Velocity Transform: Solving Homework Questions
  • Thread starter Thread starter Skullmonkee
    Velocity
The discussion focuses on solving a relativistic velocity transformation problem involving two ships and a missile. The first ship moves away from Earth at speed v, while the second ship, launched from the first, also moves at speed v relative to the first ship. The participants confirm that the speed of the second ship relative to Earth is calculated using the formula u=(u'+v)/(1+[vu'/c^2]), resulting in u=2v/(1+[v^2/c^2]). For the missile's speed relative to Earth, the same formula is applied, leading to a more complex expression involving the final velocity and hyperbolic tangent identities.
  • Understanding of relativistic velocity transformation
  • Familiarity with the equation u=(u'+v)/(1+[vu'/c^2])
  • Basic knowledge of hyperbolic functions and their application in physics
  • Concept of invariant speed of light (c) in relativity
  • Study the derivation of the relativistic velocity addition formula
  • Explore hyperbolic functions and their relevance in special relativity
  • Practice solving problems involving multiple objects in relative motion
  • Learn about the implications of approaching the speed of light in relativistic physics
Students and educators in physics, particularly those studying special relativity, as well as anyone interested in understanding relativistic motion and velocity transformations.
Skullmonkee
A spaceship moves away from a point at speed v and launches a smaller ship at speed v relative to the first ship. The second ship shoots a missile at speed v relative to the second ship
1. what is the speed of the second ship relative to Earth
2. what is the speed of the missile relative to Earth
I assume that in order to get the speed of the first ship relative to Earth i just use the velocity transform u=(u'+v)/(1+[vu'/c^2]), which gives u= (v+v)/(1+[v^v/c^2]) or u= 2v/(1+[v^2/c^2])
Is this correct?
If so, to find the speed of the missile relative to Earth would i again use the same equation using the 2v/(1+[v^2/c^2]) as u'? Would this give the answer to part 2?
Im confused.
I think that's what you are supposed to do, yes.
hi can i ask, since i am doing same question.. i understand part a.. just simple transforms, but what did u mean by using u=2v/(1+v^2/c^2) for b?? then the answer for b would be... solving for u'?
Well my thinking was that because the speeds are not a number value (they are given as 'v'), to find the answer for part 1 you must find u and simplify. This gives u= 2v/(1+[v^2/c^2]).
For the second part the u that was found in 1. becomes u' in part 2. (Sorry i forgot to add the ' to the u)
Now I am just confusing myself and I am not sure if it is right or not.
ya that's wat i was thinking... btu when u do that calculation, u get a weird answer... but anyways thanks for ur help
Since you both seem to be on the right track, the answer I get (for you to compare to) is
\frac{ 3 v + (v^2 / c^2) v }{ 1 + 3 (v^2 / c^2) }
Yes, it looks a little weird.
Writing it in terms of \beta = v / c gives the still a bit weirdly looking
\frac{ \beta(3 + \beta^2) }{ 1 + 3 \beta^2 } c
Thanks CompuChip. but how did you derive that answer? I tried doing it myself but got really lost.
I just plugged u = 2v/(1+v^2/c^2) back into the addition formula and simplified it (ok, maybe I cheated a bit by letting the computer simplify it).
Where did you get stuck?
I got stuck in the algebra. After plugging it into the formula as you did.
sorry didnt see the c... = (
Formulas in relativity are related by using hyperbolic tangent identities.
That is to say that we relate
tanh(v_final/c) = tanh(u/c) + tanh(v/c)
where v_final is the final velocity and u and v are the initial velocities. Note that the velocity addition formula means that everything is relative to c so that we can not travel faster than light but only relative to it. Think more or less like the speed of light being some kind of infinity where we approach but never reach c. This should help you hopefully understand this relationship.
  • · Replies 16 ·
  • · Replies 17 ·
