1st order PDE, seems easy but still confusing
  • Context: Graduate
  • Thread starter Thread starter Irid
    Confusing Pde
The discussion centers on solving the first-order partial differential equation (PDE) given by \(\frac{\partial q(x,y,t)}{\partial t} = -(x^2 + y^2)q(x,y,t) + ax\frac{\partial q(x,y,t)}{\partial y}\). Two initial conditions are considered: \(q(x,y,t=0) = 1\) and \(q(x,y,t=0) = \delta(x,y)\). The participant initially proposed two solutions but struggled to satisfy the initial conditions. Ultimately, the Method of Characteristics was identified as the effective approach, leading to the general solution \(q(x,y,t) = C(x,axt+y)\exp(\frac{xy}{a}+\frac{y^3}{3ax})\), which satisfies the delta function initial condition.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the Method of Characteristics
  • Knowledge of initial conditions in PDEs
  • Basic concepts of scalar fields in physics
  • Study the Method of Characteristics for solving first-order PDEs
  • Explore the implications of initial conditions on PDE solutions
  • Learn about scalar fields and their applications in physics
  • Investigate advanced techniques for solving PDEs, such as separation of variables
Students and researchers in physics and applied mathematics, particularly those working with partial differential equations and their solutions.
Irid
Hello,
I am doing some physics and I end up with this PDE:
where q(x,y,t) is the scalar field to determine and a is a parameter. I need to consider two types of initial conditions: q(x,y,t=0) = 1; and q(x,y,t=0) = delta(x,y).
I have found two tentative solutions:
q(x,y,t) = C\exp \left(-\lambda s + \frac{y}{ax}(x^2 + y^2/3 - \lambda) \right)
where lambda is any (?) number. Another solution is
q(x,y,t) = C\exp \left(-sx^2 + -y^3/3ax\right)
They both seem to satisfy the PDE, but I can't make them satisfy the required initial condition (either 1 or delta function). Any ideas or experience with this kind of equations?
I don't see a 't' in either solution. Did you substitute it with s?
Oops, sorry, I did.
Actually I think I figured out how to find the solution. It's by the Method of Characteristics. No more help needed...
Substitute q(x,y,t)=X(x)Y(y)T(t) and treat x and X(x) as constants and then try to separate the equation to two ordinary ones.Then solve those two ODEs.The general answer is the linear combination of the answers to the ODEs but the coefficients will depend on x.
The general solution to your PDE is
q(x,y,t) =C(x,axt+y)\exp(\frac{xy}{a}+\frac{y^3}{3ax}),
where C(x,y) is an arbitrary function.
So
q(x,y,t) =δ(x,axt+y)\exp(-\frac{t(a^2t^2x^2+3atxy+3x^2+3y^2)}{3})
is the solution with
q(x,y,0) =δ(x,y).
  • · Replies 36 ·
