- 10,876
- 423
Anyone have a good example of a closed subset of a topological space that isn't closed under limits of sequences?
The discussion centers around the properties of closed subsets in topological spaces, specifically focusing on examples of closed sets that are not closed under limits of sequences. Participants explore the cocountable topology and its implications for sequence convergence.
Participants generally agree on the properties of closed sets in relation to limits of sequences, but there is no consensus on specific examples or the implications of these properties in different topological contexts. Multiple competing views and examples remain present in the discussion.
Some limitations include the dependence on the definitions of closed sets and the cocountable topology, as well as unresolved mathematical steps regarding the nature of convergence in different topological spaces.
Hi. I actually laughed out loud when I went back here after only ten minutes and saw that you had already replied.micromass said:Hi Frederik!![]()
Ah yes. I actually had that right in my mind a few minutes earlier, but somehow got it wrong anyway when I made the post. This is what I was thinking before my IQ suddenly dropped 50 points: In a metric space, a set is closed if and only if it's closed under limits of sequences. In a topological space, the corresponding statement is that a set is closed if and only if it's closed under limits of nets. Since sequences are nets, a closed set must be closed under limits of sequences. These statements suggest that there's a set E that's closed under limits of sequences and still isn't closed. Then there should exist a convergent net in E, that converges to a point in Ec. That's the sort of thing I originally meant to ask for an example of, but your example illustrates the point as well.micromass said:Every closed set of a topological space is closed under limits of sequences! It's the converse that's not true.
It took me a while to understand this, but I get it now. It's a good example. It's a weird topology since even 1/n→0 is false in this topology. I think I also see an example of the kind I originally had in mind: Consider the cocountable topology on ℝ. Let E be the set of positive real numbers. Let I be the set of all open neighborhoods of 0 that have a non-empty intersection with E. Let the preorder on I be reverse inclusion. For each i in I, choose xi in i. This defines a net in E with limit 0, which is not a member of E.micromass said:\mathcal{T}=\{A\subseteq X~\vert~X\setminus A~\text{is countable}\}\cup\{\emptyset\}
Every convergent sequence in this topology is (eventually) a constant sequence. Thus all sets are closed under limits of sequences.
Thanks. I wasn't familiar with this terminology.micromass said:Some terminology: a set that is closed under limits of sequences is called sequentially closed. A topological space where closed is equivalent with sequentially closed, is called a sequential space. As is well-known, all first-countable spaces are sequential.
wisvuze said:Hi micromass, if you remember us talking about topology books in the PF chatroom, this is discussed in the topology book by wilansky: https://www.amazon.com/dp/0486469034/?tag=pfamazon01-20
and the exact same answer/example is given too, with the cocountable topology and how every sequence would have to be eventually constant. ( it's cool! )
Not that I'm contributing much to the conversation, but I just wanted to point that out
