Some help with C programming questions
Reversing an array in C requires swapping elements from both ends towards the center, but the provided loop contains an error with an extra semicolon that disrupts its functionality. For checking duplicates in an array, the current implementation always sets duplicates to 1 because it compares each element with itself, failing to account for distinct pairs. When swapping two elements in an array, the first assignment overwrites the value needed for the second assignment, leading to incorrect results. Correcting these issues involves adjusting the loop structures and ensuring values are preserved during swaps. Addressing these coding mistakes will help achieve the desired outcomes in the assignments.
fubag
I have a few questions:
1. Reversing the elements of an array involves swapping the corresponding elements of the array: the first with the last, the second with the next to the last, and so on, all the way to the middle of the array.
Given an array a , an int variable n containing the number of elements in a , and two other int variables, k and temp , write a loop that reverses the elements of the array.
Do not use any other variables besides a , n , k , and temp .
I have:
for (temp=n;temp>0; temp--;)
for (k=0; k<n;k++)
a[k] = a[temp-1];
the compiler yells at me and I don't know what's up...just for everyone to know this is a Codelab assignment.
2. You are given two int variables j and k , an int array zipcodeList that has been declared and initialized, an int variable nZips that contains the number of elements in zipcodeList , and an int variable duplicates .
Write some code that assigns 1 to duplicates if any two elements in the array have the same value, and that assigns 0 to duplicates otherwise.
Use only j , k , zipcodeList , nZips , and duplicates .
I have: duplicates=0;
for (j=0; j<(nZips); j++)
for (k=0; k<(nZips); k++)
{ if (zipcodeList[j] == zipcodeList[k])
duplicates=1;
yet the feedback comes back i am not assigning 0 to duplicates if they don't match...
3. Given an array arr of type int , along with two int variables i and j , write some code that swaps the values of arr and arr[j] . Declare any additional variables as necessary.
I wrote:
int x=j;
arr=arr[j];
arr[j]=arr;
- but the feedback comes that only one variable is changing...I don't understand why..
I know it's a lot but if someone can help me on any of them I would appreciate it a lot!
Thanks!
Technology news on Phys.org
1. for (temp=n;temp>0; temp--;)
You have a semicolon too many there. There should be exactly two semicolons in a for(a;b;c) clause.
2. This will always return 1, because when j == k then zipcodeList[j]==zipcodeList[k], always.
3. On line two you assign arr[j] to arr. On line three you assign arr to arr[j]. But you destroyed the value of arr on line two, didn't you? You overwrote it with arr[j]. So assigning arr to arr[j] afterwards does nothing.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
  • · Replies 29 ·
  • · Replies 25 ·
  • · Replies 22 ·
