2 Vectors with Angles acting on an object
  • Thread starter Thread starter JackandJones
    Angles Vectors
7 replies · 6K views
JackandJones
Hey guys, I am having a little trouble determining the final answer to this question.
Basically an object is being pulled by two forces and I am suppose to find the Net Force
F1 = 12 N at an angle of 32 degrees (upwards)
F2 = 15 N at an angle of 24 degrees (downwards)
So what I did was split the two vectors and try to find Fnetx and Fnet y
For Fnetx = F1net + F2net
F1 = 12Cos(32)
F2 = 15 cos(24)
I added F1x and F2y and got
Fnetx = 23.87 N
For Fnety
F1y = 12sin32 = 6.36 N
F2y = 15sin24 = 6.10 N
I subtracted F1y-F2y because F2y is going in the negative direction so
Fnety = 0.26 N
I am not sure if I should add these together or use PT to get Fnet...then use Trig ratios to get the angle... ?
Any ideas? I appreciate the help!
You've now got the x and y components of a vector.
So how do you calculate the length and direction of the vector from them?
(You can't just add the lengths of the components - that would make no sense.)
If I have Fnetx and Fnety
Would I use pythegorean theorem to find Fnet, and then Trig ratio to get the angle?
Nytik said:
Exactly that.
Okay perfect However could you please explain why I would not substract the F1y by the F2y?
Because F2y is a downward motion, it would not be negative?
You do subtract them; everything you have done up to this point is correct.
Okay its just that the answer doesn't seem correct to me.
Fnetx = 23.87 N
Fnety = 0.26 N
Using PT:
Fnet = 23.87 N
Then then using Trig Ratios, the Angle = 0.62 degrees... which doesn't seem correct..?
This thread has been moved to the "Introductory Physics" section of "Homework & Coursework Questions", where it should have been posted in the first place. Carry on, and try to remember to post similar questions here in the future. :smile:
