Alkyl halides left in an open container what happens?
  • Thread starter Thread starter saching
    Container
When alkyl halides (RCI and RBr) are left in an open container, the more volatile halide will evaporate, resulting in a composition shift towards the less volatile halide. This phenomenon occurs due to the differences in vapor pressure between the two compounds. As the more volatile halide evaporates, the remaining mixture becomes increasingly enriched in the less volatile halide, altering the overall composition over time.
  • Understanding of alkyl halides and their properties
  • Knowledge of vapor pressure and volatility concepts
  • Familiarity with basic chemical reactions and nucleophilicity
  • Experience with experimental chemistry and data interpretation
  • Research the vapor pressure of specific alkyl halides like RCI and RBr
  • Study the principles of nucleophilicity and its measurement
  • Explore the effects of environmental factors on chemical reactions
  • Learn about the implications of evaporation in chemical mixtures
Chemistry students, educators, and researchers interested in the behavior of alkyl halides and the principles of volatility and composition changes in chemical mixtures.
saching
A student left some alkyl halides (RCI and RBr) in an open container for several hours. What happened to the composition of the halide mixture during that time? Assume that some liquid remains in the container.
From: http://www.ipfw.edu/chem/254/254%20Fall%2005/CHM%20254%20Experiment%2024.htm The experiment had to do with measuring the nucleophilicity of different nucleophiles.
I've thought about this problem a number of ways but can't seem to make much progress. At first I thought the halides might be volatile and evaporate into the vapor. That seems right given the hint--but that doesn't tell me what would happen to the composition of the halide mixture other than that the more volatile one would evaporate further.
I've also pondered the idea that water vapor from the air might go into the mixture and cause some kind of reaction although I think that would be a bit much to assume.
Any ideas?
If one evaporates more easily, mixture becomes richer in the other one. I don't think you can say anything more.
52K
  • · Replies 23 ·
25K
65K
