2 Polarizers attenuating a light beam
11 replies · 2K views
stefan3423
An angle is given between 2 polarizer's (45 degrees), through them light passes (unpolarized than after passing through the first one it polarizes), some of the light its shown on the display. For how much does the angle needs to be increased for the intensity of light to be 2 times less if the starting angle is 45 degrees.
Given Var:
α=45°
I=I0cos2α
The answer in textbook:[/B]
α21=+15°
My work:
My answer:(Side note I have a little error instead of II2 its I2, everything else is correct).
Hi Stefan3423 and welcome to PF.
If the light intensity before going through the first polarizer is I0, what is it after it passes through it?
Given Var:
α=45°
I=I0cos2α
α21=+15°
My work:View attachment 217015
The diagram is ok, but that is not really an attempt at a solution. Please show some thoughts at least.
Well I know that cos of 90 degrees=0 which means no light will go through the crystal and if cos of 0 degrees=1 i.e the crystal cross section will match thus max polarised light will pass through
Another polirised beam of light with max intensity but the secound poliriser is at angle of 45 degrees
You did not answer my question. If the intensity of the beam is I0 before the first polarizer, what is it after that polarizer? I am talking about the intensity between P1 and P2 in your drawing. There is no 45 degree angle involved, yet.
It starts with 45 degrees.BTW I solved it, found my errors and I will post my answer now.
Please do so.
Instead of II2 is I2=I1/2
Polarized light going through a filter at angle α emerges with intensity I0cosα2. A single photon going through the same filter has the same probability of being detected on the far side. Is this a general rule: intensity reduction factor = single photon detection probability? In which case, the Schroedinger function, where probability = amplitude2, is a kind of "square root wave"?
