2 questions about Neutrino oscillations
  • Level: Graduate
  • Thread starter Thread starter Dmitry67
    Neutrino Oscillations
19 replies · 5K views
Dmitry67
Two questions.
1. Different flavors have different mass. Look at it from the frame where neutrino is at rest. What’s about energy conservation? Are neutrinos oscillating so quickly that uncertainty principle plays role?
2. Why oscillations of neutral Kaons form 2 new “particles” (K-long and K-short) – why neutrinos don’t produce such mixtures?
This is incorrect. The point is that the flavor eigenstates do not have a definite mass - they are a mixture of different mass eigenstates. Likewise the mass eigenstates do not have a definite flavor - they are a mixture of different flavor eigenstates.
As phyzguy says, the flavor eigenstates in which neutrinos are produced are not the same as the mass eigenstates. Therefore it's not accurate to talk about, for example, the mass of the electron neutrino, because it is not an eigenstate of mass. The mass eigenstates are analogous to the KL and KS states we see in the kaon system.
Energy is exactly conserved. But in any reaction there is always a small spread in energy. What makes neutrinos unique is that their mass differences are so small that the process that produces them yields a coherent mixture of mass eigenstates.
Thank you, it makes sense now.
But what is Feynman diagram for neutrino oscillation? For Kaons, W+/W- play role in changing quark contents, and for the neutrinos? It is just a line representing one flavor suddenly becomes the other flavor?
Let's take the OPERA experiment as an example. At CERN the production process is W → μ + neutrino. At Gran Sasso 730 km away the detection process is neutrino → W + τ. Conventionally we say "a muon neutrino was produced, and during its flight it mutated into a tau neutrino." Whereas in fact the unobserved neutrino is one of the three mass eigenstates, ν1, ν2, ν3. At the vertex in CERN there were three amplitudes W → μ + ν1, W → μ + ν2 and W → μ + ν3, and correspondingly at Gran Sasso there are three, ν1 → W + τ and so on. The three processes are coherent.
In other words, the process isn't represented by a single Feynman diagram, but rather, by the sum of three Feynman diagrams.
Wait, still not clear...
"mass eigenstates do not have a definite flavor" - makes perfect sense.
regarding
"flavor eigenstates do not have a definite mass - they are a mixture of different mass eigenstates" - are they mixture of exactly 3 mass eigenstates, or, as flavor does not change only during very short time we don't have the exact mass just because of the uncertainty principle?
In another words, in Standard Model, extended to accommodate neutrino masses, how many NEW parameters are there for neutrino masses: 1 or 3?
Yes.
The model currently accepted is that there are simply three new mass parameters. The true nature of neutrinos is still being experimentally confirmed.
LA LA LA LA! Can't HEAR you! :smile:
Real physicists do not talk about the uncertainty principle. We talk instead about coherent states. A flavor state is a coherent superposition, |f> = a|v1> + b|v2> + c|v3>. The three mass states coexist coherently, like the two possible states of Schrödinger's cat. They are coherent because we have done nothing to distinguish them. If the energies of the particles in the reaction that created the neutrino were measured to within a millionth of an eV or whatever, we would know the mass of the neutrino state, and hence know which of the three eigenstates it was. The three eigenstates really do have different energies, but it's not from lack of energy conservation, or shortness of time, or the uncertainty principle.
The wavefunction of a state with energy E oscillates in time like eiEt/ħ, and so if you wait long enough, the terms in a|v1> + b|v2> + c|v3> eventually get out of phase with each other. This alters the probability of its decay into a flavor state, and we see that effect as "neutrino oscillations."
I see, and yes, I am not a real physicist :)
So currently we can't measure neutrino masses yet, but are there any constraints on ratios Mass(u neutrino)/Mass(e neutrino), Mtau/Mu?
Plus 4 mixing parameters, similar to quark mixing. They determine which superposition of mass eigenstates the flavour eigenstates are (and vice versa).
After reading the PDF, so the precision of the current experiments are at least one order above the precision, required to measure the neutrino mass?
If they are worse, their precision is lower, not higher.
The indirect measurements (difference of mass squared via mixing) cannot be used to calculate neutrino masses, but you can get an idea where they might be. And the current upper limits for direct mass measurements are still above that, right.
What is measured is the differences in the squares of rest masses, right? And 2 such differences exist.
Is there any evidence that all 3 neutrino mass eigenstates possesses rest mass? Existence of a massless particle is not contrary to general relativity (see photon)... so how about mixing of massless particle with 2 massive ones?
There are 3 differences (1<->2, 2<->3, 1<->3), and as (most?) mixing measurements are not sensitive to the signs all 3 are interesting on their own.
I did not see any. One neutrino could be massless, but that would be quite odd.
Squares? Is it possible that they have negative rest masses?
Does a neutrino signal split into three during travel according to mass eigenstates, or does the signal have a single average speed over the oscillations?
At least 4 mixing parameters. If neutrinos turn out to be Majorana particles, there will be 2 extra CP violating phases in addition to those 4 parameters.
