Manifold / Atlas / Chart (Building Simple Example)
This discussion centers on the concepts of manifolds, atlases, and charts in the context of a proposed example involving velocity changes during a space flight. The user inquires whether three distinct velocity segments (A-B, B-C, C-D) can be represented as charts within an atlas for a manifold. The consensus, articulated by a participant named Ben, clarifies that manifolds are fundamentally topological objects and do not pertain to motion or velocity. Furthermore, the proposed example does not qualify as a manifold, as it lacks the necessary topological structure.
  • Understanding of manifold theory and topology
  • Familiarity with the concepts of atlases and charts
  • Basic knowledge of metrics in mathematical contexts
  • Comprehension of homeomorphisms and their role in topology
  • Study the definition and properties of manifolds in topology
  • Explore the construction and application of atlases and charts
  • Learn about metrics and their significance in defining geometric structures on manifolds
  • Investigate examples of manifolds in various mathematical contexts, including R^n
Mathematicians, students of topology, and anyone interested in the foundational concepts of manifold theory and its applications in various fields of mathematics.
ldechent
I’m studying GR and am curious about manifold, atlas and charts. I have an idea for building a simple example, in one dimension, and wanted to ask if what I’m doing below is “legal”/correct. Imagine a space flight that can be divided into three segments:
  • A-B: velocity starts at zero and it increases at a constant rate to the cruising velocity
  • B-C: velocity is constant at the cruising velocity
  • C-D: velocity decreases at a constant rate from the cruising velocity to zero
Can I say that the above three scenarios can correspond to three charts which we would use in an atlas for a manifold?
The metrics for the first and last chart vary with position to offset or counter (probably could find a better word) the change to velocity. This is done in a way that points on the travel line that are equally spaced chronologically will appear equally spaced. We might say that A-B and C-D are sort of “cousins” to semi-log graph paper. Comment and suggestions are appreciated.
Hi, Idechent,
Welcome to PF!
Manifolds don't relate to motion. In fact, manifolds are even more basic than measurement. A manifold is a purely topological object. For example, a coffee cup is the same manifold as a doughnut.
When we add a metric onto a manifold so that we can have a system of measurement, that's extra machinery, like the air conditioner in a car.
-Ben
A manifold is an entity that is equipped with a maximal atlas which is composed of smoothly sewn charts which are homeomorphisms from an open subset of the manifold to an open subset of R^n. A manifold doesn't have to be geometric per say; there are sets of rotations that qualify as manifolds. However, the scenario which you have described is not really a manifold.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 47 ·
  • · Replies 0 ·
