Chem lab, check it over for me please?
  • Thread starter Thread starter losethefire
    Chem Lab
The discussion focuses on calculating the molar enthalpy of sodium hydroxide (NaOH) using a calorimeter setup with varying volumes of water and masses of NaOH. The procedure involved three trials, with the first two yielding molar enthalpies of 32.23 kJ/mol and 26.91 kJ/mol, while the third trial was deemed anomalous, resulting in an average molar enthalpy of 29.57 kJ/mol. The user seeks feedback on the accuracy of their calculations and the validity of their experimental results.
  • Understanding of calorimetry principles
  • Knowledge of molar enthalpy calculations
  • Familiarity with the properties of sodium hydroxide
  • Basic skills in experimental design and data analysis
  • Review calorimetry techniques and best practices
  • Learn about the heat capacity of water and its implications in calorimetry
  • Investigate the relationship between solute mass and temperature change in solutions
  • Explore advanced calorimetry methods for more accurate enthalpy measurements
Chemistry students, laboratory technicians, and educators involved in experimental thermodynamics and calorimetry studies.
losethefire
This is basically the lab I typed up tonight to hand in tomorrow. I'm wondering:
1. Does it look okay?
2. Is there any additional information I should add/anything to take out?
3. Is my third calculation totally off or is it just experimental error?
Purpose: To calculate the molar enthalpy of the compound sodium hydroxide by using water in a calorimeter.
Materials: An insulated coffee cup with a fitted lid
Water (varying volumes in each trial)
Solid sodium hydroxide (varying masses in each trial)
A thermometer
Procedure: 1. Fill the coffee cup with 100ml of water. Find and record the temperature fdsof the water.
2. Weigh 9.36g of sodium hydroxide.
3. Add the sodium hydroxide to the water and quickly place the lid on top of the cup.
4. Lift the lid a bit and stir with the thermometer until the sodium hydroxide dissolves. Record the temperature of the solution.
5. Pour out the solution and clean the coffee cup thoroughly.
6. Repeat steps 1-5 twice. In the second trial, use 100ml of water and 29.27g of sodium hydroxide. In the third trial, use 75ml of water and 71.52g of sodium hydroxide.
Observations:
Trial Volume of Water Mass of Sodium Hydroxide Temperature initial Temperature final
1 100ml 9.36g 22°C 40°C
2 100ml 29.27g 23°C 70°C
3 75ml 71.52g 22°C 85°C
Calculations:
ΔHNaOH=qwater
nH=vcΔt
H=vcΔt
n
For trial 1
H= 0.1L* 4.19kJ *18°C *40g
L ● °C * 9.36g * 1 mol
= 32.23 kJ/mol
For trial 2
H= 0.1L* 4.19kJ *47°C* 40g
L ● °C *29.27g *1 mol
=26.91 kJ/mol
For trial 3
H= 0.075L * 4.19kJ * 63°C * 40g
L ● °C *71.52g *1 mol
=11.07 kJ/mol
Conclusions: I found that the third trial seemed to be abnormal and so I won’t include it in an average. By averaging the two closer enthalpies, I got 29.57 kJ/mol as the molar enthalpy for sodium hydroxide.
Thanks in advance!
EDIT: Sorry if the math and the charts are a little illegible. It's hard to communicate math over the internet.
Ask yourself this question, based on the trend you see with the first two data sets, what value in the temperature change would you have predicted when the amount of grams of NaOH doubles and the volume water decreases by a fourth? Is it feasible to attain this magnitude of a temperature change with water?
Also, from my past calorimeter experiments during my undergraduate years, the enthalpy was not equivalent to the heat change of water, if my memory serves me well. However, your professor may have simplified the matter for himself.
  • · Replies 16 ·
27K
24K
