unusualname said:
jambaugh just complicated the issue by spamming the thread with an unnecessary personal interpretation of QM...
Firstly my "personal" interpretation is the orthodox one. It just doesn't get as much Hollywood airtime since it doesn't predict such ridiculous effects as FTL signals or infinite parallel dimensions that makes for good SciFi plot elements or fantastic article titles in the popular press.
Secondly the quickest way to prove a theory (with multiple interpretations) doesn't in anyway predict an effect is to demonstrate that a valid interpretation of that theory excludes that effect. (Similar to demonstrating that say the parallel postulate is not a result of the other postulates by demonstrating a valid model satisfying the other postulates but definitely invalidating the parallel postulate).
Thirdly and finally, I am not initiating the invocation of interpretations here. The whole FTL business comes from a ("mis")interpretation of the QM. I'm just piping in with classic CI for equal time.
To zeromodz,
zeromodz said:
Okay, I understand what you mean by both particles still don't have definite states objectively, but wouldn't the particles show any objective sign whatsoever of the collapse of the function?
To make it clear, "not having an objective state" implies no observation of an objective state. Without such observation there is no possibility of observing a change. "any objective sign" as I understand your meaning must mean an observable sign.
Also The wave-function is initially (in the sequence of definition) a representation of our knowledge about the system. It takes an act of (mis-)interpretation to also give it meaning as a representation of a state of reality. In the first case the collapse is just a representation of the change in our knowledge about the system. Only if you add the "reality" do you assert that this collapse is actually occurring "out there" in the same instantaneous way that it is occurring on paper (and thus get instantaneous (meta)physical effects instead of just instantaneous updates in predictions.)
Without that ("mis")interpretation one can only say that the wave-function collapse is expressing the same sort of discontinuity as we see in a classical probability distribution collapse once one invokes new information. One is making the transition to a conditional probability. "Give we observed X we no longer look at Pr(A) but Pr(A|X)." e.g. "Once we know the number 4 is drawn in the lotto, all the tickets without a 4 instantaneously become worthless."
Now you can choose an alternative to the minimal interpretation I describe provide it consistent as far as empirical predictions goes. But given it is consistent with QM and given it doesn't predict beyond the predictions of QM it cannot predict phenomena inconsistent with the orthodox Copenhagen interpretation. Since that interpretation is consistent with relativistic causal locality and with QM there is
a.) no way QM explicitly predicts an observable FTL causal event (of which a FTL signaling device would certainly be an example) and
b.) no way an FTL causal event is consistent with both QM and relativity.
This does not preclude an alternative theory: "QM plus a a relativity violating theory" which allows FTL signals. But my point is that adding QM in no way adds to our expectation of FTL effects. Speculating about "hyperwave radios" and "warp drives" are independent of the assertions of QM excepting that they should be consistent with QM if you believe in QM. But it is simply speculating both classically or quantum mechanically that relativity is wrong and not inferring anything at all from QM itself.
Ask if there is any way we might sent an FTL signal. Why invoke QM per se?
P.S. Actually, technically Relativity doesn't preclude FTL causality as such. It simply asserts that FTL causal signals as seen by one observer are backward in time signals as seen by another. You cannot invoke FTL without invoking Time Travel and remain consistent with relativity. It is sufficient to resolve the causal loop paradoxes one generates by asserting backward-in-time communication to retain both relativity and the hoped for FTL causation. But without some empirical examples such belief is an act of faith and such speculation is just "out there".
