Understand the Collision of Electrons - Get Clarity from 'pf mentor
  • Thread starter Thread starter Amrutha.phy
    Collision
The discussion clarifies that the spin quantum number of electrons relates to their intrinsic rotation rather than their movement around the nucleus. Electrons exist in orbitals, which are probability clouds, and the concept of them colliding in a classical sense is deemed nonsensical. Instead, electrons in the same orbital do not collide due to their wave functions and the repulsive forces between like charges, which keep them positioned as far apart as possible. The interaction between electrons is already accounted for in quantum mechanics, and while they can be found at the same position with opposite spins, this does not lead to instability in the atom. Overall, understanding electron behavior requires embracing the complexities of quantum mechanics rather than relying on classical analogies.
Amrutha.phy
I got the concept of spin quantum number and got enlightened of the fact that it has got nothing to do with the movement of electron around the nucleus and that it is concerned only with the rotation of electrons about their own axis. I thank 'pf mentor' for giving me clarity about that. But I still don't get why two electrons present in the same orbital don't collide each other.. I didn't understand the example of surface of a ball and orbital. So please don't mind clarifying my doubt..
First of all, there is no end-all analogy for the quantum world. As soon as you understood the first watered down analogy I gave and found the flaw in it, you'd be right back at the doorstep looking for the next one. And so on, and so on, until sooner or later my analogy would be 'electrons act like electrons because electrons act like electrons.' And you would say, "What a douchebag, he just wasted all this time to say nothing." There is no way to completely discuss the quantum world using English, if there was, there would be no Physicists, only English majors (and what a sad world that would be.) That being said, here we go.
We don't think of electrons orbiting the nucleus anymore. Electrons exist in orbitals, probability clouds, around the nucleus. The word orbital means 'similar to an orbit.' It's not an orbit, it will never be an orbit, and no matter how closely you look at it or hard you think about it: it's not an orbit. We observe electrons in the orbitals using statistical methods so we wouldn't know when and where they collide or if they collide at all. The question 'do electrons in the same orbital collide?' is nonsensical. There is no classical interpretation of the quantum mechanical model of atomic electrons. The QM model is the only tool we have to understand atomic physics, so why would it matter if they collided in the first place?
I do know that in practical two electrons in the same orbital do not collide with each other because if that happens atom wouldn't be stable. But how can they exist without colliding one or the other time.. I'm sure there is an answer for it and hope I get it...
They are not billard balls which could collide in a classical sense.
Their interaction is already part of their wave functions in the atom.
Like charges repel. The electrons try to position themselves around the atom the furtherest they can get from each other (there are more rules to this but I can't remember them - the electrons are attracted to the positively charged protons - but not to each other). The closer the electrons are to each other the greater the repulsion - Colombs law.
The electrons arrange themselves into shells. If the shells need more electrons to be stable, the atom will react with another chemical if it gets the chance. Oxygen's outer shell needs two electrons to be stable - and Hydrogen has a single electron, but needs another one for it's shell to be stable - so they react and produce H20 -Two Hydrogens and one oxygen = water.
In QM, electrons with opposite spins actually *do* collide with each other, if you want to use these terms. The pair distribution function,
<br /> g(x,x&#039;) = \frac{\langle \psi^\dagger(x)\psi^\dagger(x&#039;)\psi(x&#039;)\psi(x) \rangle }{\langle \psi^\dagger(x)\psi(x)\rangle \;\langle \psi^\dagger(x&#039;)\psi(x&#039;)\rangle },<br />
with psi being the field operators, describes the probability of finding two electrons at spin-positions x and x' simultaneously, divided by the probability of finding them at positions x and x' individually. This function can be evaluated in practice in molecules and other correlated electronic systems (say, the uniform electron gas) and turns out to *not* be zero in general for x1 and x2 at the same position, but with opposite spin.
The reason this is not associated with an infinite Coulomb energy is that the volume element in which the energy is infinite is also infinitesimally small. This just results in so called derivative-discontinuities in the wave function.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 36 ·
  • · Replies 473 ·
31K
