Determining whether this equation is a subspace?
  • Thread starter Thread starter Cottontails
    Subspace
2 replies · 3K views · last reply
Cottontails
There is a vector space with set F, of all real functions. It has the usual operations of addition of functions and multiplication by scalars. You have to determine whether this equation is a subspace of F: [tex]f''(x) + 3f'(x) + x^2 f(x) = sin(x)[/tex]
[tex]f''(x) + 3f'(x) + x^2 f(x) = sin(x)[/tex] the 0 vector/function
So, to test that it is non-empty set I used the 0 vector/function. However, is this the same as letting "x=0"? If so, it would then be:
[tex]f''(0) + 3f'(0) + x^2 f(0) = sin(0)[/tex] and therefore [tex]0 = 0[/tex] proving that the set is non-empty.
As, wouldn't it be what value also makes sin(x) = 0 (which is x=0) and so, would this be correct?
I just want to clarify whether it is before I continue further with solving the problem.
Equations can't be subspaces. I assume that the problem is asking you to check if the set of solutions of the equation is a subspace of F. Note that this set is a subset of F.
The zero vector in F is the function that takes every x in ℝ to the number 0. You should verify that this function has the properties a zero vector is supposed to have.
As Fredrik said, an equation is not a "subspace" what you want to determine is whether the set of all functions satisfying that equation is a subspace.
No, it is not, the 0 "function" is f(x)= 0 for all x.
No, that is incorrect. You cannot set x= 0. If f(x)= 0 for all x, then its first and second derivatives are also 0 but the right hand side is not.
