270 degree thrust bearing solutions?
13 replies · 4K views
Jarfi
I need a thrust bearing, it has to be like the one in the picture as in it needs to have a hole in the middle(a circle). However all the non 360 degrees thruster bearings I googled are not circle shaped, but I need free space, it would preferably have the same diameters as the pic but just 270 degrees..
not sure if it's even possible but yeah I need something along those lines.
EDIT. It only needs to be able to rotate 45 degrees.
I'm not sure I understand what you are looking for, but why not just use what is pictured with a stop at the appropriate angle?
I don't think that'd work, say I cut 45° of the circle. the balls would fall out, and if I closed the ends so they couldn't fall out, the balls would not be able to roll forward to let the bearing top slide in a circular motion because they'd be p ushed to the ends and they'd hit the ends causing some friction, which wouldn't make a good bearing.
It's hard to explain without drawing it up in solidworks. I am not even sure if what I am asking for exists, or can be made
I was not thinking of having the stop on the bearings race, but either inside or outside it, whichever works.
The race has to go all around anyways, just to keep things from flexing.
And as a physicist you have reached the end of my vocabulary.
Thanks a lot for sharing! I think sintered bearing are best for 270 degree thrust bearing solutions...The sintering make it reliable and durable with very much flexibility!
HowlerMonkey said:
What turbocharger are you working on?
I'm not, I'm not even working on a car, I ended up creating a wholly different system in SolidWorks, I can't really call it a bearing anymore but the problem is solved regardless.
What I ended up doing was simply a 270 degree ring, that was fixed between gears so it could slide back and fourth.
Realistically, you need at least two thrust bearings on a crankshaft. Have a buddy depress the clutch and check for endplay. If it wiggles, you have a problem.
The nut used on a ballscrew recirculates the balls from one end of the nut to the other. You could do the same with a thrust bearing by having a non-loadbearing path as a ball reservoir and return path.
Renukanissi said:
These type of bearing is available in market. Some of the manufacturers are specialized in this types of bearings.
Can you please provide a link to the manufacturer and a series or part number.
