
10=? have no idea
thanks guys
#5 is:
The best way to learn more about it is to observe higher energy radiation, such as UV and x-rays. This is "FALSE" because the "dust and gas" answer above is correct and the high energy radiation (X-rays & UV) don't penetrate this as well as the longer wavelengths do. So, Radio would do it, not X or UV.
#7 is:
in a globular cluster high above the Galaxy's disk.
#10 is:
dwarf elliptical
  • · Replies 0 ·
  • · Replies 23 ·
