Can You Solve the Square Root Equation with Variables?
  • Thread starter Thread starter liskawc
The discussion revolves around solving the equation involving square roots: sqrt(ax^2 + bx) - sqrt(cx^2 + dx) = e, where a, b, c, d, and e are known constants. Participants explore various methods and approaches to tackle this equation.
  • Mixed
  • Participants discuss squaring the equation to eliminate the square roots and simplifying the resulting polynomial, leading to a fourth-degree equation. Some express challenges in solving this polynomial.
  • One participant suggests considering specific forms for the square root arguments to derive a simpler equation.
  • Another mentions using Taylor series for approximation when a full square is not achievable.
  • There is a discussion about factoring the polynomial and finding roots, including the use of Horner's scheme for polynomial evaluation.
  • Questions arise regarding the applicability of the discussed methods to other polynomial forms.
Participants have shared various methods and insights, with some confirming the effectiveness of suggested approaches. There is ongoing exploration of different interpretations and techniques, but no consensus has been reached on a singular method for solving the original equation.
Some participants specify that the discussion is limited to cases where a, b, c, d, and e are integers, which may influence the methods considered.
liskawc
[SOLVED] how to solve and equation?
sqrt(ax^2 +bx) - sqrt(cx^2 + dx) = e
where you know a,b,c,d and e
i don't know
i put the entire equation on the power of 2 and then simplified adn then repeated again ... and i got an equation of 4th grade (ax^4+bx^3+...=0)
and well i can't solve it so i retuned back to my original problem :)
If the first sqrt argument was a form (x+p)2 and the second sqrt argument was (x+q)2, then one would have a form
x+p + x+q = e
or x = 1/2 (e - p - q) and don't forget roots +/-
hmm sadly its not a full square :(
solved it with taylor series (got and estimate and its better then nothing)
I'm talking only about the case when a, b, c, d and e are integers.
First of all, substract e from both sides you get the form (let d - e = f) ax[tex]^{4}[/tex] + bx[tex]^{3}[/tex] + cx[tex]^{2}[/tex] + f = 0
Then you have to factor the equation to a(x - x[tex]_{1}[/tex])(x - x[tex]_{2}[/tex])(x - x[tex]_{3}[/tex])(x - x[tex]_{4}[/tex]) = 0.
To do this you must first figure out one of the roots. All roots are in the set of [tex]\frac{d}{a}[/tex] divisors, so what I usually do is try to input all those divisors as x. Now, when you find one root, you must input it in Horner's scheme.
1)In Horner's scheme you put in the line A all coefficients of x[tex]^{n}[/tex] - a, b, c and d. In position C1 (look at the example) you place the root you guessed. Now rewrite the coefficient from A2 to C2. Multiply C2 with the root (B1) and write the number at B3. Now add to it A3 and write it at C3. Multiply C3 with the root and rewrite it at B4. Add A4 to B4 and rewrite the sum at C4. Now multiply it with the root and rewrite the product at B5. etc. Do you see the algorithm? If no, then http://en.wikipedia.org/wiki/Horner_scheme" it might me explained a bit better. Anyway, if C6 is not 0 then check your calculations again or the root might be not a root. Now the C line are coefficients for (x - x[tex]_{1}[/tex])(C2x[tex]^{3}[/tex] + C3x[tex]^{2}[/tex] + C4x + C5) = 0. Now factor the part in second brackets until you reach the form previously mentioned where x[tex]_{1}[/tex], x[tex]_{2}[/tex] etc. are the roots you need.
Here's an example:
5x[tex]^{4[/tex] - 3x[tex]^{3}[/tex] - 4x[tex]^{2}[/tex] - 3x + 5 = 0
I find that one of the roots is x[tex]_{1}[/tex] = 1 so
1. 2. 3. 4. 5. 6. ==== position numbers
| 5 -3 -4 -3 5 (A)
1 | 5 2 -2 -5 (B)
5 2 -2 -5 0 (C)
Now I have 5(x - 1)(5x[tex]^{3}[/tex] + 2x[tex]^{2}[/tex] - 2x - 5) = 0
On 5x[tex]^{3}[/tex] + 2x[tex]^{2}[/tex] - 2x - 5 I use Horner's scheme again. I guess that one root x[tex]_{2}[/tex] = 1 and...
| 5 2 -2 -5
1 | 5 7 5
| 5 7 5 0
Now I have 25(x - 1)(x - 1)(5x[tex]^{2}[/tex] + 7x + 5) = 0
You probably now how to factor 5x[tex]^{2}[/tex] + 7x + 5 so I get
125(x - 1)(x - 1)(x - (7 + 2[tex]\sqrt{6}[/tex])/2)(x - (7 - 2[tex]\sqrt{6}[/tex])/2) = 0
If the result is 0 then at least one of the multipliers must be 0. So x[tex]_{1}[/tex] = x[tex]_{2}[/tex] = 1; x[tex]_{3}[/tex] = (7 + 2[tex]\sqrt{6}[/tex])/2; x[tex]_{4}[/tex] = (7 - 2[tex]\sqrt{6}[/tex])/2).
I hope that helps.
Whew, that tok a lot of time. If something is unclear, and it probably will be from what I've written, feel free to ask.
tried it and it works :D thank you (does it work for x^n+... aswell?)
Yes, in x[tex]^{n}[/tex]+... n is the max number of roots by the way.
cool :)
thanks
  • · Replies 21 ·
  • · Replies 27 ·
