Conservation of Energy and Angular Speed.
The discussion revolves around applying the conservation of energy principle to determine the speed of two blocks and the angular speed of a pulley in a system that starts from rest. The problem involves concepts from mechanics, specifically energy conservation, rotational dynamics, and kinematics.
  • The original poster attempts to calculate the kinetic energy and moment of inertia, expressing uncertainty about their understanding of the concepts involved. They question the correctness of their calculations and seek clarification on deriving angular speed from linear speed.
Participants have provided some guidance on relating the speed of the blocks to the pulley's surface speed, indicating that the rope's non-slipping condition is crucial. There is an ongoing exploration of the relationships between translational and rotational speeds, with some participants affirming the correctness of the original poster's approach without a definitive consensus on all aspects of the calculations.
The original poster expresses confusion and seeks validation of their calculations, indicating a need for further clarification on certain concepts and relationships in the problem setup.
astro2525
Use the conservation of energy law to find the speed of the blocks and the angular speed of the pulley when the heavier block hits the ground. The system starts at rest. (going to include picture)
http://i.imgur.com/CjB3gzK.jpg
Moment of inertia for a disk (I believe): I = (1/2)mR^2
KE = (1/2)m*v^2
KE of pulley = (1/2)I(v/R)^2
R = radius .2 m
m1 = 10 kg rock
m2 = 4 kg rock
mp = mass of pulley
Tried reading some things out of my textbook but that didn't help much =(. Decided to let the PE of each block at it's initial position be 0, so the amount of GPE that is converted to KE is:
KE = (10 kg - 4 kg)(9.8 m/s^2)(2 m) = 117.6 J
calculate moment of inertia:
I = (1/2)mpR^2 = (1/2)*2*.2^2 = .04 kg*m^2
then the KE of the system:
K = (1/2)(m1 + m2)v^2 + (1/2)I(v/R)^2
K = v^2(1/2)[10 kg + 4 kg + (.04 kg*m^2 / (0.20 m)^2)] = v^2(7.5 kg)
Set v^2(7.5) equal to the available energy that was converted from PE and solve for v:
v = √(117.6 J / 7.5 kg) = 3.96 m/s
Is this stuff even right? I basically just derived it from my textbook and am having a hard time completely understanding it. Really not sure how I would get angular speed .. would it just be ω = v / R?
Rereading this gives me a headache so if anyone helps, I commend you! ;D
The key for the angular speed is seeing that the speed of the blocks has to equal the speed of a point on the pulley's surface as it rotates, seeing as the rope doesn't slip.
care to elaborate? lol, not sure how I would go about doing that
You've already found the velocity of the block. The velocity of the block must equal the velocity of a point on the pulley's surface. Using that, apply the equation that relates translational speed to rotational speed.
so it is ω = v / R ?
ω = 3.96 m/s / .20 m = 19.8 rad/s?
Btw, do you happen to know if all the other stuff is right?
I didn't analyze your work equation by equation but the method did seem correct. And yep, your method to find the angular velocity is correct :)
Sweet, thanks a lot =D
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 16 ·
