2 questions in electromagnetism.
18 replies · 3K views · last reply
1. In a dilectric sphere with radius a and polarization vector P= P0 r (r is the spherical radial vector) where P0>0. find D,E and the polarization charge volume density and area density.
2. A chagrge q is displaced at the centre of a hollow dilectric sphere (with a,b as its internal an outer radii), the dilectric constant e(r) depends on the radial distance, find E,D,P.
Maxwell (electrostatic) Equations and boundary conditions.
For 1, I found the charge densities, [tex]\rho ' =-\nabla \b{P}= -3P0[/tex] and [tex]\sigma ' = -(\b{P}_{inside \ sphere} - \b{P}_{outside \ sphere})\cdot \b{n}= P_0 a[/tex], Now I don't know how to find D and E, from the boundary conditions I know that:
div D= [tex]4\pi \rho_{free}[/tex] and that [tex]\sigma_{free} = -(\b{D}_{inside \ sphere} - \b{D}_{outside \ sphere})[/tex], and E I can find after I find D, by the fact that D=E+4pi P.
I suppose that [tex]\sigma_{free}=-\sigma '[/tex] cause the net charge is zero, and the same with volume densities, from both equations and from the symmetry of the problem (D is spherical radial) I can find D, I am not sure if this is valid.
For 2, not sure either, if I find D then E=D/e(r), and P=(e(r)-1)/4pi)E, the question is how do I find D?
Thanks in advance.
Do you know the relations?
[tex] \mathbf{P}=\varepsilon_0\chi_e\mathbf{E}[/tex]
and
[tex] \mathbf{D}=\varepsilon_0\mathbf{E}+\mathbf{P}[/tex]
these should help with both problems
Yes, I know them (but in cgs system).
OK, I see now how I can solve question #1, but not sure how to answer question #2, can you help me with question #2?
thanks.
Wait a minute, the first equation is valid only for linear materials, in the first question it's not given that the material is linear (i.e E is proportinal to D).
It doesn't say it's not linear either. For nonlinear polarization,
[tex] P_i=\sum_j\varepsilon_0\chi_{ij}E_j[/tex]
I would assume you should go with what I wrote first, since you don't have the matrices needed to solve the nonlinear term.
For problem 2, wouldn't this just be Gauss's Law in dielectric form?
[tex] \oint \mathbf{D}\,d\mathbf{S}=Q_{enc}[/tex]
and from D, find E and P?
It also doesn't say there aren't a bunch of free charges scattered about, but I see no reason to assume there are.
That still looks like a linear relationship to me (If you double E, you double P)...Just because the material doesn't polarize parallel to E, doesn't mean its nonlinear.
True, but in non-linear cases, it is not [tex]\mathbf{E}[/tex] that is the non-linear term, it's the [tex]\chi_{ij}[/tex] that is the non-linear term.
That looks a little odd to me...are you sure the problem doesn't specify [itex]\textbf{P}=P_0\hat{\textbf{r}}[/itex] (i.e. the polarization has a constant magnitude and points radially outward)?
What makes you think the net charge s zero? Unless you are given information to the contrary, I would assume there are no free charges. You can then calculate E directly from the bound charges using Coulomb's Law (or Gauss' Law) and D can be determined directly from its definition.
I'm not sure what you mean by this...unless [itex]\chi_{ij}[/itex] are functions of [itex]E[/itex] (which is not at all implied by the way you've written the equation), the relationship is linear.
Normally you would Taylor expand the relationship into more terms:
[tex] P_i=\varepsilon_0\left(\sum_j\chi^{(1)}_{ij}E_j+\sum_{jk}\chi^{(2)}_{ijk}E_jE_k+\cdots\right)[/tex]
where [tex]\chi^{(1)}[/tex] is your normal susceptibility and [tex]\chi^{(2)}[/tex] comes from the Pockels effect and so on, but I didn't feel like expanding it out further than I did because I doubt that the professor would have assigned such an problem (that is, I still assume it is linear).
So I guess I was technically wrong about saying that [tex]\chi_{ij}[/tex] was the non-linear term. When you asked further, I pulled out my non-linear optics text to double check.
I am sure.
Careful,
[tex]\rho'=-\mathbf{\nabla}\cdot\textbf{P}\neq-3P_0[/tex]
Why not, I use the nabla operator in spherical coordinates which according to my textbook is:
div A= 1/r^2 d/dr(r^2 A_r)
In this case, A_r=P0*r.
[/quote]
Not sure how to do this, [tex]div E=4\pi \rho '[/tex], I can assume here that E is radial, if yes then it's rather simple as well.
I am sure.
Okay.
Yes, I edited my post when I realized my error:smile:
Have you not already calculated the fields due to a uniformly charged sphere and a uniformly charged spherical surface?:wink:
So for r<a, Q enclosed is q, so D *4pi *r^2=q, => D=q/(4pi*r^2)
for a<r<b, D(4pi(r^2-a^2))=q
for r>b, D(4pi * b^2)=q
Is this right?
Thanks in advance.
P.s
Don't know but electromagnetism in university is still my tough part in physics, though the theory is pretty neat I find myself baffled at questions which are rudimintary.
Why do you have the r^2-a^2 there? What are you using as your Gaussian surface? What is the flux of a spherically symmetric D-field through that surface?
I'm not sure what you mean by "ring", but I guess you are referring to a spherical shell of thickness r-a? If so, that is a VERY poor choice of Gaussian Surfaces; it is actually two surfaces (at r'=a and r'=r) and hence the D-field will have two different values over this surface (D(r'=a) and D(r'=r))
[tex]\oint\textbf{D}\cdot d\textbf{a}=4\pi D(r)r^2-4\pi D(a)a^2[/tex]
Just use an infinitesimally thin spherical shell at r'=r instead.
